Question about General Electric Cafe CSCP5UGXSS Side by Side Refrigerator
The refrigerator part is not col but freezer is
Freezer is col, but refrigerator seems only cool and there is condensation. type is kennemore elite
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 21, 2011 | Refrigerators
My freezer is cold makes ice fridge is warm not cold at all
Look for frost on the rear of the freezer, that is a sign of a defrost problem. If the heater or heater thermostat is open then ice will form over the cols and block the flow of air.
Service manual for amana bottom mount
Jul 14, 2011 | Amana ABB1927DE Bottom Freezer...
Our 3 months old refrigrator will get so cols that freezes food products.
There are actually 2 cold controls on refrigerator-freezers. The main control is within the refrigerator cavity, the other is located in the freezer cavity. The one in the freezer is usually only a cold air deflector. It takes the cold air that is produced and divides it proportionally between the freezer and refrigerator sides. Set the control in the refrigerator to about mid-range. Set the control in the freezer to mid range. That is your starting point. If the freezer is not cold enough, adjust the freezer control. If the refrigerator s not cold enough, adjust the fridge control. After any adjustments, you MUST wait at least 24 hours for the temp to equalize before making any more adjustments. It may take a week to get it set right. This is true for all refrigerator-freezer combinations. Be patient.
Oct 09, 2010 | KitchenAid Refrigerators
The freezer is working OK but the refrigerator is not getting col
you have leakeage on pipes(smal hole) in short time and the freezer wil not getting cold.call specialized service, they must have a good welder.
Feb 15, 2010 | Frigidaire FRS3R5EMB Side by Side...
Frig side doesnt cool cant hear fans but the freezer is still col
if the fan isnt running it either needs to be replaced and/or you could have a bad sensor in the freezer or a defrost control problem. if there is ice build up behind the freezer wall that could also block the fan from turning and the ice build up would most likely be a defrost problem.
Sep 17, 2009 | Samsung RS2630SH Side by Side Refrigerator
Jenn-air JCD2289ATW Freezer perfect but refrigerator is warm
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 12, 2009 | Jenn-Air JSD2789GES Side by Side...
No cold air n at all in refridgerator or freezer oadmirall sideo
I believe i just posted part of your answer and mine, switch icemaker switch to off position and noise stops i'm assuming ice maker has had better days but hope it can be remidie
Jan 03, 2009 | Jenn-Air JCD2295HES Side by Side...
Refrig does not get col or work but the freezer works
is the fan running in the freezer if not go there first
Apr 25, 2008 | Refrigerators
General Electric Cafe CSCP5UGXSS Side by Side Refrigerator Logo
24 people viewed this question
Top General Refrigerators Experts
John Tripp
John Tripp
Shehu Pro
Shehu Pro
Joseph Mueller
Joseph Mueller
Are you a General Refrigerator Expert? Answer questions, earn points and help others
