The motor spins on the belt but the drum won't turn. I took the back off of the machine and tried to spin the drum by it's pulley, no can do. the washer sensors give a motor board problem but the motor is cycling back and forth like it is supposed to do. What gives?
  • 139 Answers
Check the hoses going into the drain pump a small sock or something is in the drain pump causing this ..if the washer drains then its not that .. could be transmission clutch silinoid
Posted on Aug 22, 2010
The belt has come off my hotpoint WMA5 washing machine
offer the belt around the motor pulley first , feed one side of the belt to drum pulley , whilst holding this side to drum pulley turn pulley using other hand , belt should follow natural path onto pulley .
Jan 23, 2013 | Hotpoint Aquarius WMA56 Front Load Washer
Drum won't spin on it's own but spins freely by hand.Was slow to start spinng before. Took front off but can not see belt at all, if it has one?
drive belt is normally accessed from the rear of the machine or if sealed rear from underneath(bottom) the belt is normally easier to get off the drive motor pulley first . Sounds like your belt is either already broken or has come away from drive unit or drum .
Jul 25, 2011 | Maytag MDE508DA Dryer
My kenmore 70 series washing machine wont spin. i took it apart and could see the belt off, but i couldnt figure out how to put it back on
just place the belt over the motor pulley
then get it started over the drum pulley it will stretch on by rotating the drum pulley
Mar 09, 2010 | Washing Machines
Drum does not agitate water goes in and it just humms, no agitation or spin
The drive belt is broken or the motor's rotor is stuck. Open the door and rotate the drum manually. The drive belt is worn or broken if you can freely rotate the drum. The rotor is most probably stuck if you cannot turn the drum.
Visual check can be done by removing the back panel. Remove the screws holding it to the cabinet and pull it off. Replace the belt if it is worn or broken. Simply wrap it around the drive motor pulley and on one side of the drum pulley. Rotate the drum pulley in such a way that the belt completely wraps around it.
Try to free the rotor if it's stuck by lubricating it and forcibly turning it back and forth until it turns freely. To remove the motor, disconnect the motor wiring harness and ground wire from the terminals and remove the mounting bolt. Pull the motor out of the mounting slots. To reinstall or replace, simply slide it back into the mounting slots and secure it with the mounting bolt.
In some cases, the drum will not spin due to a broken drum pulley. Post it back if that is the case.
Feb 07, 2010 | Kenmore 42822 Front Load Washer
The drum does not spin, the blower works, the gas will fire up, belts look to be in tact but may be loose?
Most gas dryers have a tensioner on the drive belt under the drum a metal bar with a teflon pully that is spring loaded to tension the belt. Try spining the drum by hand if it spins freely the belt may have come off the tensioner or it may be streched. If it doesn't turn the drum rollers or bushing may be bad. Without a make and moddel # it's hard to say
Hope this helps
Please leave feedback
Dec 04, 2009 | Dishwashers
DRUM WILL NOT SPIN, BELT IS OK
have you try to rotate the drum when belt is attached or installed, unplug your machine and try to spin it manualy at the back opening where you can access the mechanical part
try to use the belt when turning it counter-clockwise see if it will turn the drum, if not then the fproblem is the bearing
Nov 08, 2009 | Whirlpool LGR6611L Gas Dryer
Replaced broken washer belt, but drum still won't spin.
you may have a bad bearing in a pulley,could be motor coupling. Take belt off and spin motor shaft and pulley both ways if it's free, then its more than likely not the motor. Now spin the drum with belt off and see if it does the same as with the belt on if it does it has to be a bad bearing or coupling to the drum. hope this helps
Aug 24, 2009 | Amana ALW480DA Top Load Washer
Maytag mah4000aww drum wont spin
No - it is likely the key for the pulley that has broken.
You'll need to remove the pulley to see if the keyway is damaged. If so - you'll need to change the motor.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 31, 2009 | Washing Machines
Clothes are still soaking wet after spin cycle and the wash cycle is complete.
If the drum spins in the spin cycle, then the belt can't be broken. However, if the drum does not move at all in wash and spin, then the belt can be broken or just fallen off. You will have to remove the back plate and fit the belt back on the drum pulley and the motor pulley. If belt is ok check the motor brushes, they could be worn. They are located one on either side of the motor and identifiable by a single wire that connects to each one. You could also have a restriction in one of the drain hoses which is not allowing all the water to drain out.
Nov 05, 2007 | Maytag MAH6500 Neptune Front Loading...
Drive belt and noises.
your drum shaft is broken this is making the pulley wobble causing the belt to come off and it will also explain the noise. This is a very expensive job sometimes requiring the complete tub to be changed might be time for a new machine
Jul 30, 2007 | Bosch Classixx WVF 2402 Front Load...
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
