Question about Sony CDX-GT310 CD Player
Hi. I just need to know what the wires are at the radio. Power, memory,l/F speaker, etc. Thanks a lot! Jerry
  • 10,594 Answers
If you are looking for harness details, click Sony Support to download installation manual for CDX-GT310 that has info of each connecting wires and if thats not what you are asking then let me know in details to provide you info.
Thanks.
Posted on Aug 22, 2010
Need to know from top left to bottom right what each wire goes to on power plug on jensen car stereo model vm9311
Hi Jeff, Thanks for the question. When wiring an aftermarket car stereo I always recommend purchasing a wiring harness that will connect into the vehicles existing harness, Then you only have to worry about connecting each wire to it's color coded counterpart. With that being said, if you do not have the stock harness I can explain the wiring colors to the best of my memory
Red = 12v Memory power
Yellow = 12v Constant power
Black = Ground
Blue/white = Power Amplifier
Blue = Power antenna
Grey = RF speaker (+)
Grey/Black = RF speaker (-)
White = LF speaker (+)
White/Black = LF speaker (-)
Purple = RR speaker (+)
Purple/Black RR speaker (-)
Green = LR speaker (+)
Green/Black = LR speaker (-)
Sometimes there is a dimmer wire also, usually orange or pink I believe
I hope this helps, & Thanks again!
Feb 18, 2014 | Car Audio & Video
I brought a rover mgzr and want to put radio in it but the wires in the loom have had the connectors cut off so i just got the speaker wires and the four wires to power the radio, I know which speaker...
My assumption would be black = earth, red/black = power, purple power antena? green white? start by getting a test lamp put the earth ********, turn ignition on & check all wires for power also test in acc position & off position in case 1 is memory (constant power) once you know which ones are power put the test light in the power & black to check the black is the earth. Once you have + & - & speakers it should work.
Jun 27, 2012 | Cars & Trucks
I need to know what the coloured wires are(which is live,speakers etc) for the radio from the car.Somebody has cut the block off so i just have a load of wires where the radio goes.
black is ground, red is hot, yellow is memory,blue is activation wire for amps or antena ,speakers are green ,gray and white ,and purple negetive and positive wires to each of those colors .
Apr 22, 2011 | 2001 Daewoo Lanos
2004 sunfire ignition key wire does it have one/ instaling new radio only have constanyt 12 volt radio power on off button does not shut off do i use this wire and where does it go the ignition wire...
Hi, your factory Sunfire wire colors are pasted below. The yellow wire should be accessory. This should connect to the stereo's red power wire. The orange "always hot" wire should connect to the stereo yellow wire--this is only used to keep your station presets in memory. Please let me know if you have more questions, and thanks for using FixYa.
2004 Pontiac Sunfire Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Apr 04, 2011 | 2004 Pontiac Sunfire
When power is off radio loses memory what can i do to put power to memory please sendai cd 789
Hi, the aftermarket head unit should have a red wire for memory. This wire needs to connect to your factory hot lead wire. If you're not sure which one that is, tell me your car model and year so I can look it up for you. Thanks for using FixYa.
Jan 01, 2011 | Car Audio & Video
How many wires do you need to install rodio in truck ?
Let's see.. (1) Power (switched with ignition), (1) Power (always on to hold memory & time), (8) Speaker (2 wires per speaker), Antenna (coaxial cable). Now, the two power can be always on, but you'll have to remember to shut the radio off before you get out. You could have the radio power from a switched power source, but the clock will be wrong and all the station presets will be wiped outwhen the truck is shut off (no biggie if you're only going to listen to the CD player). You could get away with 4 speaker wires - one pair for the left speaker and one pair for the right speaker. The antenna is a must - unless you're planning on listening only to the CD player.
The rest, are optional. The power output lead is handy to turn on any external amplifier or to raise and lower a power antenna. If using an amp, you might want to use phono cables to send line level audio signals to it instead of using the speaker wires to do that - maybe use the speaker wires to drive dashboard speakers directly and use the amp to drive rear or door speakers.
In any case, I'd recommend purchasing a vehicle specific wiring harness. This will allow you to simply unplug your factory radio from the vehicle wiring. After you wire the new harness to the aftermarket radio, simply plug it into the vehicle wiring as if it were a factory radio. Easy as pie. Not cutting connectors off, crossing wires, etc. Plus, you get to plug your factory radio back in when it's time to sell - and move the aftermarket radio to your new car (after you buy the harness to connect it to the new car anyway). Some vehicles have a data bus that makes the radio an important part of the electronics for sending door chimes, key in ignition signals, etc., and require some pricey harnesses - but they are worth it in the long run. Please take a moment and rate this reply - thanks.
I hope this helps - good luck!
Dec 13, 2010 | Pioneer DEH-P6500 CD Player
My radio in my truck has soped working and I need to install a new radio. However I do not know which wires go to what speakers etc. Can you help me identify which color wires represent the speakers they...
I always would go to bestbuy or walmart to get a harness adapter kit and the radio bezel installation kit to install an aftermarket radio. Just plug it in, and the wires are all labeled for speakers, antenna, power, etc.
Nov 10, 2010 | 1996 Chevrolet Cavalier
Yellow wire from battery to radio no power?
Hi Excavator,
Normally both Red and Yellow on the radio need +12VDC (with Black Grounded).
One is supposed to be switched, the other constant (for clock, memory, etc). I've been hooking 'em both to constant power for so long I forgot which is which
Best regards,
Aug 14, 2010 | Car Audio & Video
Hi,i have just brought a 1989 bedford camper and wanted to fit my sony cd player to it but have no idea how to start...old radio seems to only have two wires going to it (and ariel)but cd player seems to...
Usually a car stereo will have at least 11 wires and sometimes more, the basics are Power (red) Ground (usually black/sometimes brown), constant/memory (usually yellow) and the speaker pairs, gray pair, white pair, purple pair, and green pair. There may be a blue wire for the amplifier trigger, but you don't need to concern yourself with it unless you are installing an amp.
Let us know what your configuration is as for speakers and such and we may be able to be of more assistance.
Sep 11, 2009 | Buck Chevy Express Van Fullsize 01 Radio...
Wiring a new radio in 1991 ford explorer
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
Feb 08, 2008 | JVC KD-G230 CD Player
Sony CDX-GT310 CD Player Logo
195 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
