Question about Sony STR-DE535 Receiver
SPEAKER PROBLEM I have a problem with my center speaker. I get a buzzing sound but when I disconnected one of the channels everything is fine.. I determined that it was not the fault of the speaker, borrowed a speaker from a store and had the same problem. Anybody have any idea what the problem could be. I have my system hooked to a high def TV.  EMILE  embike@rcn.com
techman
  • 3130 Answers
SOURCE: Center speaker not working
Yes Mark, You have a problem with a componet with that center channel. If your not a tech, dont have a schematic, or dont have any training in troubleshooting solid state electronics, unhook everythuing and take it into a repair senter for an estimate, as unless you know how to chech the parts you can cause more damage to the unit as it takes one slip and boom, all gone. Good Luck
Posted on Jul 28, 2006
  • 15 Answers
SOURCE: Sony STR-DE945 5.1 Channels Receiver
Hi, Happened across this forum looking for some remote info. Had a similar problem with my 945...main speaker outputs started to click off & on, no rhyme or reason. Found that the solder joints on the speaker output relays were cold (poor soldering). Actually happend twice, two different relays. Took me a while to find it, reflowed the solder, that solved the problem, over two years ago now. Are you able to dig into the receiver? Do you have a (good) soldering iron and some solder? If not take it to elec. shop and tell them to look for cold joints on the relays.
Posted on May 11, 2007
  • 5 Answers
SOURCE: Sony STR-DE845 center channel cut out, receiver clicks
I have fixed 3 shorts on my de845. 2 have been caused by cracked solder joints. they were speaker cutout problems...yours most likely is the center channel relay on the main board. take the thing apart. you need to get to the back of the main board and re-flo those solder joints. get your geeky pc buddy and do it together(buy him a sixer). its really not that hard...just a bunch of screws. disconnect everything from the main board including the front plate. be careful with the ribbon cable...mine is hurting at this point. not meant to be removed so many times. put it in straight. my leads bent, but was able to straighten them. there are 5 relays together, one for each channel. they are white cubes and prb a little smaller than the tip of your finger. its the 4 leads on each of these that you want to take a soldering iron to . i'm not sure which ones the center channel so do them all in that area. it may be hard for you to tell which leads they are so just go overboard and at least get everything in the vacinity. i did all component leads because who's to say another's not ready to go bad. you've gone this far. touch the heated up tip to all the leads at the very end of the barb. you can reflow the solder without actually touching it. the metal lead will get hot enough. hold it until the solder liquifies, then let it cool. do this on a flat surface. my other fix once was a re-seating at the speaker switch a,b,a+b on the front plate. there are 2 boards plugged together there. i bent the leads slightly so they seated in more tightly. if your left or right front goes out, sometimes thats an easy fix...try b if you're using a, or the opposite. don't forget the speaker cables. if you're using both zones then you prb already figured out you need to re-flo! test and cross your fingers. good luck.
Posted on Jul 27, 2007
SOURCE: No output on main speakers
I have experienced a similar problem with my Sony STR-GX57ES and took it to a certified tech only to find it needed the power supply replaced. I opted to hunt down a compatible power supply but have been unsucessful thus far. That being said I picked up an STR-D665 for next to nothing and found the power supplies to be quite different (you would hope so any, with the ES meaning Elivated Standard and all) but with the D665 working flawlessly I'd rather have something working than nothing. Good luck!
Posted on Aug 17, 2007
marsrover
  • 682 Answers
SOURCE: STR--DG910: no rear speaker sound, no center speaker sound
if you confirmed all connection repeat your speaker setup.
Posted on Aug 02, 2008
Why am i not getting any sound when i hook up a speaker directly up to a speaker channel its only a buzzing sound
If the radio is powered on, put a cd in, or make sure you are on a known good radio station and connect a speaker directly to one of the pairs of speaker wires on the radio. let us know if there is still just static.
Nov 07, 2013 | Farenheit TID735NRBT Car Video Player
Have been trying to connect speakers to my samsung AV-R720 receiver but I am getting a terrible buzzing sound and only the center speaker is playing. I have lost the manual and would like to know about...
http://www.retrevo.com/support/Samsung-HT-AS720-Home-Theater-Systems-manual/id/6333ci454/t/2/
Page 10 discusses speaker connection.
Disconnect everything but the speakers and evaluate the buzz. It may be coming from external hardware or loosely connected analog cables.
Sometime juts rotating the ac plug on one device eliminates the ground loop buzz.
Feb 07, 2011 | Samsung HT-AS720ST Theater System
Yamaha RX-V365 Receiver when I hook up my center channel it is not audible at all. The R and L speakers work fine when they were located in the FRONT A and FRONT B terminals, but when I moved everything to...
With what signal did you try? Maybe your signal source (DVD/TV or radio) didn't contain any sounds for the center channel.
Go to the Setup menu, Speaker setup / Manual setup and find there item called "Test tone". It will output a test tone to each speaker individually (you will see on LCD which speaker is being tested at each moment). If you will hear a sound from the center now, there is no issue and center is working fine, just your source didn't contain any sound for the center.
If it doesn't work, then either you have faulty cable, faulty speaker or faulty center output of the receiver.
- Try connecting the center speaker to different output of receiver (this will test if speaker is OK).
- Try connecting working LEFT speaker to left output with CENTER cable (this will test if cable is OK).
- Try connecting working LEFT speaker with working cable to the CENTER output (this will test the output of receiver if OK - but use the Test Tone from Setup).
May 18, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Onkyo TX-DS696 receiver center channel not working
Can you say explicitly that the Center Channel speaker is defined as something other than NONE?
And how does dialog sound? If it sounds ok you're routing it to the front speakers. This is from the manual...
"For ideal Surround effects, all speakers should be installed. If a
center speaker or subwoofer is not connected, the sound from the unused channel is properly distributed to the connected speakers in order to produce the best Surround sound possible."
Apr 10, 2010 | Audio Players & Recorders
Rx-v1800 with check sp wires problem,narrowed it down to the center channell speaker which is 8ohms the rest of the speakers are 4ohms center speaker checks out fine on other receivers,could the ohm...
So are you saying the error goes away when you disconnect the center speaker and its cables? Sounds like you have one more step to isolate the exact external component: try a different speaker as the center and/or try a different speaker cable.
Did you set the speaker impedance (Page 33 and 117) to 6-ohm min. AND - the manual does actually say "the impedance of each speaker must be 6-ohms or higher" for all BUT the Front speakers.
Mar 23, 2010 | Yamaha RX-V1800
Sound from 3 channels only
Sometimes what happens is that people r just confused with all wirings.Considering that you have connected the speakers correctly...Now according to u the center speaker is not working
  1. If u have a jack attached at the end of the speakers then try connecting the center speaker jack into the Right front/Right Rear/Left Rear socket at the back of the reciever.Just to make sure that your speakers r fine.
  2. Secondly play an audio cd first,sumtimes a video DVD not being 5.1 channel one confuses a lot.
  3. Assuming that you have checked the center speaker,like I asked u too,Connect it into its proper socket or better connect all the speakers.
  4. Now with the remote you check the predefined equalizer in it n keep changing that [pop,rock,jazz etc] or you might even want it to change it to 5.1 from a 3channel or 2channel Stereo.Everytime you change it listen to every speaker.
  5. Also check that you have increased all the speakers volume one-by-one.
  6. Disconnect any headphones attached.
  7. Switch on the selected source or select another source.
For further details u can check the manual.
The VGA cable of the monitor will work fine.
Jun 03, 2009 | Philips HTS3450 System
Centre Channel speaker has stopped working
connect any speaker instead of center speaker if you get the same result you will have a problem in amp itself if the problem fixed change center speaker with a new one
Apr 11, 2009 | Audio Players & Recorders
Carver Sound Problems
your going to need this place to download the remedy's for your system http://www.euras.com/repair_tips_1/CARVER/AV505/AV505_CARVER.htm
if it is not working then there is another serious problem , and it could be the amp IC or the volume IC but tests will need to be done to determine what is causing the failure , but it does sound like amp IC as a suspect since the rear were not even working , did the volume seem different when turning it up or down before the center quit or after the center quit?
Nov 02, 2008 | Audio Players & Recorders
DVD plays partial sound
Check your speaker connections it sounds like you have a 5.1 or higher sound system. 5.1 means left front speaker, right front speaker, center speaker, right rear speaker, left rear speaker and subwoofer.
Voices in movies all get channeled to the center speaker (you can usually hear it a bit from the right and left front speakers as well). If your center speaker is disconnected or not working, you will only hear the background sounds.
Sep 20, 2008 | Compaq Presario 5000 PC Desktop
Sony STR-DE535 Receiver Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
