Question about Cameras
I have a Polaroid i533 camera, I currrentyly don't have any pictures on there and it keeps saying my memor is full. Even when I have a blank SD card it says that the mempry is full. Any help?
Minez does the same thing who knoes how to fix that?
Posted on May 05, 2008
Polaroid tablet 8-in wont accept any sd cards?
Look for a format command within settings on the tablet. Also, there are different types of SD Card.
SD card TYPES - Google Search
Apr 08, 2017 | Cameras
Is there or was there ever a Firmware update for the i533 DIgital Camera to be able to use a SD card bigger than 2 GB and /or a SDHD Card larger than 2 GB. Thank you.
No, and there never will be. SDHC cards are electronically different from SD cards. While an SDHC device can use an SD card, the reverse does not hold. It's a hardware difference, and no amount of firmware tweaking can make an SD device use SDHC cards.
Oct 20, 2010 | Polaroid I533P Digital Camera
I have a i533 5.0 megapixel digital camera.I took pictures thinking the memory card was in it but it wasnt and it said memory was full so i deleted the pictures off the camera and put the memory card back...
You caused a card conflict, or have corruption on the card.
Try this:
Remove the battery from the camera.
Remove the memory card, and re-insert.
Install the battery back in the camera.
Turn on the camera.
In the setup menu or the equivalent for your camera, select the card options. Indicate for it to re-format, or re-initialize the memory card.
If the above does not work, you should call the support line for your camera.
Jerry G.
Sep 26, 2009 | Polaroid Cameras
Keep saying memory full and I have not used it yet
all cameras have a small internal memory, in your case three pictures, you need a memry card, your manual should tell you which type you need (although for polaroid, i think [but am not sure] thit it will be an SD card) you should probably get a 1-4 gb card, as this will let you take a few hundred photos, before you have to download them onto your computer
Jul 31, 2009 | Polaroid i733LP Digital Camera
Polaroid i533
Check you camera instruction book. The card may be the wrong one or two large or???
Jul 26, 2008 | Polaroid I533P Digital Camera
It Turns On Then It Turns Right Back Off
I put Rechargable Duracell Batteries in and now it takes pictures and turns on without a blank screen or shutting back off.
Jul 12, 2008 | Polaroid I533P Digital Camera
Is the polaroid i533 camera compatible with sdhc memory cards? Or does it only use sd memory cards?
No, the polaroid i533 camera is not compatible with sdhc memory cards. Use only SD cards.
Jun 27, 2008 | Cameras
Polaroid digital camer i533
I am assuming it is an SD card. There is a small slider on the side of the card you just need to move it towards the gold part of the card.
Jun 11, 2008 | Cameras
Re:sd card
The SD card has a "lock" lever on it...make SURE it is in the "unlock" position.
You might also try using an SD card reader. These are VERY inexpensive on Ebay- but your computer has to have Windows 2000 installed for these readers to work.
May 04, 2008 | Polaroid I533P Digital Camera
The lcd screen on my polaroid i533 digital camera went out
your screen is broken, some one must have accidentally put pressure on just the screen. The smae thing happened to my screen now i am looking to buy a new screen
Oct 27, 2007 | Polaroid I533P Digital Camera
Cameras Logo
77 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
