Question about Nintendo Wii Console
Connecting to internet
I am having trouble connecting to the internet.....i have been able to connect to the internet and it suddenly won't connect
  • 2 more comments
  • aqua12345678 Oct 08, 2008
    i need help getting on the internet on the wii
  • Anonymous Oct 15, 2008
    my internet connection suddenly stoped working how do I fix this?
  • Anonymous Dec 18, 2008
    geting wii to connect to internet
  • Anonymous Feb 06, 2009
    I don't know what the ssid is
I do not know how to conect to the internet.
Posted on Feb 08, 2009
  • 3 Answers
If you have a wii go buy wi-fi usb connector of walmart it about 20.00 put the disc in turn off your firewall too you must do this ture it back on whan you git off line you will be buying games in no time
Posted on Oct 17, 2008
    Scholar:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 38 Answers
If you really can't connect,try to start setting up again the internet settings/connection from scratch.make sure your router is working fine and you haven't changed anything on it including firmware upgrades.your router setting must be such that it's allowed to accept your wii to connect.if your router has either wep or wpa password,this should be the same one you need to key in on your wii internet setting.say you have wpa,most likely you need to select wpa (AES) on your wii internet setting.finish the wii internet set-up,your wii should be able to scan your router's ssid and connect to it.no guarantees,hope this helps.
Posted on May 06, 2008
2 Suggested Answers
spikerman199
  • 26 Answers
SOURCE: Trouble connecting to the internet w/PS3 using an cricket aircard
the best thing for you to do is get a cable and attach it to the internet port. the cricket aircards have a tendency to fail or stop working entirely
Posted on Aug 18, 2009
Internet Explorer 8
Are you using a router? Do you use cable internet? Try connecting directly the cable directly into your netbook. If you have internet access then the issue may be with your router.
Aug 24, 2012 | Samsung Computers & Internet
Use to connect to internet now it won't find it
open control panel through start button
look for wireless icon
click on that and see if it's active
start button
control panel
system
device manager
then look for network adapters see if they are happy(no yellow ? marks)
restart machine try again
May 23, 2012 | Acer Aspire 1410-8414 Netbook
Won't connect to my computer. I've had the printer for about 3 years, and all of a sudden it stopped connecting and i can't get it to connect again.
check printer connections and try again but if still not working go to control panel add and remove click to select program remove HP Photosmart then back to main window, insert the disk and install again driver, follow commands you see on the screen . but first unplug internet connection then exit anti virus before you start installing driver HP Photosmart .good luck
Jul 10, 2011 | HP Photosmart C6280 Printer
My modem keeps dropping connection. I have called my ISP and they say everything is running just fine. It happens when i am playing counter strike source and i start lagging badly and all of the sudden my...
Intermittent connection issues are very difficult for internet service providers to trouble shoot. The first step in trouble shooing any Intermittent connection problem is to look at the chain of equipment involved in flow of data from the internet service provider to the end user. In most homes the packets enter from the main line to the modem, than from the modem to the router, and finally from the router to you computer. So that means that the issue can be caused from the following equipment: main cable line, splitter, modem, router, or the Ethernet / wireless card of the PC. The first step in trouble shooting this problem is to wait for the internet to drop off. As soon at this happens go to your modem. If the top 4 lights are not solid green then the the modem is losing it's connection to the internet. This can be cause by some thing as simple as a bad splitter in the home or some thing as complicated at an issue at the pole. If the modem drops the connection I would recommend contacting the internet service provider and demand a service call to swap the modem and check the pole. Now if when the connection drops the modem still has access than the issue is most likely with the router or PC. If more than one computer loses it's internet access than you can rule out the computer as the issue. At this point I would have to recommend bypassing your router for about 48 hours. If the issue does not return than you know the router was the source of the problem.
I hope that information above has helped is some way.
If possible please rate this solution.
Aug 29, 2010 | Arris SURFboard® SB5101 Cable Modem
Internet connection suddenly shut off
Rather than spending any money/time trying to "trouble-shoot" the router, probably without success,
go buy a brand-new router.
Apr 10, 2010 | Belkin (F5D7230-4) Router (587009)
Wireless Connection Difficulties
sounds like your wireless card in your laptop needs either a replacement, or new drivers.
www.sony.com
May 23, 2008 | Sony VAIO VGN-FJ290P1 Notebook
Computer cannot access the internet
Try to disable wireless card on your desktop. With both the wireless and cat-5 socket enabled, "WITHOUT" the proper bridge settings, they will conflict and not be able to read.
Apr 07, 2008 | Computers & Internet
Nintendo Wii Console Logo
235 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
