Question about Vacuums
Ran over a blanket that stopped the roller from turning. imediately I stut off switch and removed blanket (6" long wrapped inside, not a lot). After restarting the roller will not turn, and belt is in tact, cleaned everything, but not working, please help or my wife will leave now and get a new one.
  • 139 Answers
The belt is off the shaft of the motor.. take off bottom of vac.. belt around the motor shaft then the beater bar put the beater bar back into slots .their should be tension on the belt ,if not the belt is stretched get another one
Posted on Aug 22, 2010
Roller not spinning
Possible belt broken. If you smell an odor like burning rubber it could be the belt that turns the roller if not the belt could be broken already.Possible string or something else wrapped around roller. If you have animals in home they shed and the hair or fur gets wrapped around roller and it will stop the roller.
Mar 06, 2012 | Vacuums
Beater bar not turning
The number one cause of the "beater bar" (or brush roller) not rotating is a broken belt.
The number two cause of brushes not rotating is that something is jammed & wound around the roller, preventing it from rotating.
For the belt: If you remove the screws holding the bottom plate, you should see one (or maybe two) short, wide rubber belt(s) that goes around the roller.
If this is broken, it's easy to replace. They do break because of age and wear. One of the leading causes of breakage is when the roller gets something - a curtain cord, for example - wrapped around it. If you don't immediately shut off the vacuum & remove the cord, the belt will continue to try to turn the roller (which can't turn), and this generates a lot of heat in just a few seconds.
You can find belts at places like Sears, Home Depot, or your local vacuum shop.
For just the roller: Turn the vacuum over on its side and inspect the roller. Will it turn? Can you see something wound around it that's jamming it? While you here, take a minute and clean the roller... including using scissors or a knife to snip & remove wound hairs & threads. A clean and healthy roller will help to keep your belt happy!
Mar 03, 2011 | Cirrus CR99 Bagged Upright Vacuum
Our brush doesn't rotate anymore on our U5402-900 vacuum cleaner. What are common causes of this?
The number one cause of brushes not rotating is a broken belt. If you remove the four screws holding the bottom plate, you'll see a short, wide rubber belt that goes around the roller.
The number two cause of brushes not rotating is, as suggested above, something jammed & wound around the roller. It's always a good idea to turn the vacuum over periodically and clean the roller... including using scissors or a knife to snip & remove wound hairs & threads. A clean and healthy roller will help to keep your belt happy!
Mar 03, 2011 | Hoover Vacuums
Our floor brush does not work, any help please
Hi, I wrote the following tip for someone very late last night.I don't know if they ever saw it, so here it is just for you. I hope it helps.
This problem is most often caused by a broken brush roller belt. Sometimes, although very rarely, there is a separate motor which turns the brush, or there may be something that is causing brush roller to bind so that a belt does not last long. I don't know what your situation is but I'll give it my best shot. Lets just assume the most common problem (97% of the time) and that it is a broken belt,
FIRST: UNPLUG THE VACUUM CLEANER. Write down the model number of the machine so that you have it with you when you purchase a new belt.
Set up an area to work and lay down newspapers to do this job as it can be messy. Or, of course, if you do it on the carpet, you can vacuum it up when your finished
Normally to remove the brush roller and install a new belt most vacuums will have some way to gain access. Either there are:
a) Screws on the top of the roller sections that if you remove them you can tip the cover up so that you can remove it. Sometimes there are cosmetic caps over where the screws are. or
b) Screws on the bottom of the roller section so that you can remove them, then a cover, and then the brush roller itself.
When you have the roller exposed, remove it carefully and take note to observe the parts and how they are oriented. This will help with the reassembly process. Often the brush roller is a simple one piece unit, but it pays to keep track of your work.
1 Remove the broken belt.
2 Remove the brush roller.
3 If there are any carpet strands wrapped around the roller, remove or unwind them. If there is material that is causing the roller to bind which is caught in the ends of the roller, of course, remove them as well.
4 Reinstall the roller with the belt loosely wrapped around it so that the other end of it can be put around the motor shaft that turns it. This step may be harder than it looks and you may need a lot of strength to wrap the belt around that shaft. It depends on the design of the unit. Sometimes it is alternately easier to put the belt around the shaft first and then put the roller into position.
5 Once the roller and belt are in their final positions, Re-assemble.
6 Before plugging the vacuum cleaner in, Check to see that the Roller will turn without binding.
You will need to use some force because you are turning the roller itself and the motor via the belt. So it does not need to turn easily but it should not be stuck. If it is stuck, for any reason, when you turn the vacuum cleaner on you will burn up the new belt with plenty of smoke
to make things exciting and stink up the house.
7 If the belt is not binding then plug the cleaner in and test it.
All should be well,
Hope this helps,
Best Regards,
Mark
Jan 16, 2011 | Bissell 3750 Lift Off Bagless Upright...
Motor runs vacuum has suction on attachment but brushes won't Rotate
FIRST: UNPLUG THE VACUUM CLEANER. Write down the model number of the machine so that you make have it with you when you purchase a new belt.
All should be well,
Hope this helps,
Best Regards,
Mark
Jan 14, 2011 | Kenmore 31913 Progressive Direct Drive...
It stopped picking up dirt . I cleaned the filter, and the belt isn't broke on it. What do i do
Does the belt spin when you turn the vacuum on? There is likely hair wrapped around a brush or roller, or dirt clogged up inside the nozzle somewhere.
Jun 04, 2010 | Dirt Devil M086700 Vision Bagless Upright...
Ran over a cord. Wrapped around the roller brush.
it was the belt should cost a few dollars at bimart or like ace you can do this by taking rollers out from bottom of vac. u can use a butterknife to unscrew it ull see the belt.
Feb 08, 2010 | Vacuums
I have a wind tunnel vacuun and the roller will not turn
There is only one motor which turns the turbine and brush. Therefore, if the suction from the turbine works check the belt by removing the bottom plate of the vacuum and look for the belt attached to the brush roller or if only a piece of the broken belt is inside the unit. If the belt is attached and intact look for a mechanical switch to turn on and off the brush and make sure it is not on bare floor or off. Look on one of the edges of the brush assembly for the clutch which is attached to the mechanical brush switch with a rod. The clutch will close and open when you move the mechanical switch. If you cannot turn the brush unit by hand you may need to remove some objects such as string or hair from wrapped around the clutch or brush.
Jan 20, 2010 | Vacuums
Roller won't go around after part of a blanket stopped it. the belt is ok. power is ok
Remove the roller by pulling down on one side, note how the belt is attatched so you can re install. you will find, I suspect, that part of the blanket is jamming the roller, hence remove obstruction, and put back together.
If the belt is a type with teeth, ckech that these are not warn down. If so you will have to replace
Dec 04, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Fantom twister wont work light is on
When you say, "just stopped", did the MOTOR stop operating and there's no sound from it at all? Or, is the motor still working or sounds like it does, and it stopped vacumning?
If the MOTOR stopped, most likely there is a short somewhere in the connection at the motor. Think 'repair shop'.
If the motor still runs and there's no VACUMN ACTION, think Roller Brush which operates by virtue of a rubber belt. Turn the machine on its side and turn it ON, keeping FINGERS !AWAY! from the roller area. If the Roller Brush is not moving it may be that the belt has slipped off or is broken or simply too loose to turn the Roller. Also sometimes debris such as strings, long hair, carpet strands/fibers will become wrapped around the roller especially next to the roller bearing/brace points, to the point of binding so tightly that the roller will no longer be able to actually roll which would now prevent it from 'Vacumning' or sweeping dirt and such up into the vortex of the vacumn chamber. In which case, !!UNPLUG!! the machine, use small scissors to cut away the material wrapped around the roller paying particular attention to the brace point areas.
Apr 20, 2009 | Fantom Vacums FM780 Twister 700LX Upright...
Vacuums Logo
48 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
