Question about Dishwashers
I wash dishes before i put them in the dishwasher and have to wash them again when i get them out. It also seems that the dishwashing liquid/powder doesn't desolve completely
  • 139 Answers
Check for debri in the wash arms .the wash arm should spin freely
Posted on Aug 22, 2010
Dishes come out feeling gritty. Using Finish doesn't help
If you open the door immediately after the dishes are washed, and before the "dry" cycle, is the water hot enough to have "steam" coming out of the machine?
You should be able to feel the heat.
If not, perhaps the water is not getting hot enough to dissolve the dishwashing powder.
Could you try using a liquid soap once and see what happens?
Be blessed.
Feb 17, 2013 | LG Dishwashers
Keep getting a white film on all my dishes, not cleaning properly.
Check the temperature of the water. Should be 120 deg. Also are you using powder or liquid? Liquid dissolved a lot quicker that powder. So liquid is actually better to use. Try running the hot water at the sink until it gets hot before running the dishwasher. Also you may want to try mixing half cascade liquid and half lemon shine.
Nov 14, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
My dishwasher (model # DU81ODWGU1) is leaking water and suds during the wash cycle. I ran out of dishwasher powder so I had used regular dish soap for this cycle. Did this cause the problem? My...
MOST DEFINITLY You can put regular dish washing liquid in a dishwasher will do that every time take a few washings to stop run 2-3 times empty it will stop.
May 06, 2011 | Whirlpool Dishwashers
Spots are left on the dishes after washing. Dishes don't look clean
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Nov 26, 2010 | Kenmore Washing Machines
Frigidaire Dishwasher problem
The problem is hard water. There is a new product out called the dishwasher2_bing.gif filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Jun 13, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Dirty cups and baby bottles after dishwasher has been run
Hi and welcome to FixYa I am Kelly. One of the biggest causes of the symptom you describe is that there is a partial blockage of the drain. The blockage areas are most often in the "Air Gap" A device that looks like an inverted 5 oz Dixie cup on the back of the sink with no cone shape. Food particles collect in the very top of that and slow down the drain process. Because of that the dishwasher doesn't completely drain between cycles. So what you get is recycled previous cycle water in the rinse.
Other places where blockages occur are at the garbage disposal side inlet hole. And the last place is under the wash arm tower / mini riser in the pump impeller outlet area. To clean under the lower wash arm riser it requires diassembly and a good memory of how everything came apart / goes back together when your done cleaning.
Apr 18, 2010 | Kenmore 24 in. 17032 Built-in Dishwasher
Used dish washing liquid dishwasher damaged?
Hello- NO- Use about 1 gal warm water to: 1- fill bottom of tub. 2- turn on briefly- 5sec - 3- Push Drain button. 4- Press cancel. ---- Repeat. Let me know if this info helps. -ED
Mar 04, 2010 | Fisher and Paykel Dishwashers
Chalky residue left on dishes
hi,
The chalky residue would have formed due to the washing liquid or powder used. According to my experience, I am happy with "Amway -Dishwasher liquid".Please try it for washing your dishes. It leaves no residues and even cleans your dishwasher. On continuous usage, you may find the difference. Overall, it cleans your dishes as well as washer simultaneously. Though its a bit expensive, it is worth buying it.
please search in "ebay" for your country to get the product. Please rate my solution as helpful. Regards, Venu.
Feb 18, 2010 | Frigidaire 24 in. FDB635RF Built-in...
There is soap left at the end of a cycle from the dispenser. It is trailing down the door and standing in a puddle at the bottom of the dishwasher. The soap that is not in the trap door seems to wash...
Try different detergent types--liquid instead of powder, capsules instead of liquid. Don't put large dishes near the door that might block spray. Check the spray holes in the spray arms for blocking.
Sep 18, 2009 | GE 25 in. Nautilus GSC3400J Free-standing...
Soap foam left after dishes are washes. can't dry properly. and always has soapy water left in it and on the washed plates.
Try adding some liquid fabric softener to your dishwasher. This will reduce the foaming. Also make sure there is rinse agent in the proper dispenser, this will reduce the soap sticking to the dishes. Finally, reduce the amount of dishwasher powder or liquid you put in for each wash. If water remains in the bottom of the dishwasher, check if there is a filter or drain hose clogged. Is the dishwasher drain hose connected an undersink garbage disposer? If yes, make sure it is run periodically so it does not clog up.
Aug 09, 2008 | Dishwashers
Dishwashers Logo
47 people viewed this question
Top Dishwashers Experts
