Question about Philips Televison & Video
Not sure which philips i have, but suddenly lines have appeared at the top of the picture, going the width of the screen, about 4 inches down the screen, and moving downward.
    Scholar:
  • 33 Answers
It seems you may have a vertical linearity problem. Check all electrolytic capacitors around the frame output stage. The frame output ic may be at fault but this is less likely.
Regards Vintie
Posted on Aug 22, 2010
I have a 27 inch panasonic and have about 19 real thin lines across the top of the screen. It is in the top 4 inches of the picture tube.Model CT-2701G Built 9/03
Scan coils (field) measure about 5 to 15 Ohms from the plug where they connect to the main PCB
Look for the cables that come down from the scan coils (deflection yoke) to the main pcb
its either two cables and two plugs or a 4way cable with one plug to the main pcb
2 of the wires goto the vertical(height) and 2 to the width
try to work it out which (the fattest wire is width)
The width ones go towards the loptx(line output/flyback transformer),
and the height ones go to the field output chip (or transistor pair) Follow the printed circuit from the plug and look for a 7 or 9 pin chip on a cooling plate(heat sink for the posh),
it should have a diode connected to it and about 25v on both ends of the diode.
Jul 14, 2008 | Televison & Video
Visual transparent lines at top of picture
You have a vertical output circuit problem. This was common for Philips' sets. Have a repair shop check it out. Should not be too expensive to repair.
Oct 15, 2009 | Philips 27PT6441 27" TV
Horizontal lines across the top 3 inches of picture
Hi
what line started? from Left to right? or from top to bottom?
Thanks!
Nov 28, 2008 | Philips 32PT6441/37 32" TV
Colored Lines Destorted Picture
I had the same problem , sent it into the shop and they said it was a capacitor . It is a $3.00 part and $75.00 for labor . But it did fix the problem . The labor charge was inflated I'm sure so if you someone who can do it and just get the part ,would be the way to go.
Apr 13, 2008 | Philips 32PT5441/37 32" TV
Blue tint and lines on screen.
Those lines sound like "retrace lines" and several things can cause them. The most common are shorts inside the picture tube and shorted semiconductors in the video driver circuits. They can also be seen if the blue screen voltage is too high or if someone has tampered with the screen voltage control.
Jan 20, 2007 | Philips 28PW9536 28" TV
Vertical, pencil-thin blue line appears after 10 minutes of viewing (any source)
I would suspect a connection breaking down as the set heats up. A shop will probably have to put the set in a stand to hold it while they check for loose connections or defective components inside. Not a DIY job by any means. If this line went completely through the picture either vertically or horizontally and stayed there then this would have indicated a failure in the Panel itself. A thin Line any where on the screen consisting of one pixel in width is a Panel Failure according to Hitachi.
Jan 01, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Televison & Video Logo
52 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
