Question about Eureka Whirlwind 4388 Bagless Upright Cyclonic Vacuum
Eureka upright no bag started leaving streaks of dirt behind
  • 139 Answers
Check the hoses or check where the beater bar is. the opening where the hose connects. their is a clogg somewhere in the hoses
Posted on Aug 22, 2010
I have a bravo 2 eureka bagged upright suction is very bad changed bag cleaned roller still bad what should i do next
Replace the belt if it is over a few months old. Even if the suction is great it won't pick up dirt very well if the belt is stretched out.
Oct 28, 2017 | Eureka Vacuums
Not picking up dirt - already changed the vacuum bag
Check the belt. It may be slipping or broken. You can turn the vacuum over and turn it on briefly to make sure the brushes rotate.
If this is not the case, their may be a vacuum leak or something obstructing airflow, which is necessary to create a vacuum to pick up the dirt.
Jul 13, 2011 | Eureka 2270 Bagged Upright Vacuum
Vacuum shoots dirt or whatever it has just vacuumed out the back of the vacuum. I checked and cleaned the filter and the vacuum bag and it still leaves dirt behind the vacuum.
Good morning,
If you've checked both the bag and the filter, the next step would to check for any clogs.
I will detail what you will need to do below, or you can always reference your Owner's Guide (check: How to Check and Clear Hose Blockages)
http://www.eureka.com/service/manuals/77418_r2.pdf
Step 1: Remove hose from hose retainer on the base and check suction at end of hose - if little or no suction, check dust cup. Empty if needed. If no improvement, proceed to step 2.
(Make sure you turn off the switch and unplug the unit before proceeding to step 2)
Step 2: Remove electrical cord from cord hooks. Disconnect the clear tube by unscrewing the 2 screws, then lift away from cleaner. Check for any obstructions that may be in the tube or hose. Any obstructions can be removed by using a blunt instrument to clear the tube or hose (I will sometimes you a bent hanger or a retractable pointer). Flexing the hose may help loosen the blockage. After clearing blockage, reverse above steps to reassemble unitpcfloy86_0.jpg.
I hope this helps. If so, please give this solution a thumbs up!
Have a good day
~PCF
Mar 05, 2011 | Eureka Power Plus 4703D Bagless Upright...
Eureka rm 4480
Hi there SmartAlec from NelsonVacuums.com.au . Unless there is a bad sound coming from your vacuum i would suggest you have a blockage. This machine is prone to getting blockages in 3 different places.
  1. at the base behind the brush.
  2. Inside the main suction hose - this should be removeable so you can drop a small coin through. If it doesnt fall easily viola blockage found.
  3. Where the dirt enteras the chamber or bag.
Basically start by removing all hoses and filters and turn machine on put your hand over all inlet and exit points provided you can feel airflow at one of these points work backwards from there and identify the point at which you no longer feel airflow.
HAPPY vacuuming !
Aug 26, 2009 | Eureka Whirlwind 4480 Upright Vacuum
Eureka 4463 Vacuum blows OUT dirt
sounds like the pipe is stopped up,, you need to take it off and run a rod through it and unclog it,, sometimes small toys ect. can get in pipe stop ot up,, hope this help you,,good luck
Aug 14, 2009 | Eureka Lite 4463 Bagged Upright Vacuum
Something is stuck in my hose on the eureka boss smartvac, can i dtach plastic hose on side
yes, there are a few screws that need to come out to do so, u can also use a coat hanger to loosen it up and turn it on, the vac will **** the loose dirt into the bag/canister
Jul 14, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
My Eureka Lite speed whirlwind has a bad odor when it runs.
It is either the filter or on the roller or belt.
  1. Eureka Parts Storewww.Eurekapartstore.com Unbeatable prices on Eureka Parts Largest site for Eureka parts.
  2. Eureka Partswww.ThinkVacuums.com/Eureka Eureka Central Vacuum Accessories Find Hoses, Tools, Nozzles & More! Google Checkout
  3. Eureka Part Storewww.vacuums24x7.com/Eureka-Parts Bags, Belts, Filters, Repair Parts. Complete Selection Eureka Parts.
Jul 06, 2009 | Eureka WhirlWind Litespeed 5844 Upright...
My eureka 2961avz bagless vacuum has no suction
Usually clogs are in the dirt inlet by the brush roll, or in the hose. Take the hose off from the bottom and see if there is suction, if not, then the hose is clogged. If suction there, then it is lower. Also is the brush roll turning, if not, that could be your problem.
Jun 06, 2008 | Eureka 2961AVZ Bagless Upright Vacuum
Eureka Whirlwind 4388 Bagless Upright Cyclonic Vacuum Logo
128 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
