Question about Acer Aspire 3610 Notebook
How to take computer out of hybernation? - Acer Aspire 3610 Notebook
    Scholar:
  • 183 Answers
Normally tap the space bar.
If that doesn't work, hold the power button down for 10 secs until the machine powers down, then start up normally.
Posted on Aug 22, 2010
My dell says hybernating while on and hang
Hybernation is a power saving feature in microsoft windows. Often times this will cause the computer to freeze.
One solution is to disable hybernation in the power settings located inside the control panel.
On windows vista / 7 you can do this by clicking on the start button (lower left hand corner of the screen)
Then going to "Control Panel"
At the top right of the screen should be a search box, simply type "Power" Into this box and options to edit / change the power plan should appear. Choose edit power plan,
Make sure any options pertaining to hybernation are disabled, You can also adjust when the screen and hard drive shut off during inactivity. For desktops it is recommended to set all options to "Never"
Once finished click the "Save Settings" Button. and you are all set.
You can adjust these settings as much as needed, they can always be undone.
On windows 8 you can access the control panel by moving the mouse to the upper right hand corner of the screen and choosing "Settings" or "Computer Settings" the same procedures apply after this step.
Nov 20, 2014 | Computers & Internet
How do I get my lnspiron 1545 out of hybernation
On most computers, you can resume working by pressing your computer's power button. However, not all computers are the same. You might be able to wake your computer by pressing any key on the keyboard, clicking a mouse button, or opening the lid on a laptop. Check the documentation that came with your computer or go to the manufacturer's website.
Sep 12, 2014 | Dell Inspiron 15 Laptop
Beeping 3 times startup
It really depends on what make or model as they seem to have different methods to get out of hybernation mode.
Dec 30, 2013 | Computers & Internet
My emachine isn't starting up after hybernation, unless i press the power button and reboot. Why is this?
When your system goes to hybernation it creates a file on the root drive called hyberfil.sys in most instances this file gets corrupted and is causing the computer not to wake up from hybernation.
You would have to try and delete this file so that it will re enable the normal hybernation wake of your computer, here's how to do it:
http://helpdeskgeek.com/windows-7/windows-7-delete-hibernation-file-hiberfil-sys/
Just have to reverse the process to re-enable hybernation.
My recommendation would be to just disable Hybernation and just let the computer go to sleep if you're going to leave it idle.
Hope this helps!
Aug 03, 2011 | E-Machines eMachines Desktop PC
SCREEN GETS STUCK IN HIBERNATION MODE
To disable Hybernation try:
right click on empty space of the screen
select property
select the tab "Screen saver"
click the button power on the right bottom
another window will pop out
select the tab "power option properties"
uncheck the checkbox "enable hybernation when it is checked
Mar 09, 2011 | LG Flatron L1750S 17" LCD Monitor
How to open when computer is hybernated
as you start it normally-just press the power button and you are done
Dec 09, 2010 | Acer Aspire 4730-4947 Notebook
Gone into hibernation - can I retrieve
When your laptop goes into hybernation, all files are saved as they were. As soon as you re-start your computer, it will open all files and programs as they were before hybernation started, so YES, you can retrieve everything as it was before.
be sure the computer ios plugged into a charger, to be sure the batteries are charged.
Please, let me know how it goes.
Alex
Mar 21, 2010 | Computers & Internet
What would cause your power button light on the monitor keep blinking and the screen is black and you have trouble getting the light to stay on and get the picture back on. what is the problem. thanks,...
If the button on monitor is blinking, it means your computer is either turned off or in standby mode (or in hybernation).
You should push the power button on your computer to restore it from standby (or hybernation).
Aug 09, 2009 | Acer Computers & Internet
When waking from hybernation - woulnd't boot for 2 minutes
Hello ccc9294,
The system may be trying to restore the browser last settings (including tabs) when resuming from hybernation. Try closing the browser before going into hybernation. Then check to see how long the system takes to resume from hybernation.
If the system still takes too long then look at task manager (Control+Alt+Delete keys). Check the processes to see which ones may be taking up too much cpu or memory resources. It may be a system security application like McAfee or Symantec working in the backgound while coming out of hybernation.
I thank you for giving a rating to this solution if it has been helpful.
Have a great day,
martyshaw562
Jul 27, 2009 | Fujitsu Siemens LifeBook S7010D Notebook
Random Hibernation
this sounds like power settings options.
what i can suggest now is that......................
go to the Power Options in the Control Panel and do the following.
  • first uncheck the hibernate option on the hibernate tab
  • use your computer and see if the problem re-appears, go to the control panel and on the power option, select Never to all options when using battery or ac power.
cheers...............
Oct 24, 2007 | Sony VAIO VGN-N130G/W Notebook
Acer Aspire 3610 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
