Question about Jet 3 Ultra Power Chair
Need a battery charger for jet model 2904jt-24 3stage
  • 692 Answers
Check around the neighborhood for others who have chairs. Any 4 amp charger for a wheel chair will work for you. You can try E-bay also. Your provider will wanna charge you a good bit for a new charger so check in the neighborhood first to borrow one until you can get one Hope this helps
Posted on Aug 22, 2010
Need manual for model 2904jt-24
Could it be the Pride Mobility Mobility Jazzy J3 2904JT-24 model?
If so,click on the link below for the manual downloads.
www.pridemobility.com/includes/download.php?f=Owners_Manuals/US_Jazzy/US_Jet_3_om.pdf
Hope it helps.Thanks!
Jan 05, 2012 | Dishwashers
I have a blue jet 3 ultra n i just put 2 new batterys on it and all it will do is flash a red light in the top left corner of the battery light on the joy stick and the horn works but will not move what...
Check your battery wiring on the Jet the wires from the circuit breaker need to connect the positive of the front battery to the negative of the rear battery and the other wires connected to the positive of the rear battery and negative of the front battery putting the batteries in series to generate 24+ volts. If you have a voltmeter before you check the wiring set it to 200 volts dc and plug the leads into the 2 outter holes of the charger port located under the front of the joystick. If your batteries are wired correctly you should be reading 27+ volts without the charger plugged in and your batteries fully charged. If you are only reading 12 volts then the wiring is wrong and needs to be fixed. Leaving the voltmeter in the charger port plug in your charger and you should be reading 27 -30+ volts at the charger port anything less than 24 volts indicates your charger is not charging Hope this helps
May 22, 2011 | Jet 3 Ultra Power Chair
I have a JET Mobility Model 2904JT-24 Battery Charger that I would like to use to charge a 24-V project I'm working on. It's from a Pride Jet 2 HD. Trouble is, I only have the charger (no wheelchair) and...
Blue Positive Brown negative, Yellow with green stripe is additional ground. many people are trying to use the 2904JT charger for a 24 volt charger for other things. I am using mine on an e bike that has 4 12 volt batteries. I charge them 2 at a time and it works well. It only shows voltage when the batteries are partially charged. Some kind of safety feature to keep you from charging a shorted battery. No schematics available, I took my chances and verified the Blue wire is positive. lol Good luck with you project or re wire. : )
Jan 24, 2011 | Pride New Mobility Victory XL 4 Wheel...
Does anyone have a link for the battery charger for a Scooter Store Jet 3 mobility scooter that defines the different light meanings. The scooter is 6 years old but before I purchase new batteries ($112.00...
saying to refer to the manual provided with the charger for a complete indication of these indicators do you happen to have a make or a model number on the charger or the manual? if you dont have the charger manual you may want to try calling this number its the scooter store and they can send you one for your charger and also answer any questions that you have Thanks again
Rick
Call us toll-free at
1-800-391-7237
Dec 19, 2010 | Jet 3 Ultra Power Chair
Had not used the jet for several years and batteries would not charge. replaced batteries and new batteries will not charge, meter will not work or move when jet is plugged in. jet worked with new...
You'll have to get to the battery terminals while they're charging, and then you can measure the charger voltage, if any (around 12 v).
It sounds like your charger is bad, and you can order one from this site:
http://www.monsterscooterparts.com/jet3ultra.html
Good luck, and hope this helps you.
Nov 07, 2010 | Jet 3 Ultra Power Chair
Have 110 ac going in nothing coming out where can i get a charger model 2904JT-24 Automatic 3 stage Battery Charger 4APK@24VDC 60A.HR. Sealed L>A>
Contact a service provider in your area that sells power chairs they shouldn't rape ya for a charger but you should be able to get one for $125.00 or so. You could also find a neighbor that has a chair and borrow their charger it'll work too Hope this helps
Jul 22, 2010 | Jet 3 Ultra Power Chair
Where can I buy a battery charger for my Jet 3 model #2904-24. My batteries will not charge up anymore. Bateries about 2 years old. Email address is horton-cathy@hotmail.com\r\n Thank you James Horton
Hi. Try a google search for your nearest pride dealer.
You would be better advised to get your batteries tested first. It is more likely to be a battery fault.
If you do need a new charger, ask for one of the new pride chargers, as are sold with the Pathrider 130 XL mobility scooter. These chargers are a very good charger. Once the batteries have been fully charged, the charger drops its charge rate to 27.6 volts. This means that you can leave the charger on for days at a time, and not overcharge the batteries.
The older 4 amp chargers maintain the full rate of charge, and do not drop down to the lower charge rate. These chargers should only be used for overnight charging after each use.
Good luck. Neil.
Jun 22, 2010 | Jet 3 Ultra Power Chair
I CANNOT FIND A GUEST CHARGER MODEL 2904JT-24 DO THEY STILL SELL THEM, OR IS THERE ANOTHER MODEL THAT REPLACES THIS ONE
You didn't state what model of power chair or scooter you had but you can use any charger which outputs the same AMP's and has the same connection. Also try South West medical they will sale to the public. Click the link below and you will see the charger you are talking about.
SOUTHWEST MEDICAL
Hope this helps. If my solution worked for you please rate the solution as to help others who may have the same question.
Thanks for using FixYa.com and have a great day.
Flavadave75
Feb 05, 2010 | Pride Mobility Products New Pride Mobility...
Jet 3 Ultra Power Chair Logo
633 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Louis Smith
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
