Question about Maytag Bravos MTW6600T Top Load Washer
The 2-year old washer leaks from the bottom. At first it was infrequent and now every load. It's in a tray (thankfully) and after two loads the 2" deep tray is full. I've checked the inlet hoses on the back. If I use bleach, I can smell the bleach in the tray.
    President:
  • 2,702 Answers
It sounds like the main water seal has burnt out and all this water is running through the washer drum bearings,,,this will wash the grees out of them so soon the washer will be making a lot of noise as well mostly on the spin speed first,,,
you need to fit new drum bearings and drum water seals,,,
Posted on Aug 21, 2010
  • gburt385 Mar 11, 2011
    where to get new seal and bearing what are the part numbers or sizes?
I have a Frigidaire Gallaxy Series top loading washing machine, 4 years old that seems to be leaking from the bottom. Is this something I can fix myself? THANK YOU.
Before you buy a new $100 door gasket, pull out the soap dispenser tray and look inside the washer where it normally sits. If there is significant soap accumulation (even 3/8 inch), the water can become backed up and trickle down the washer front to the door bottom, making it look like a door leak. Fixed mine this way.
Jul 30, 2010 | Washing Machines
Leak
Hi, If you remove the lower half of the front panel, you will be able to see the pump and hoses. Another option is the bellows around the door. Please let me know if this helps or if I can assist you further.
Thank
Vic
May 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Thumping Noise
it must be due to the damaged belt inside the motor. check it out.
thank you
Mar 09, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore top load washer approx. 10 years old
f7686aa.jpgPump is leaking around the drive shaft.
To get to the pump CLICK HERE
Dec 28, 2008 | Kenmore 24032\24036 Top Load Washer
Ammana washer less than 5 years old making loud noise and leaking water from bottom of washer
it sounds like the tub seal is going bad and leaking on the bearings,not good,you can remove the top with a putty knife into the front seam one clip on each side(make sure no screws on bottom front,you can now check everthing out to see what you find,let me know -mike
Sep 26, 2008 | Whirlpool Washing Machines
5 yr old washer is leaking
Ellbee, remove the two screws at the bottom of the front panel and lift it towards you. Two clips on the top that hold it will release. You can now get a good look at the pump. Catriver..post back.
Sep 19, 2006 | Frigidaire GLWS1339C 3.0 Cu. Ft. Top...
Maytag Bravos MTW6600T Top Load Washer Logo
636 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
