Question about Dryers
Have a kenmore dryer model 110.66912692. Wife was using it for multiple loads today and then it stopped working. You can hear the timer ticking, and the push to start button makes a click noise like it was telling the dryer to start again. Opening and closing the dryer door cause the normal push to start button needing to be activated again, but still no drum turning and no heat. Check circuit breaker box and it was OK. Pulled panel off and by-pass thermal fuse, but dryer won't come on.
  • Dryers Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Aug 22, 2010
Kenmore dryer stopped working
check the door switch
Jul 30, 2015 | Kenmore Dryers
Kenmore washer model 110 82781800 won't cylce, just hear timer ticking
If the motor is going thru cycles and the agitator doesn't move, than it means the drive link snapped. cheap repair. it was made to protect the motor and trans. Read the manual before doing this. it will show you how to do it easily. iv'e done mine around 4 times. my wife keeps jamming too many clothes into the thing.
good luck
Apr 10, 2014 | Kenmore Washing Machines
My kenmore dryer just stopped working. the timer
the timer has internal cog teeth with works with an ecentric cam to keep the timer operating. the cam is working if ticking although a tooth appears to be broken keeping the timer to advance on its own
Mar 13, 2010 | Kenmore 63942 Dryer
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
Dryer stopped working
  • first step, turn your circuit breaker off then back on.
  •  it is common for 220v appliances to trip only one side of the dual breaker resulting in a non-working machine that still seems to have power.
  • another symptom of this would be running with no heat.
if this does not solve your problem, don't give up. there is a couple other things it could be (E.g. door switch). just let me know
Jul 01, 2008 | Kenmore Dryers
Kenmore Electric Dryer Model 68731
does the dryer have a gray back panel if it does then take it off the fuse may be bad its a small 1 in in diamiter white with 2 wires going to it replace it if the dryer has a front bottom panel in front then it is in there fuse is bad that is your problem
Aug 18, 2007 | Kenmore 659 Electric Dryer
Dryers Logo
173 people viewed this question
Top Dryers Experts
