Question about Maytag Neptune MDE5500AY Electric Dryer
Drum paddle loose how do i tighten it - Maytag Neptune MDE5500AY Electric Dryer
  • Maytag Master
  • 3,053 Answers
Hello, solson I was trying to help you out here. I wasgoing back to some customers that asked questions in the past and it appearedthat no one answered them, so I thought I would take some of my personal timeto see if I can help. Here is a link to about everything you want to know aboutyour dryer, from repair to trouble shooting it. If you go to this link andclick around, I am sure you will find out so much about your dryer, you willknow more that the company that made it. Here Is the link for you to click onhttp://home.howstuffworks.com/how-to-repair-a-dryer.htmPlease if this helped you at all, if youcan find the time to rate my help and some kind words written would beappreciated for my free help , I would appreciate it. Here is also my direct link to my own pagesof other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike http://beta.fixya.com/users/mc1bean
Posted on Oct 26, 2011
The paddle is not off but loose on Maytag neptune model mde4000ayw dryer, how do you make a repair on it.
you need to remove the drum, and tighten the paddle,, look on this site on how to remove the drum http://repair2000.com/wpoolbelt.htm
May 29, 2011 | Dryers
The drum paddles have came loose from the machine
Have all drum paddles come loose? Generally there is one anchor bolt accesed through on of the paddle holes, usually the third from the front. Press down and away from you towards the back of the machine and tighten the bolt
The paddles have slots on there underside and coresponding hooks on the drum of the machine, hence the "push down and away" action to hook up the paddles.
Hope this helps
Duncan
Mar 04, 2011 | Whirlpool Washing Machines
Maytag dryer blade inside of the drum
Is blade loose or broken off? Either way, you must remove front panel (door panel) to expose the front drum end retainer brackets, which you must unscrew and remove to get at screws to tighten or replace missing paddle blade. You can get replacement part at www.repairclinic.com their very reasonable
Feb 13, 2011 | Maytag PYE2300AY Electric Dryer
Paddle in drum is loose at back of drum screw is loose how do i access to tighten ?
You need to get at the outside of the drum to reach those screws. You don't give a brand, but if it's a Whirlpool-made dryer (many are, like the Sears models), this page can help. It shows how to change a belt, and the first few steps explain how to open the machine to get at the drum.
Good luck with the repair, and thanks for using Fixya!
Mar 02, 2010 | Dryers
Loose paddle
Pop the top ... remove the front ... carefully remove the belt ... take the drumout - you are correct, the paddles are held onwith screws - tighten them.
reassemble
Oct 19, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Paddle inside dryer came loose how do we tighten
You have to open up the dryer to expose the clothes drum. Most paddles are fastened by two or three 1/4" sheet metal screws. Look for your lost screw in the dryer or replace it with the same. Use a drop or two of lock-tite to keep screws in place. Good time also to clean out all lint which can become a fire hazard, replace the drum belt and redo all of the screws.
Oct 15, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore Elite Dryer with loose paddle- can I glue?
Unplug the dryer.
Remove the lint filter.
Remove the screws at the lint filter opening.
Pop the lid clips on the left and right front corners of the cabinet.
Rotate the drum counterclockwise until a tumble vane(paddle) is at the 12 o'clock position.
Tighten the screws going through the drum.
Repeat this for the other 2 vanes.
Re-assemble the dryer.
May 10, 2009 | Whirlpool LEB6300 Electric Dryer
Fin / paddle has come loose in the drum.
The paddles are the plastic things inside the metal drum. they are held in by tabs that slide into slots in the drum and a metal tab from the drum flips over a ledge underneath the paddle.
if its loose you may need to replace it, they are available as a spare part and come with instructions. you will need to varify which version you have by counting the bumps on the end of the padle, should be 2 or 3.
basically you put a small screwdriver down on of the holes in the top of the paddle, i think the 3rd one, to push the metal drum tab down enough to be able to pull the paddle towards you and out of it's slots. carefull not to push the tab down too far as it will bend inside the drum and isd pain to bend back again.
Any further help, Let me know.
Thanks for using Fixya.
Do rate the solution 'Fixya" if 100% satisfied.
Apr 30, 2009 | Washing Machines
Maytag Atlantis MDE6200AYW loose dryer paddle
You might have to remove the back, then the top, but it looks like the paddles are either held on buy a screw from the outside of the drum or they just have clips that lock them to the drum. Once the back is removed, you should be able to see how the top is held on. I think it is screwed or has clips for the back and then you slide it forward to unlock the front tabs. You can follow this if you don;t get a reply
from someone who has worked on this model#. Hope you get it apart ok and fixed by yourself.
Mar 14, 2009 | Microsoft Windows XP Home Edition
Loose Paddle in the Drum
not the right method, the paddles are the plastic things inside the metal drum. they are held in by tabs that slide into slots in the drum and a metal tab from the drum flips over a ledge underneath the paddle.
Feb 02, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Maytag Neptune MDE5500AY Electric Dryer Logo
48 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
