Question about Bass Pro Boating
Yamaha hpdi 225 2 stroke throttle problems will engage in reverse but not forward
  • 677 Answers
Your gear selector cable may only require a simple adjustment.They can and do stretch.Hope this helps
Posted on Aug 22, 2010
Where is the oil filter for 2 stroke oil on 200 hp hpdi
Hi, Ron for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Yamaha HPDI Oil Filter The Hull Truth Boating and Fishing Forum
http://www.tidalfish.com/forums/showthread.php/250692-HPDI-owners-Cleaning-your-VST-filter
http://www.yamaha-motor.com/assets/service/manuals/1/lit-18626-07-03_1417.pdf
Yamaha Outboard Routine Maintenance Tips by Mark Marine
Jun 23, 2016 | Motorcycles
2010 yamaha 200 hpdi
Have you replaced all three filters under the cowling?
1. Primary Filter (1st one in the Plastic Bowl)
Reference # 12 in "Prim Fuel" Image
2. Screen on the bottom of the Fuel pump-Inside the VST
Reference # 27 in "VST" image
3. Filter between the VST and the HPDI Pump
Reference # 19 in "VST" Image
Number 2 and 3 get overlooked often, and they are pricy, but they do need to be changed.
If that has been done, the problem most likely is in the fuel pumps
Reference # 24 in the "Prim Fuel" image.
The can be tested by removing them from the powerhead, DO NOT remove the fuel lines, just unbolt them from their mounting leaving the fuel lines attached. Then squeeze the primer bulb until firm. If fuel leaks from the center hole on the fuel pump, Replace them both.
e87e836d-4c03-41b2-984e-2496eb73ed3c.jpg 7cff4158-0f6c-4620-803c-7841ea37bc6a.jpg
Jul 07, 2014 | Boating
Yamaha 200HP, HPDI lifts out of the water when shifting
sounds like something got put together backward . most motors will lift when put in reverse if not locked down . this is to prevent getting swamped by the rush of water going backward .
Mar 13, 2010 | Boating
I have a 2003 yamaha kodiak ATV, reverese indicator light stays
MAKE SURE THAT FORWARD AND REVERSE ARE FULLY ENGAGEING AND DISENGAGING
Jan 18, 2010 | 2003 Yamaha YZ 450 F
I have a Yamaha TTR 225 4 stroke that is having issues starting
Carba/f ratio needs adjusting and use of the choke will help keep the idle circuits clean.
Nov 12, 2009 | 2003 Yamaha YZ 250
Hello, I have two yamaha 300 hpdi 2-strokes and the left one keeps dropping out to 2000rpms when im at wide open throttle for a while i have checked for faults in the ecu but none have been recorded and i...
Possible a pinched line...also run with cowling off to try to get it to stop. If it fixes it then you have an exhaust leak under the cowling that is choking it out.
Jul 31, 2009 | Boating
4 stroke Yamaha 50HP -Runs rough at all throttle levels
If it has the old points system you will need to set the points also adjust the carburatior screw the screws all the way in and back out 2 1/2 turns then get it to run turn the air mixture screws till it runs smooth. you want it slightly lean then enrichen it slightly, afterword shut the engine down and look at the plugs if they are gray black they are ok. good luck.
Jul 09, 2009 | RTO Oar Sockets
Boating Logo
128 people viewed this question
Top Bass Pro Boating Experts
ray gallant
choprboz5
vinayghl
Are you a Bass Pro Boating Expert? Answer questions, earn points and help others
