Question about Jenn-Air Ovens
Jenn-air model svd48600b Fan runs continually and the oven light stays on. only way to stop them is to pull the oven breaker on the electric panel.
  • 3,083 Answers
There are two components that can mess up in this situation, the temperature probe and the PBR (relay board). This web blog describes how to check the temperature probe, and also has information about the relay board:
http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/12231-jenn-air-oven-svd48600b-continuous-fan.html
It may just be the temperature probe, in your case.
Good luck, thanks for using FixYa, and hope this helps.
Posted on Aug 22, 2010
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
Jenn Air W30400 wall oven does not heat.
Turn off the power to the oven.
Remove the racks.
Remove the BAKE element screws and carefully pull the element out.
Remove the wires from the element,being careful not to let the wires fall back into the oven cavity.
Use a volt meter set for continuity and touch the meter leads to the element terminals.
No reading is a bad element.
Replace the element.
If you do get a reading,the electronic control is bad.
Jul 16, 2010 | Jenn-Air Ovens
7 yr old jenn-air wall oven locked shut, shut down
It will remain locked until the temperature is safely as low as it should be. You just have to wait and be patient.
Jan 31, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Vent fan stays on
The fan was on because the griddle element was on. 1/2 of the element was on so 110 volts was on at all times. If I had not been close to the oven and heard the fan I might never have found this problem. I replaced the infinite switch and that solved the problem. I found the model # inside the drip jar door. Problem solved.
Mar 18, 2009 | Jenn-Air JGW8130A Electric Single Oven
Jenn-Air coolimg fan problem
Good Morning!
What youre experiencing could be a result of a faulty oven temperature sensor, a faulty oven control board or relay board. Youre more than welcome to send both the main control board and relay board for evaluation. Fixyourboard will test and repair both as needed for less expensive than buying new, and include a two year warranty.
5700M662 60 Jenn Air OVEN CONTROL BOARD
May 15, 2017 | Jenn-Air JJW8230D Electric Double Oven
F2 fault, continuous fan after clean cycle for Jenn-Air electric convection wall oven. I haved turned off power at breaker and restarted. Fault reoccurs. Oven is definitely cool. It has been 36 hrs...
The "F2" means the oven control senses runaway temperature. The cause of the problem could be the oven sensor, the oven sensor wire harness or the power relay board.
PS:please disconnect your oven from power supply completely before continuing.
Open the control panel and measure the oven sensor resistance at the control board. It suppose to be about 1100 Ohms at the room temperature.
If the reading is wrong do the same test at the oven sensor connection (where the sensor wires goes through the back panel).
If the reading is still wrong - replace the oven sensor.
If the reading is correct, check the wire harness and the connector itself (it's better to eliminate the plastic plug and hardwire the oven sensor).
If there is nothing wrong then the power relay board has to be replaced.
Nov 07, 2008 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air Gas Range SEG196 NO CLOCK/DISPLAY
THE ONLY SOLUTION FOR THE BAD DISPLAY IS TO REPLACE THE CLOCK. I HAVE A JENN AIR OVEN TODAY AS A WORK ORDER TO REPLACE THE CLOCK FOR A FAILED DISPLAY.
FOR THE JGW8130DDB WITH NO POWER ANYWHERE, IT SOUNDS LIKE YOU HAVE A SUPPLY PROBLEM. MAKE SURE THE WIRING IS HOOKED UP WITH THE RED AND WHITE WIRES RECEIVING 240 VOLTS AND THE WHITE WIRE ATTACHED TO NEUTRAL / GROUND.IF THE OVEN HAS A BARE COPPER WIRE AND THE HOUSEHOLD WIRING ONLY HAS THREE WIRES, COMBINE THE WHITE WIRE AND THE COPPER WIRE TOGETHER AND ATTACH TO THE HOUSEHOLD NEUTRAL / GROUND .
UNLESS YOU ARE SURE ABOUT THE HOOKUP IN THE BREAKER/FUSE BOX, DO NOT GO SIMPLY BY THE COLOR OF THE WIRES.
Apr 10, 2008 | Jenn-Air JGW8130A Electric Single Oven
The electrical panel does not light up
I'm afraid you are going to need a new display board. Not very hard to change but a pricey item. Have seen this problem a few times. Good Luck!
Oct 05, 2006 | Jenn-Air WW30430P Stainless Steel Electric...
Ovens Logo
146 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
