Question about GE Nautilus 24" Built-in Dishwasher
Dishes have a film on them, washer does not drain completely
  • GE Master
  • 43,501 Answers
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Aug 22, 2010
I have a Samsung Dishwasher DMT800RHS, dishes have brown film, tried Lemon Magic, fixed 9e code, still dirty dishes. Used liquid detergent, still dirty dishes. Sometimes white film.
Sounds like its not draining properly between cycles. Its time for an appliance engineer I'm guessing. Can you access the drain pump hose area to see if its clogged.
Nov 06, 2014 | Samsung 800 Series DMT800RHW 24"...
After running a full cycle the dishes have a film left on them. Sometimes soap is not rinsred off the dishes. Tried different soaps for dish washers. It seems the only thing to take the film off of the...
Film on dishes post cycle is caused by 2 things.... Poor water flow during the wash / rinse cycle.... i.e clogged sump inlets or restricted drains. Clean the drain hose first. Start at the cink connection and clean EVERY connection and in-line componenet from the port hole at the sink connection all the way back to the drain hise connection port at the dishwasher.
If you still have dirty dishes post cycle after drain cleaning... then remove the lower wash arm support and clean the accumulator / sump area thoroughly. See this link: (items 1 and 4) http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5140844&diagram_id=28222738#d28222738
Test again.
If the problem persists you will have to gain access to the pump impeller. Inspect the impeller, and pump housing for damage. UNDER the dishwasher. Item 22 of the above link.
This should get your diswasher performing properly again.
I used this model number as a reference: GU2400XTPB1
Thanks for choosing FixYa,
Kelly
Jun 03, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Cloudy film left on all dishes and glasses. How do I remove the film?
Buy a gallon of white vinegar and rewash your dishes this time add 1/4 of a gallon of vinegar in the water with no soap just vinegar and water.... Also check and see if the dishwasher is completely draining you may have another problem that the dishwasher is not completely draining and you are washing with dirty water...... check the screen in the bottom of the dishwasher and the spray arm to see if they are clean and open...... I have used vinegar in my dishwasher and it has taken the cloudy film off... You may have to add it a couple of more times if you have a real bad build up......
I also use cascade complete dishwashing soap and has helped the problem with the cloudy film.
Mar 28, 2011 | KitchenAid Dishwashers
Have bosch SHE45 EVOLUTION PUSH BUTTON ON RIGHT FRONT PANEL. MY WASHER WILL NOT RINSE ALL THE SUDS OFF THE DISHES OR DOWN THE DRAIN AND HAD BAD SOAP RESIDUE BUILD UP. i HAVE USED LEMISHINE ONE TIME AND...
I started running the Hot water faucet till I got really Hot water then I started the dishwasher with No dishes in it and let it fill with hot water till it was almost full then I added a half a gallon of white vineagar to the water and let the dishwasher go through its cycle. It cleaned up the inside of my dishwasher then I put the dishes that didn't get clean and that had a soap film on and rewashed them with plain hot water and poured the other half a gallon of vineagar in the dishwasher and let them wash the complete cycle. It cleaned the dishes very well. I don't know if you will have the same results but it worked for me..... Hope this helps, your welcome to give it a try vineagar is pretty cheap... and it won't hurt anything inside the dishwasher or dishes.
Feb 12, 2011 | Dishwashers
Not draining and leaving film on dishes and interior of dishwasher how do we fix it?
If you have mineral build-up throughout interior nooks and crannies, try some Iron Out. Follow directions on the back of the product. I had to do without a water softener for a time. I used Iron Out through two complete cycles. No more white film left on the dishes. It ran like new! Be VERY careful and follow those directions! This stuff is really powerful.
Nov 21, 2010 | KitchenAid Dishwashers
I have a Whirlpool Gold Quiet Partner III dishwasher. When I unload the "clean" dishes, there is some type of film or crud on the dishes. I have to hand wash them to get this off. It seems like a...
You need to check the drain system completely, look for plugged screens, pump impellers, valves and the drain hose. You need to witness a large volume of water flow during drain.
Sep 19, 2010 | Whirlpool Dishwashers
Dishes not clean
make sure all holes in spray arm are clear and turn your hot water up so it is 160 degrees F.(watch out in shower) If this don't help put in a pump kit
Aug 06, 2009 | GE Nautilus 24" Built-in Dishwasher
Water not draining out after wash cycle
frigidaire dishwasher model#MDR251RER0/serial#TH84453602 not completely draining. I hear when it the drain cycle begins but does not empty completely out.
Jan 05, 2008 | Frigidaire 24 in. GLD2150RCC Built-in...
Dishes and inside the washer are not drying
Make sure that the drain hose is connected as per manufacturer instructions, and that there isn't a direct run down from the sink u-bend to the machine. The rinse agent effects dishes dry but has nothing with the water remaining in the machine. Good luck!
Sep 15, 2007 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
GE Nautilus 24" Built-in Dishwasher Logo
54 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
