Question about Whirlpool LGV4634JQ Gas Dryer
Whirlpool gas dryer
Dryer lights when it first turns on but then it won't relight.
  • pmpkinhead Jun 04, 2008
    Same as aricbrady's problem, the burner does a cycle like normal. Then the flame goes out. The hot surface igniter comes back on after a minute or so, no flame, and the HSI goes back out. It retries every few minutes. I have removed the back cover and throughly cleaned it out and then replaced all of the exhaust piping.
I had the same problem only a few weeks ago.
Read from other forums and found the most common solution: "replace the gas-valve coils."
I ordered the parts, replaced and found that IT WORKS!!
I hope that helps.
Posted on Aug 27, 2008
I have a Whirlpool gas dryer, I can see through the hole that the piolet light is not lit. Model #LGR7646EQ3. It is not heating to dry clothes, can I just try & relight the pilot light?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 28, 2011 | Whirlpool Dryers
My Hotpoint gas dryer won't relight after it has
Your gas valve electrical coils have gone bad. They are easy to replace.
Jun 21, 2011 | Hotpoint Dryers
Whirlpool LGN2000JQ2 Dryer will initially light and reach temp normaly, then it will not relight just continue tumbling. Shut off dryer wait a few minutes and restart
I am assuming that it is a gas dryer even though it shows it is an electric. This is a good website
http://www.applianceaid.com/gas_dryer.html#noheat
Dec 02, 2010 | Whirlpool LER8648P Electric Dryer
Old maytag gas dryer. Does not heat anymore, gas
Maytag dryer series 05. How do I light the pilot?
Apr 04, 2010 | Maytag Dryers
How do I relight the pilot light?
There is no pilot light on many of the dryers of today. They light with a hot surface ignitor.
Here is a tip that I wrote about dryers and no heat on gas dryers...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Apr 01, 2010 | Kenmore 72802 Gas Dryer
Have a Whirlpool Gas Dryer - model # lgr7646a spins but no heat
Thre is no pilot light. This dryer uses an ignitor (glow bar or coil).
Open the lower front "door" (small access door) and turn on dryer.
If the ignitor does not glow (bright orange), then the ignitor needs to be replaced ($60).
If it does glow, then the gas valve needs replacement ($60).
If it isd the valve, the internal spring is stuck. Do not try to repair it, you must replace it.
Sep 25, 2009 | Whirlpool Dryers
Gas dryer burner cuts off after a few minutes of use
Your gas solenoid coils are bad. Replacing them will solve your problem.
May 17, 2009 | Whirlpool Dryers
Whirlpool LGV4634JQ Gas Dryer Logo
52 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
