Question about Seth Thomas Thomas The Tank Cranky The Crane
Cranky the crane moter is running, rope does not move....How do you open it up. screws are not standard.
How to fix cranky the crane
Think you mean "ball bearings" and not "cogs"....
If so, traditionally one uses thick grease to hold them in the "bearing cups" on reassembly... Count they are all there... A "magnetic tool" is useful to collect them..
Aug 18, 2014 | Cycling
How to replace steering belt on zero turn toro lawn mower
if you mean a drive belt (not a mower belt) then im sorry to tell you your gonna need to remove the mower deck , this is only possible with help of a small crane or a stout tree limb and a bit of chain or cable (rope not good enough) , use a breaker bar to move off tension roller and fish belt around pulleys then let tension arm back down (four hands really make this easy) then lower machine back down onto cuter deck and make sure belts and pins line up right
May 16, 2014 | Troy Garden
CCRadio-EP Tuner Knob Spinning and not moving tuner dial
Get a set of screw drivers of different dimensions and shapes and try each one until you find the right one.
Dec 29, 2013 | C. Crane CCRadio-EP AM/FM Radio w/ Lighted...
How do I replace the string on cranky crane
To start, you need a TA27 triangle driver bit to remove the handles. Then pull hard straight up on the top block with the face on it. It will separate from the tower. The rest is straight forward. I have some choice words for the person who designed this thing...
Apr 27, 2012 | Thomas and Friends Deluxe Cranky Crane...
Need Instructions for Thomas and Cranky deluxe set.
Learning Curve (the company that produces the toy) would most likely be more than happy to send you a new set of instructions. Click here to access the Learning Curve customer service form: http://www.learningcurve.com/wps/portal/contactus?locale=en_US
This information will help you fill out the form:
Official item name: Deluxe Sights & Sounds Cranky the Crane
Item Number: LC99271
I hope you have no trouble receiving your new instruction manual!
Aug 01, 2011 | Toys
I pulled the emergency rope on my door opener. How to fix the chain back on the pully?
Pull straight down on the rope and release. Then bring the two halves of the trolley together either by moving the door by hand or running the motor.
May 31, 2010 | Sears Craftsman LiftMaster Chamberlain...
Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener: my garage door unit acts like the gear is stripped...
DOES IT MOVE AT ALL OR JUST RUN??
IS THE ROPE RELEASE PULLED??
IF THE GEARS ARE STRIPPED IT WILL NORMALLY MAKE A GRAVELLY SOUND. AND THE DOOR WILL MOVE BUT NOT LIKE IT SHOUL.
TRY DISCONNECTING THE DOOR FROM THE OPENER & SEE IF THE TRAVELER MOVES NORMALLY.
May 17, 2010 | Chamberlain Powerdrive PD422D 1/2 HP...
Chamberlain powerdrive door opener will not move. moter hums but chain will not move
CHECK TO SEE IF HE TRAVELER IS AGAINST THE BOLT ON THE RAIL. IF IT IS YOU WILL NEED TO LOOSEN THE CHAIN / BELT TO GET IT TO MOVE THEN ADJUST THE TRAVEL LIMIT SO IT GOES UP / DOWN LESS AND DOESN'T HIT THE BOLT.
HOPE THIS HELPS
Jan 10, 2010 | Chamberlain Powerdrive PD422D 1/2 HP...
Seth Thomas Thomas The Tank Cranky The Crane Logo
90 people viewed this question
Top Seth Thomas Toys Experts
ray gallant
Are you a Seth Thomas Toy Expert? Answer questions, earn points and help others
