My document will not print. There are jobs in the queue, and I cannot delete them by normal means.
  • 480 Answers
Hi, you can try restarting the print spooler on your computer 1. click on start 2. go to run > type services.msc 3. look for print spool 4. double click on print spooler the click stop then slick on start 5. then try to restart your printer. and print again
Cheers!!!
Posted on Aug 22, 2010
What to do if after canceling the printing in queue document its status is still showing deleting ?
Give it a few minutes. Sometimes it takes awhile to delete the document.
If that fails, turn off the printer, wait a minute, then turn it back on. The document should be deleted.
Jun 29, 2015 | Office Equipment & Supplies
I need to restart my computer everytime i want to print
Sounds like you have print jobs stuck in the print queue. Try deleting all documents in the queue and resending print job. Some print drivers choak on PDF documents. Try updating the print driver by download it from the manufacturer.
Try deleting printer then re-installing printer and updating the print driver.
Sep 21, 2011 | HP LaserJet P3005 Printer
Printing blocked by a document showing being deleted
Sounds like a stuck document is in the print queue. Try to clear the print queue first before sending another print job otherwise it will just accumulate in the queue. The steps below will help you clear the queue.
Feb 21, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
Document won't delete from printer queue after printed
Have you tried to stop the spooler service in services?
Option 1)
Click on start orb
Type in search window:
services.msc
click ok
Scroll down to Print spooler service and click on it in the right side window.
On the left side click stop the service and wait forthe process to stop .Do not close the window yet. You will have to restart it here later.
next delete the print job in the printer queue then restart the spooler service
Resubmit your new print job.
Option 2)
If that doesn't clear it, the next step would be to stop the spooler
service as stated above
Go into windows explorer
(Print job data is collected and stored in a spool file in the spooler folder.)
It is located in:
C:\WINDOWS\system32\spool\PRINTERS
Your print job will show 2 files there Example below:
00002.SHD
00002.SPL
Delete the files located in there. There may be several of them depending apon how many print jobs you submitted. You will have to resubmit your print jobs all over again.
Next go back to services window and restart the spooler service
That will definitely fix it.
Aug 19, 2009 | Lexmark Office Equipment & Supplies
Docs in queue won't cancel so I can print another document
turn of the printer and unlug the data cable.
go to start>>printer and faxes, open the printer queue and deleted the job.
plug in the data cable and turn on the printer
Jan 29, 2009 | HP LaserJet 1020 Printer
Can't cancel documents in the queue
Hi grt2b1915
go to printer not document selct cancel all while the printer power off.
thanks
Hamedo
Nov 22, 2008 | Office Equipment & Supplies
I want to print new page of printing printer keeps churning out prvious printing instrctions i am 78yrs old still learning
What you need to do is clear out the printing "QUEUE".
Clearing the Print Queue in Windows
The printer is one of the slowest devices in a computer system. If you had to wait for it to print your document before you could resume writing, you would quickly go back to using a typewriter. To eliminate the delay, Windows reserves a portion of memory for something called a “print queue” (or spooler). The queue works on a first-in first-out basis. You can continue to use the computer and send jobs to the spooler as it feeds a steady stream of data to the printer.
Print queues are nice, except when something happens in the printer to cause it to stop functioning. Sometimes it is just a paper jam and sometimes it is a bit more serious. If you need to cancel the jobs in the print queue, you can simply double-click the printer icon (in the system tray down by the clock) and open the print queue. Depending upon the length of your document and how many documents are waiting to print, the printer icon may appear briefly or for a sustained period. (Note: This would be a good time to remove the paper from the printer before continuing.) If the icon is not there, you can manually open the queue.
Open the Print Queue
  • Windows 98 - click Start, Settings, Printers
  • Windows XP - click Start, Printers and Faxes
    or click Start, Control Panel, Printers and Faxes
  • Windows Vista - Start, Control Panel, Hardware and Sound, Printers
Double-click to open the appropriate printer's queue. The Print dialog box will open. Here you will see a list of all of the jobs waiting to print, along with the status of each job. The first print job is at the top of the list.
To cancel a document in the list, right-click it and select Cancel Printing. Most often, it is better to cancel all of the jobs and then resend the documents to the printer.
Cancel All Documents
  • Windows 98 - click Printer on the menu, select “Purge Print Documents”
  • Windows XP - click Printer on the menu, select “Cancel All Documents”
  • Windows Vista - click Printer on the menu, select “Cancel All Documents”
Please note that you must have Administrative rights in Windows XP and Vista to cancel print jobs. If you are the only user, you automatically have administrative rights. If you are on a multi-user computer, you must be an administrator. If are on a network and get a message saying that you do not have Administrative rights, find someone who does.
Under normal circumstances, printing documents are cancelled and will disappear from the queue. If one or more do not disappear, shutdown the computer and restart. When shutting down, you may get a message warning you that your print jobs will be lost if you continue. Tell Windows to shutdown anyway. When you restart, Windows may tell you that you have print jobs waiting. Tell Windows to delete them.
Before you resume work, open the Print Queue from the Start menu. You should find the queue empty. If you are using Windows XP or Windows Vista and the queue is not empty, you will be unable to print. Before trashing your computer, you can try to clear the queue using a secret Windows command.
Click Start, Run, and type “Net Stop Spooler” (without the quotes). Then press Enter. Shutdown the computer and restart. The print jobs should be removed. If they are not, shut down the computer again, take a deep breath, and then go for a long walk. The queue should be clear when you return. Note that you must restart the computer for your printers to resume normal operation.
This should solve your problem, Let me know how it works for you..
~~Jastababe~~
Nov 19, 2008 | Lexmark Office Equipment & Supplies
CAN NOT DELETE A PRINT JOB
Right click your default printer & click OPEN. Now right click on document , select delete/cancel documents.
If this does not solve your problem reinstall the printer, usually this will solve it.
Oct 26, 2008 | Office Equipment & Supplies
Unable to clear printer queue
I had a related problem. Couldn't delete a job from the queue nohow. I wound up deleting various processes (CTRL ALT DEL PROCESSES tab) and it cleared it.
Mar 01, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
