Question about Health & Beauty
Yesterday all the lights started blinking every once in a while when I first turned it on. Then it was hard turning on and off; and NOW it won't start at all. I took it apart and made sure the connections were tight to the battery. It still won't work. On one of the connectors it has a three prong plug but I noticed there are only 2 prongs inside the plug. Anyway, I need an electrical diagram and instructions on how to check the VSI controller and everything else on this. PLEASE HELP. I live alone and it is really hurting not being able to use it and I can't afford to have it taken in to be fixed. Thank you in advance.
  • Barbara Frost Aug 22, 2010
    This is not a blood pressure monitor it is my quantum 610 power chair.
What is the make and model of your blood pressure monitor?
Posted on Aug 22, 2010
My sansui hdlcd1909 19 in. lcd tv won't turn on. the standby red light blinks once, what can i do to turn it on?
sounds like bad capacitors on the power board. Very common problem. I would look at the caps if any appear even slightly rounded on top they are bad. They should be perfectly flat on top any puffing up means replace that cap.
Aug 07, 2012 | Sansui HDLCD1908 19 in. LCD TV
Washer Control Locked blinking and won't washer won't work
Water still in the bottom of the drum. Empty, clean filter and check pump is turning. Once pressure switch is satisfied no water is left it'll allow the door to open, assuming the door interlock is still ok.
May 19, 2012 | Washing Machines
My mitsubishi tv W55613 won't turn on. green light keeps blinking even after resetting
Hit the front of the tv near the blinking light... give it a good rap or two. See if this helps. Helped mine. I had the same problem and the tech who came out to the house told me that it would work and it did! I could hardly believe it but it worked.
Feb 13, 2012 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi WS-65513
if you changed the energy mode from standard to low that is normal, anytime you turn the set on it will do the same,
plug set green light will blink one minute.
turn it on it will blink onother minute and then turn on(make sure that you dont keep pressing power key) once on you can change your settings again.
hdtvman.
Apr 07, 2008 | Mitsubishi WS-65513 65" Rear Projection...
The 3 lights blink on and then off and on and then off etc.
try and restore your computer by clicking on start all programs, accessories, system tools then system restore, restore it back for a few days or a week even try that
Jan 24, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Change Image Drum light blinking
You have to reset the drum counter. Leave the front cover open Press and hold the "cancel" button until all the lights flash in sequence Close the front cover You should be good fro another 30 - 40 thousand copies. Hope it helps Ed
May 22, 2007 | Dell 1710n Laser Printer
Health & Beauty Logo
89 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
jeff tilburn
jeff tilburn
Are you a Health and Beauty Expert? Answer questions, earn points and help others
