Question about Refrigerators
Electrical unit attached to compressor keeps making a spark(clicking sound) Fridge & freezer slowly stopped cooling during the day and is now down to 0 cool.
  • Anonymous Mar 12, 2014
    This is a mini-fridge made by Haier. The clicking sound occurs every 10 to 30 seconds and is coming from the relay switch attached to the compressor. I did detach it from the unit and shook it and only heard a faint click. Any suggestions would be appreciated.
  • 828 Answers
Overload thermal protector is tripping out. When a mechanical refrigerator is unplugged it should remain unplugged for 5-10 minutes to allow the refrigerant pressure to equalize. If you unplug it and then plug it right back in the overload will open on and off until the pressure in the system balance to the point where the compressor will start.
This protector is a two way protector. It opens on Over current and or over temperature. If a condenser is plugged with dust , hair or what ever the fan which circulates the air for cooling the system will not move enough air to keep the compressor with-in operating temperature range. The thermal protector will open.
Posted on May 04, 2008
My 18 year old refrigerator GE model TFX24FG freezer side is not keeping food frozen. Refrigerator side seems to be working normally.
The refrigerator side is at present working properly , but slowly slowly, it will also loose its cooling.This will happen because, freezer side is the side which cools first, then the refrigerator side ( also called as fridge side)., gets cooled.If freezer side is not cooling / freezing properly then fridge side will also loose its cooling ability.------------ And later on both section will loose its cooling.----------- As per the present situation, it indicates problem with compressor or problem with freezer side door not closing properly.---------- Or the temperature in freezer section is not set to proper cooling/ freezing.--------- So first inspect temperature, is it set right? If ok, then check the freezer door , is it properly closed? If ok, then its compressor problem.? The compressor is running non stop, this is indication of compressor problem.---------- Click this link below for more help:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html ----------- Later on both section will loose its cooling. -------- This will help.Thanks.Helpmech.
Aug 19, 2011 | Refrigerators
How do you add a switch to disable the thaw cycle from an Amana top freezer fridge.I need to do so i can use solar power on my fridge.the thaw unit uses to much energy so when i am boondocking i can switch...
while i do not reccomend doing this since more energy is used in running the components to make is cool (compressor,compressor fan & freezer fan) all 3 must run to keep it cool while the defrost comes on for 25 minutes about once every 4 days as compered to the cooling components running a average of 24 hrs during the same time span as compared to 25 minutes is to disconnect teh wires from the defrost heater behind the freezer back wall
ps if you read this and give me a bad rating i do not care
Aug 11, 2011 | Amana ATB1832AR Top Freezer Refrigerator
Model 5920991 kenmore side by side unit quit
Pull the fridge out and remove the bottem panel .find the compressor it is a black round unit.listen to see if the compressor is running should make a hummming sound if you put your ear by it.If it is not running check the starter relay. TO check it unplug fridge remove relay it is located on the side of the compressor with 2 or 3 wires running to it. remove it and shake it if it rattles or if there are burnt spots on it it needs to be replaced.Hope this helps. if so give us a4 thumbs up.THANKS
Mar 02, 2011 | Kenmore Side by Side Refrigerator
Model BC21VW Amana Lower Freezer works, Upper Fridge not cooling
I want you to see if you can manually get the refrigerator into defrost. At the bottom of the front of your refrigerator and behind the kick plate is a defrost timer part number 10530703 I want you to pull the kick plate away from the bottom and there should be a metal mount with a hole in the center. Take a flathead screwdriver and slowly turn clockwise until the compressor stops. The refrigerator should remain off for about 25 minutes. During that time open the freezer door and listen for crackling and sizzling sound. That should be sounds of defrost taking place. If timer is not working properly you may need to turn again slowly clockwise after the 25 minutes and replace the timer. The only other 2 things that may be causing this is the defrost heater or defrost thermostat inside the back of freezer and behind the rear panel. Try this first and let me know what you find, Thanks, Sea Breeze
Sep 17, 2009 | Amana ABB1927DE Bottom Freezer...
Freezer works, fridge doesn't cool
Probably excessive ice in the condensor. Likely defrost thermostat or defrost heater problem.
What happens is excessive ice keeps airflow from the refrigerator part of the unit.
Jul 08, 2009 | Refrigerators
The fridge side by side door. Freezer & fridge stop working I can hear the motor trying to go but doesn't cool
When you say motor I assume compressor. No start compressors can be an electrical component like the start relay or the compressor itself. Eric
Jun 14, 2009 | Frigidaire FRS3R5EMB Side by Side...
Candy fridge freezer
it should come back after about 20 mins only and should cool back after about 10 mins.
i'm afraid the buzzing sound could be coming from your compressor which can not start. the over current relay is tripping off after 20 seconds to prevent the compressor from burning up.
i suggest to unplug the ref, let it cool for 1 day, re plug it after a day and observe the compressor if would run.
if the buzzing sound is still there and the unit is no longer cooling, then the compressor is not running.
check the relay of the compressor. it could just be the relay.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Candy CPCA240FFK Bottom Freezer...
Maytag side by side slowly getting warmer
I have actually been having the same problem. We have a Maytag MTB2156GEQ and it hasn't been cooling well at all lately. Temp in the fridge is about 52 degrees even on the highest setting. The freezer seems to be fine. I pulled off the back panel and vacuumed out the condensor coil and everything else under there. I then pulled out the control panel on the ceiling of the fridge. The channel between the freezer and fridge was almost completely blocked with ice. I cleaned it out by taking out the back panel of the freezer and pouring hot water down through the hole until it was clear.
that seem fix the issue.
Aug 10, 2008 | Maytag MSD2656G Side by Side Refrigerator
Refrigerators Logo
394 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
