Question about Loewe Articos 55 55" Rear Projection Television
Moved from UK to US, can Loewe Articos and Individual TV's be switched from PAL to NTSC?
  • 15 Answers
SOURCE: Loewe Articos 55 RP
There is a software patch that increases the cut off temperature you may get this at Loewe Website. Quick fix is reverse one of the fans on the back of the set this gives a through flow of air rather than all fans blowing into the set.
Posted on Jul 29, 2008
ladywinn
  • 5138 Answers
SOURCE: loewe articos muffin fan stops..
If Fan stops running Lamp will not Light and TV will not come on!On your Menu you should have in there a listing for Lamp Timer it should tell you how many hrs you have on Lamp and Ballast Board is what turns Lamp on if you need Parts Call Encompass 1-800-638-3328 or UED 1-800-648-6657
Posted on Nov 14, 2009
ladywinn
  • 5138 Answers
SOURCE: loewe articos hd tv rear projection. contrast too shiny
Try lowering Brightness first.Not contrast leave it up middle range.
ladywinn
  • 5138 Answers
SOURCE: 55 in loewe articos rear projection
You might have defective Fan if Fan stops running Lamp will not Light also keep in mind Ballast board it what turns lamp on and Fan is what keeps Lamp cool, and most of the time if set is not comming on Lamp is Bad. Call Encompass Parts 1-800-638-3228 or UED 1-800-648-6657 main 3 parts to DLP is Lamp,Ballast board ,Lamp Fan.Id say you have Bad Lamp! God Bless and hve a wonderfull Day.
SOURCE: loewe articos 55
had same problem, solved by lamp replacement. back to full glory!
jurgen
Posted on Nov 21, 2009
How do I get a US Sony Bravia KDL-42V4100 to work in the UK?
I have encountered this before---there are set top boxes that will convert the NTSC to PAL and the only other concern is the line voltage being the same or not.
May 29, 2012 | Sony Bravia KDL-42V4100 42 in. LCD TV
How do i change my channel tuner from NTSC to PAL?
you need to get a converter that takes pal and converts it to ntsc.
Apr 16, 2012 | Sanyo DP50747 50 in. Plasma TV
DVD will not play in color, what am I doing wrong
Hi, are you using a UK pal tv? Chances are you are watching a US region 1 dvd which is encoded in NTSC. This will play in 525 lines and black and white on a UK PAL tv. Does your DVD player have an NTSC playback to PAL tv swich? It would simply be labeled "PAL" and "NTSC" If not on the back then possibly in the menu. If you have the switch select NTSC and try again.
Hope this helps
Steve at Olive Country Computers in Spain
Mar 04, 2011 | Durabrand DVD-1002 DVD Player
I have sound but no picture with my Loewe TV
Bad Ballast Board Call Encompass Parts 1-800-638-3328
Apr 13, 2009 | Loewe Articos 55 55" Rear Projection...
Loewe articos hd tv rear projection. contrast too shiny
Dec 26, 2008 | Loewe Articos 55 55" Rear Projection...
Using pal/ntsc system dvd player in USA - how to setup to work on ntsc tv
You sould have a button on the remote controls thats says Pal/NTSC, press that button to switch.
Nov 07, 2008 | Durabrand Televison & Video
Loewe articos 55
jurgen
Oct 07, 2008 | Loewe Articos 55 55" Rear Projection...
Loewe Articos 55 RP
Apr 24, 2008 | Loewe Articos 55 55" Rear Projection...
JVC DR-MX1S
It's likely to be an incompatible signal. You have PAL (UK) and NTSC (Belgium), the DVDR/VCR combo may not be compatible with PAL causing it to seem like it's not receiving any signal, when in fact it is - but not in a recognisable format. You may try and get an NTSC to PAL signal converter like this: http://cgi.ebay.co.uk/NEW-TV-AV-Video-System-NTSC-To-PAL-Converter-Converor_W0QQitemZ270163920912QQihZ017QQcategoryZ32837QQtcZphotoQQssPageNameZWDVWQQrdZ1QQcmdZViewItem That'll solve your problem.
Sep 09, 2007 | JVC DR-MX1S DVD Recorder/VCR
Pal/Ntsc playing problem
is your tv is the same tv that u playing before? coz according to you if u play ntsc there is no problem. if ur tv is multisystem, u can change the tv system menu to auto, but if not u cannot watch coz ntsc tv only accepts ntsc signal.
Jan 08, 2007 | Pioneer DV-373 DVD Player
Loewe Articos 55 55" Rear Projection Television Logo
23 people viewed this question
Top Loewe Televison & Video Experts
Are you a Loewe Televison and Video Expert? Answer questions, earn points and help others
