Question about Singer 3116 Simple
The upper thread is not catching correcttly. When it does feed through the bottom corectlly it jams up after about an inch of sewing. It jams up with tons of thread.I have threaded and rethreaded cleand and cleaned it out again and again. I have taken the lower bobbin out and and went through the motions of picking up the bottom thread. The thread is catching somewhere!! I dont know what to do! Please help!!!I
  • Singer Master
  • 7,365 Answers
Check to see if you have your needle in backwards
have you checked your needle to see if it's bent-roll it on a flat surface & see if it rolls good
check to see if the needle is blunt-makes a popping sound when going thru fabric
check to see if the thread is getting caught on the notch of the spool of thread
check to make sure the bobbin is not warped
check to make sure there are no burrs on the bobbin case
check your upper thread tension
Posted on Aug 23, 2010
Machine jammed and now the bobbin wheel will not turn or catch the thread
By jammed do you mean thread jam? Have you removed sew plate and checked under feed dogs and bobbin for tangled thread and lint build up?
Mar 30, 2017 | Sewing Machines
Sews 1/4" and then sews in place
1) remove upper and bottom threads. Try sew without threads.
Is fabric transported corectly?
NO:
- Drop feed dog button is OFF
- Dust under stitch plate
- Transporter malfunction (must be taken for a service to the BERNINA dealer)
YES:
- Upper or bottom thread jammed
- The upper thread tension is too tight.
- Wrong needle used (probably small ...)
Nov 20, 2013 | Bernina Bernette Deco 600
How can I adjust the thread? I have a problem with the thread, when I start the sewing machine the tread from the top and the bottom would suddenly get tangled. Tks.
try this suggestions
check the needle to see if it's bent-roll it on a flat surface to see if it rolls correctly
check the bobbin to see if it's warped
check the bobbin case to see if there's any lint or loose threads
rethread the machine-upper thread & bobbin too---to make sure the thread is not catching on anything
make sure the upper thread has a thread tail 3-4 inches long
make sure the bobbin has a thread tail 3-4 inches long
make sure the bobbin is inserted correctly in the bobbin case
if you have your operation manual-check the tension settings & see if they are correct
Sep 01, 2010 | Singer 2517 Mechanical Sewing Machine
Sewing machine grabs fabric and won't let go
I dont think the top thread spool feed is the problem, I sounds like the upper thread tension is set at too low a number. Normally on that model it should be set at 3 to 6.
May 06, 2010 | Sewing Machines
Machine is not sewing properly
use larger needle, check bobin thread, bobin should go one way, if it bunches up switch dirrection the bobin turns
May 23, 2009 | Bernina Virtuosa 160
Bobbin wont feed
a. needle in backwards
or
b. needle threaded wrong
Apr 24, 2009 | Sewing Machines
Brother 3022 Mechanical Problem
Make sure your needle is in correctly. Check your threading again. If that does not work, remove throat plate, install new needle, turn hand wheel until needle is at its lowest position and observe if the hook is exactly behind the eye of the needle. If that is correct then you do not have threaded correctly. If it is not then the machine needs to be re-timed.
Oct 09, 2007 | White Sewing 2037 Mechanical Sewing...
Bobbin thread won't catch
I've just had this exact problem with my model 2037. The problem, according to 3 shops I've taken mine to, is that the shuttle hook (the metal piece that the bobbin sits in) is broken and needs replaced. Problem is, the piece is next to impossible to find.
Jan 14, 2007 | White Sewing 2037 Mechanical Sewing...
Singer 3116 Simple Logo
114 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
