Question about Garden
Key start 6.75 HP Power Propelled lawn mower won't start. I changed the battery,spark plug, and belt. A repairman checked the carburetor and cleaned it. It started right up. I was able to cut my yard. Today I tried to start it again. It would turn over but took a few key turns (more than usual). I finally got it started, cut my yard. Turned it off. It would not start up again.
  • 472 Answers
IT SOUNDS LIKE YOU NEED TO REPLACE THE CARB I KNOW YOU JUST HAD IT FIXED TRY IT
Posted on Aug 22, 2010
Testimonial: "Thank you. From my research on lawn mower starting problems, it sounds like I need to replace the carburater. It is seven years old."
Will a bad drive belt make your riding lawn mower not start?it cranks
Take the spark plug out and see if it is wet with gas. Could be bad cable, bad plug, leak in carburetor gasket
Jul 20, 2016 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Have a self-starting, self propelled toro lawn mower about 5 years old, I ran it out of gas by accident & now it won't start
It seems to be an obstruction in your fuel delivery system. Get a can of ether and a spray a short burst of it into the breather area near the carburetor, if the mower starts up and then stalls out, then you may need to get your carburetor serviced.
Dec 18, 2013 | Toro Lawn Boy Self Propelled CARB Walk...
Hi I did a tune up ,changed and checked every thing I done ..too I changed the oil ,oil filter ,gas filter air filter ,got a new battery changed the plugs there new too...even a new belt new key ...but...
Spark and gas??? Must have both. Pull spark plug wire and check for spark. If you have spark, check gap on spark plug. Check the bowl on carburetor. loosen bowl screw to see if gas is coming out. If you have gas coming out, carb needs to be taken off and cleaned or rebuilt.
Oct 11, 2013 | Cub Cadet Street Sign- tractor lawn riding...
Wont start
I would check for spark, if you have spark put a little bit of carb cleaner in the spark plug hole and see if it fires up and then dies. If that is the case then the carburetor needs to be cleaned. Hope this helps!
Jun 07, 2012 | Troy Bilt 5.5hp Self Propelled Mower
Wont start
Check the blade bolt is tight, if the starter kicks back it may have sheard the flywheel key, to check this you will have to remove the starter and flywheel.
Apr 16, 2012 | Briggs & Stratton LawnBoy 20Inch 65 HP Gas...
Engine won't start oil level is good has fuel changed spark plug and filter
Remove the spark plug and attach the plug wire to the top of the plug. Place the base of the spark plug against a metal part of the engine and pull the starter cord. You should see sparking between the plug electrodes. It helps to do it in a dark area, not out in the sun.
If there is no spark, something may be shorted out, a wire broken, or the magneto has come apart, etc.
If there is spark, then the problem is fuel related. The gas may not be getting to the carburetor, or the air / fuel ratio is wrong, not allowing combustion.
You have to eliminate each of the possibilities one by one. I would recommend buying a can of starting fluid, which you can get at parts stores, Walmart, Target, Shopko, etc. Spray a little in the carburetor or directly into the spark plug hole. Replace the plug and if it acts like it is starting, then dies, you know you have good spark and the problem is with the fuel or carburation. If the machine has sat for a long time with stale gas in the carburetor, it gets gummed up and will not start. The carburetor will have to be removed and cleaned.
Jul 14, 2011 | Craftsman Front Propelled Rear Bag Lawn...
I have a Toro 20" self propelled, electric start
I am strictly Briggs&Stratton. They are hard to start when the fuel tank is half empty. Clean the plug and air filter.
Jun 15, 2011 | Toro Power Lawn Mower
I put new spark plug in and changed gas in lawn mower and now it won't start.
Your mower has to have these things all working in unison to start 1. Compression (the engine has to be in good shape) 2. Clean Air (Check Air Filter) 3. Clean,fresh constant fuel supply (Maybe remove bowl of carburetor and clean/check for debris and/or water). 4.Strong Spark (Remove Plug and ground the body against the engine. Pull starter and check for nice, blue spark.
Sometimes, the problem is as simple as the brass bolt that holds the bowl on the bottom of the carburetor is clogged and needs cleaning. That's because this dual purpose bolt is ALSO the main jet. So if you remove it to clean the float bowl, clean the bolt as well. Use no metal objects on it at all. There are small holes in bottom and along the sides that get gummed up when fuel dries.
Carb/Choke areosol spray cleaner will clean the bolt. Remember, don't scrape it up.
Check all these things. To maybe "coax" the engine to run, remove the spark plug and spray a couple of shots of carb cleaner into the engine. Immediately choke it and pull start.
Some OHV lawn mowers are difficult to start because the overhead valves need adjusting periodically. The Briggs and Stratton website have instructions and specifications for doing this. It is not real complicated and allows for easier starting and much better running. Post back if needed.
Jun 04, 2011 | Troy Bilt 5.5hp Self Propelled Mower
Troybuilt 675 hp lawn mower doesnt start
self propelled not working on troy built 675 series bought 5/08. The belt is still on.
Jun 17, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
