Question about Singer Sewing Machines
Free Singer 185K manual The thread breaks most of
Free Singer 185K manual The thread breaks most of the time. You think you've got it right and then you get looping on the back of your work. Sometimes the needle unthreads itself
    Problem Solver:
  • 6 Answers
You need to adjust your tension, or make sure bobbin is threaded right.
Posted on Aug 30, 2010
  • 340 Answers
Why does the bottom thread on my 185k Singer sewing machine keep tangling.
Your bottom thread looks like the top tension is too loose or not being fed through the tension disc.
1. While you thread do it with the pressure foot up. Make small pulls while threading to make sure there are no snags.
2. When you finish threading put the foot down. Check for resistance on the thread. There should be some; not excessive though.
3. Always start at four on tension and adjust as you need to.
Feb 26, 2015 | Singer Sewing Machines
How to time a sewing machine
Breaking needles is not an indication that your timing is off. If you are breaking needles, the most common cause is inserting your spool of thread so that the little notch on the spool that holds the loose end when it is not in use and when you first purchase it is facing your thread path, catching and holding up the thread and causing the needle to break. Another problem might be inserting the flat end of the needle improperly; generally, on modern machines with the bobbin system in the front, the flat part is inserted towards the back of the machine. You MUST have a user's manual; if you do not have one, go to the Singer site, and you can download it free.
Sep 07, 2014 | Singer Merritt 8734
How to thread singer 57817
here is a link for a free manual, read the manual competely thru
first and then if the machine has been sitting up for years look in
the manual for oiling instructions and then oil where it shows
and then sew on a scrap piece of fabric but don't use any thread
so the oil can move thru the machine and loosen it up,,
try using a new needle--one that is right for the fabric you sew
http://www.singerco.com/uploads/download/118_356508008.pdf
Jan 25, 2013 | Sewing Machines
Bobbin thread keeps breaking
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
if you don't have a manual, here is a link for a free manual
http://www.singerco.com/uploads/download/1295_3270.pdf
Dec 21, 2012 | Singer 3343 Mechanical Sewing Machine
Fix tension on Singer 4552SW
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight--if tension is too tight back
off one number or letter at a time, if thread is too loose increase
one number or letter at a time till you get the correct stitch
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8.also check to make sure the top thread has not come off the thread
take up lever
if you don't have a manual, & want one, singer has a free pdf
manual to download
Go to the singer website
Click on customer support--there will be a drop down menu
Choose instruction manual
In the box type the model number( example 4552) do not put in
the sw
Click search
Jun 05, 2012 | Singer Sewing Machines
It keeps breaking the thread when sewing a few stiches, i need the manual to make adjustments, I work at a hospital and patients use this machine and we do not have a manual for it singer advance machine.
Sounds like it has been threaded wrongly or the tension is too tight. Try re-threading or loosening the tension slightly. Singer should be able to provide a downloadable manual on their web site, I think.
Jan 25, 2011 | Singer Sewing Machines
Sewing machine either breaks thread or comes unthreaded every time i try to sew.
Your threading is not right, totally remove your thread and rethread according to the manual directions and dvd. If, you still have problems call Singer at 1-800-4singer
Sep 29, 2008 | Singer 3116 Simple
Singer Simple.....not really!
You really should go on the Singer website and look up support and frequently asked questions. If, you cannot find your manual they have it there to download for free. I really think that you are not threading the machine right, check it with the presser foot up and the thread should feed freely, then lower the presser foot and it should not feed at all or very little. Most of the bunching of thread underneath is the fault of the top thread not the bobbin. Make sure you turn the handwheel towards you never away from you. Also, check your needle, inserted flat side away from you and, if it were me, I would use a new needle before I sewed again, This machine comes with a dvd, try watching it.
Jul 22, 2008 | Singer 3116 Simple
Sewing Machines Logo
1,338 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
