Question about Dell Inspiron 6000 Notebook
Laptop touchpad insperion 600,defective touchpad
  • abcd_21 Jun 05, 2008
    while using Touch Pad the arrow not responds properly
  • 191 Answers
Run a diagnostics
turn off your system
press and hold Fn key ,power on the system, leave fn key
it will start running a diagnostic
it will give you an option to press any key to continue
press any key and you will get 4 options
express test
custom test
extended test and
symptom tree
choose symptom tree
you will get list of devicec
choose keyboard run test
it will highlight some keys you have to press
if everything works fine here
hardware is working fine
then you have to take the system back to day one or use Operating system cd to reinstall the operating system
if you are in United states call 1-800-624-9896
Posted on Jun 05, 2008
    Problem Solver:
  • 32 Answers
Look for a driver on dell... if that doesnt work then get a new touchpad or send it back to dell and tell them to shove it.
Posted on May 04, 2008
Dell insperion windows 7 turns off and beeps will not turn on for a while
This normally happens when the laptop overheats as it seems to have an inherent heat problem with the Insperion. Normally needs to cool off before poweron attempt is done again
Jan 10, 2014 | Radio Communications
Touch pad not working
It is possible that the micro switch underneath the button is defective. If this is the case, then the laptop ,(if still under warranty),should be returned to the manufacturer for repair. Otherwise, a new motherboard will be required as the micro switches cannot be replaced.
Dec 18, 2013 | Acer Aspire 7520-5185 Laptop
Go device manager
Usually a sign of a defective part.. Most touchpads on the market today will allow you to do a double tap the pad which is the same as clicking the right pad
May 13, 2013 | Samsung Computers & Internet
Dell insperion 5030 screen black and beeping
This POST code means there is a problem with the RAM.
Reseat the RAM and if the Dell still does not boot up then -
If it still does not boot up then could be faulty. Remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Sep 08, 2012 | Dell Computers & Internet
Dell insperion 1545 windows vista home touthpad and right click does not work help
Try plugging in a USB mouse and see if the right click works on that. If so then you probably have a defective right click button on your laptop. You will need to have the "palm rest" (the plastic top portion) replaced.
Feb 08, 2011 | Computers & Internet
When laptop gets hot, touchpad stops working (cursor won't budge)
You have failing components on the motherboard, This needs technical intevention to repair it and pssibly a new motherboard or power supply fitted.
Sometimes its cheaper to ditch an older laptop and get a good second hand one or even a new one from some of the better offers that are around 500-600 than spending money fixing old units
Thanks for using FIXYA
Apr 13, 2010 | Dell F3534 Touchpad
Dell Insperion M1540 Dell wireless broadband card
the side of the computer is usually where it is, it slides up.....
Nov 19, 2009 | Dell Inspiron 6400 Notebook
The touchpad mouse on my toshiba salellite does not function even though it shows it working properly when you go into the touchpad icon. I have an external wireless mouse (usb) hooked up that works fine...
The touchpad is most probably defective. If you have dropped your laptop the touchpad cable could have get out from its connector on the mainboard. You can get a new touchpad/palmrest on ebay. You have to remove your touchpad/palmrest as shown in the link below, steps 17 to 19 :
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
Identify the part number of your touchpad/palmrest. Search on ebay.com : Toshiba Satelitte A105 palmrest. Buy the one with the same part numer as yours.
...or have your laptop repaired by a professional.
Oct 09, 2009 | Toshiba Satellite A105 Notebook
Touch pad is not working in my dell latituse 600
If the touchpad is not working, then ensure that the touchpad is not disabled in the BIOS, in control panel ensure that is is not disabled there either. If the touchpad is not disabled in BIOS or Control Panel, then a palmrest would be required to fix the issue. On a system of that age, I'd just use a wireless mouse till I was ready to replace the system
Jul 03, 2009 | Dell Latitude C600 Notebook
Touchpad not working in HP G70 laptop
if you are technically inclined, you can remove the keyboard and check the cable for the touchpad to see if it has become unseated, if it hasn't, you may need to replace the touchpad, the cable, or the motherboard. This can happen if it has been droppped or jarred, or from a manufacturering defect
Jun 15, 2009 | Computers & Internet
Dell Inspiron 6000 Notebook Logo
786 people viewed this question
Alun Cox
