Question about GE GSS25LGM Side by Side Refrigerator
Describe your ge refrigerators gs25lgma Problem The icemaker is not working and the is a steady stream of water dripping.
  • laomei892 Aug 22, 2010
    I was able to turn off the water and stop the leaking. Are there any drawings I can refer to in order to check the things that you mentioned to check?
    Although the comment was not in and of itself very useful, it did point me to a site that was, which helped me to solve the problem. I didn't have to wait long for comments, which made the service very worth while to me. Thanks
    President:
  • 1,796 Answers
Hi!!
If your icemaker is leaking water into your ice bucket or onto your floor, several things could be the source of the problem. Check the following items:
  • Be sure the water line fittings are secure.
  • Check the water valve for leaks.
  • See if water is leaking from the fill tube extension.
  • See if the defrost water drain is cracked or overflowing.
  • Check for water on the exterior of the refrigerator case.
  • See if the refrigerator is leveled.
Note: If the icemaker is leaking water onto the floor of your home, turn off the water supply to your icemaker. This line is usually located under the kitchen sink. Locate the cold water line under the sink, and look for a small 1/4" copper line attached to it. Where these two lines meet, there will be a saddle valve. Sticking out from this valve will be a post with a wire running through it. This is the shut-off valve. Turn this valve in a clockwise manner until it stops. This will shut off the water to the icemaker. If the water line is not connected under the sink, it will be in the basement or crawl space.
Keep me posted!!
Posted on Aug 22, 2010
Hotpoint refrigerator leaking water from hose underneath
It sounds like this may be coming from the icemaker water valve. If the refrigerator is an older one the tubing gets brittle and cracks. Check this first. But the water valve is usually on the left side in the back.
Apr 09, 2014 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
GE Profile Icemaker freezing up; water freezes down inside wall of freezer; icemaker making ice, very slowly, but will not dispense. Water is still dispensing
This sounds like your water valve is not completely closing allowing water to drip and freeze. First check to make sure that the water tube going into the cup of the ice maker is lined up correctly and not causing this problem - if it is lined up correctly then replace the water valve on the back of the refrigerator that your main line is connected to.
Jul 01, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Water dispenser in door front is leaking.
The water inlet solenoid is bad. Unplug frige. Follow inlet line to back of frige to part. Replace part.
Nov 04, 2009 | Kenmore Refrigerators
All water underneath.ice in the bottom.freezer working.not making
If I understand you correctly your water line that comes through the back wall of the freezer and into the icemaker is frozen. If so you have a bad water valve. When the valve goes bad it will not seal off the water. It will seep causing a slow drip where the water comes out at you icemaker. It'd slow enough to freez causing a ice blockage. This will not allow water to come through and fill your icemaker when it calls for water.
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker dripping water even in stop position (bar up) and keeps supplying water to device. water dripping from the bottom of the housing unit at a steady rate.
unplug ice maker if you still have water coming in fill valve is stuck on back on the bottom if not more than likly icemaker bad
Jun 26, 2009 | GE Profile 20.7 cu. ft. CustomStyle...
ICEMAKER LEAK ON GE TFX25VR
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the second one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 27, 2009 | GE 25.2 cu. ft. Side-by-Side Refrigerator...
GE PSS23mstcss Icemaker not working
icemaker will need replaced, < only other concern with description is water dripping> would not address this unless problem did not go away after replacing icemaker, < could be leaking water valve>.
Apr 23, 2009 | Refrigerators
Makes ice for three days, water drips to fan, freezing up,
there is a device like a switch that makes the icemaker stops the solenoid valve of the water intake, u should check that switch...
Mar 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
Drips at water dispenser GE PSC23MGSA BB
If it's a constant drip then you need a new water valve.
Jan 03, 2009 | GE Profile Energy Star PSC25MGS Side by...
GE GSS25LGM Side by Side Refrigerator Logo
224 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
