Question about RCA P52960 52" Rear Projection Television
The picture is blurry and looks 3-D. - RCA P52960 52" Rear Projection Television
    Top Expert:
  • RCA Master
  • 14,553 Answers
Look on back where model number is, there should be a chassis number like ptk195
If it is a 195 I know what is wrong. That set (many versions) has a small board that provides power for the convergence circuit--it that board is there it will be easy fix.
attached photo of convergence problem.
LET ME KNOW IF PTK195 ON BACK OF SET AND if this information helped you rate this solution as very helpful as I do this here for free.
SD TECH
Posted on Aug 22, 2010
Panasonic hgtv 1080i blurry screen
The blurriness is caused by the picture tube itself. If you were to look into the light that you covered up, not recommended because it is very bright and could hurt your eyes, it would look blurry compared to the others. The picture tube would have to be replaced about cost about $400 or more to replace
May 05, 2017 | Cars & Trucks
Some of my pictures are blurry using a cannon rebel 3. how can i fix this problem?
There are several possible causes for blurry pictures.
1) Camera motion. If everything is blurry, it's most likely because the camera moved while the picture was being taken. Make sure your shutter speed is fast enough if you're handholding the camera (longer lenses require faster shutter speed). Alternatively, put your camera on a stable surface, such as a tripod or a tabletop.
2) Subject motion. If the subject is blurry but the background is sharper, then the subject may have moved while the picture was being taken. Use a faster shutter speed. Raise the ISO if needed. There are limits, of course. If you're trying to photograph a fast-moving object in the dark, you probably won't be able to.
3) Improper focus. If the subject is blurry but something else in the picture is sharp, then the camera probably focused on the wrong object. Move the focus selector to the subject you want in focus. Alternatively, center the viewfinder on the subject, press the shutter button halfway to lock focus, then reframe and shoot.
Without any more specific information as to what and how your pictures are blurry, I'm afraid the above is all I can give you.
Jan 13, 2012 | Canon Cameras
THE PICTURE GET BLURRY FOR A FEW SECOND THEN GOES BACK TO REGULAR..IT IS A 55 INCH MITSUBISHI TV REAR PROJECTION...IS TIS EXPENSIVE TO FIX?
Yes,the shop will cost u $300 for parts and labors. Convergence problems,the 2 convergence ICS it well die,just not dead yet.Problems will be blurry,color misalign,3 D look,when the 2 convergence is dead.
Feb 06, 2010 | Televison & Video
Blurry and colors are seperated red green white
if you are viewing from a projection tv, chances are you have to go thru the menu of the tv to 'picture tuning'. here it gives you different things that could be fixed. one to look for is 'lamp alignment'. It should show all the colors and lines with directions to bring them into focus. This should fix the blurriness and 3-d red/green/white separations. hope this helps you!
Aug 16, 2009 | Philips Magnavox 51MP392H Rear Projection...
Blurry picture
Try adjusting the focus ring around the lens. Poor quality try adjusting room lighting or you may need to upgrade to a better webcam.
Jun 09, 2009 | Logitech 961462-0403 Webcam
Zenith Blurry Picture
i got a zenith tv and the picture is really blurry how do i focus it ?
Feb 02, 2008 | Zenith R57W46 57" Rear Projection...
Pictures are blurry
Maybe you have the camera set to a slow shutter speed. Try putting it on Program mode.
Oct 18, 2007 | Photography
Sony TV with blurry picture
blurry picture is mainly due to focusing voltage is not proper. solution 1 check & adjust focus control on flyback. 2 check crt base for loose. 3 wire going to focus control on crt base got disconnected due to foreign materials deposit on it. 4 if tv is old possibility of crt getting weak.
Sep 20, 2007 | Akai CF2791 27" TV
Blurry Vision
What are you looking at on the screen? Before or after the shot? The this point the taking sequence-point camera at scene look in screen blurry image - half press the release - autofocus comes into play- press all the way picture takes.Sharp picture in the taken images what are you doing?
Sep 08, 2007 | Sony Cyber-shot DSC-W30 Digital Camera
Samsung Projection HDTV BLURRY!
Each projection set has focus controls in back, usually they don't move or go out of focus unless someone moves it, but in your case if you open the back you will see a focus block with 6 knobs 3 are for screen,I would highly recommend that you don't move this. Look for the focus and you will have to set each with the one color. Cover the other two and adjust.
Sep 07, 2007 | Toshiba 36A40 36" TV
RCA P52960 52" Rear Projection Television Logo
83 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
