Question about Frigidaire Dryers
Have a frigidaire "gallery" series stackable washer/dryer, the heating element initially turns on when the dryer starts. you can see the element light up and feel heat but after a minute of run time the element goes out and clothes do not dry.Is there a sensor and/or switch on this unit that cycles the heating element? shouldn't the element stay on during the drying cycle? Any help would be greatly appreciated.
  • Frigidaire Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Aug 22, 2010
Frigidaire stackable washer making loud clunking noise when spinning
You will need to take the front cover off and check to see if there is anything lodged between the drum and housing.
Jan 27, 2013 | Frigidaire Gallery Series GLEH1642FS
Dryer won't start
have you left the unit unplugged for one night and tried to start??
doe sit make any humming noise when trying to start
Aug 25, 2008 | Frigidaire GLEQ642A Electric Dryer
Model #ALFRIGLEGLIS152ES Frigidaire gallery series won't heat. It stays on for a while and sometimes cuts off. When you set the time on it and press start all the lights start blinking on the o
Hi Robert Burch - From what you have described the unit could possibly have a communication problem with the control panel. However, if the unit is not producing any heat please have a professional diagnose the heating element and the blower assembly as well. Either, or, could be faulty at this time. This is not a typical DIY job so please consult a professional.
Oct 12, 2012 | Frigidaire Electric Dryer
How to disable buzzer from frigidaire gallery series stackable washer/dryer?
Here is a site showing all of the steps to disable both buzzers on the Frigidaire Gallery series stackable washer/dryer.
http://www.scribd.com/doc/34420420/Buzzer-Disconnect-Frigid-a-Ire-Gallery
Nov 19, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
I have a stackable Frigidaire Gallery Dryer. It won't turn on...
turn the start and it's like the drum gets stuck. then starts smelling like burning.
Mar 05, 2010 | Frigidaire Dryers
I have a Frigidaire Gallery Stackable that has a screechy dryer
Sounds like it is worn out. Get a parts diagram and take it apart and see what parts are missing or worn out. The belt is probably coming apart and that is the black stuff. There are several plastic wear plates and a bearing/bushing for the drum, plus the belt idler and all these can wear out. The motor could also have a bad bushing in it but more than likely that will require a new motor as they don't usually sell just the bushing or end caps.
Sep 03, 2009 | Frigidaire FEX831CS Top Load Stacked...
Sounds like the bearing is gone, call a repiar man or buy new as repairman 100 per call
Sep 03, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Wire Scraping sound and sparks inside rear dryer drum area.
Probably the rear bearing has failed and caused the drum to rub against the heating element. Hey, is this the guy that said he heard a noise last month? LOL
Feb 01, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
314 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
