Question about Kenmore Dryers
Kenmore gas dryer (14years old) starts by turning the timer rather than waiting for the press on the start switch - then never turns off. Replaced timer - no change. Maybe the on push switch is always "on"? Hence it runs again and never turns off....
    Champion:
  • 245 Answers
You have a bad start button.
Posted on Aug 22, 2010
Testimonial: "Am buying a new start button this week but won't be able to get to the dryer for three weeks - so will let you know...thanks"
I have a kenmore elite dryer that will not start - once you select the dryer setting and press and hold the "start button" all it does is click. An indicator light also switched from "check...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Dec 27, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore gas dryer doesn't stay on
I think it is probally the thermocouple not holding letting gas valve work properly, timers do not go out very often, its not getting hot enough to release the gas, valve wont let it, chheck thermocouple, let me know im not there, but its in the heat not getting hot enough
Feb 25, 2010 | Kenmore Dryers
Hi, I have a Kenmore Dryer Model 100.96591240. 15 years old (approx). Problem just started - I have to wiggle the Timer knob after pressing the Start button (sometimes I have to push the Start buttom and...
i took apart a dishwasher and in the timer switch there were some electrical contacts and over time they get a black burnt build up on them and need to be cleaned or replaced .might need a new switch
price one on ebay . or look at sears.com for a new part
Jan 10, 2010 | Kenmore 73952 Gas Dryer
Kenmore Dryer (Model #11073952101) starts, but WON'T stay ON
your motor maybe going out. theres a switch on the motor that starts it . on most models the start switch is built into the motor. however some models the switch can be replaced by itself.
Aug 30, 2009 | Kenmore 73952 Gas Dryer
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
Dryer wont start. starter switch is new and timer will run when the door is closed
HI. if the timer is running, and the wiring harness is in good condition, this will confirm motor failure. I would advise to test the operational value of the door switch as well but if the door switch is working, this will only lead to motor failure.
May 22, 2009 | Kenmore 73952 Gas Dryer
Kenmore Dryer
The start button works like a push-on switch that engages the timer switch. It's all one unit. It isn't engaging because the internal lever the engages the switch is either broken or worn out. The start timer/switch will need to be replaced.
Jul 09, 2007 | Fisher and Paykel DG05 Gas Dryer
Dryers Logo
35 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
