Question about Saws
I have a 10 inch delta table saw. I cannot get it to turn on. It must be the switch or reset button. Where can I purchase these two items?
  • 90 Answers
You didn't specify the brand. try tool parts direct or ereplacement parts onlind.
Posted on Sep 02, 2010
Craftsman model 137.415030 10 in portable table saw won't turn on. It is getting power the switch sounds like it is working ok but it won't turn on. The reset button ,does not appear to do anything.
My table saw motor just stopped.. What do I do? - The WoodenBoat ...
forum.woodenboat.com/showthread.php?...table-saw...I...
WoodenBoat
Apr 6, 2013 - 23 posts - ‎20 authors
Does the motor have an internal thermal cutoff switch? ... Auto reset on a table saw, now that would be scary. ... A Craftsman, I think. ... The saw is a Grizzly 1022Z contractor-style saw about 10 years old. .... After the motor cools down the switchneeds to be pressed to restart the motor, it won't start suddenly ...
My table saw stopped, the reset button won't reset. What ...
www.shopyourway.com > Manage My Life > Questions
It is a Craftsman Table Saw Model 137.248880. ... I pressed the reset button and the saw restarted. I continued ... My table saw stopped, the reset button won't reset. ... One was just the switch the other the rocker switch, identical except in cost.
Craftsman 10 table saw motor stalled - Yesterday's Tractors
www.yesterdaystractors.com > Discussion Forums > Tool Talk
Dec 25, 2015 | Craftsman 21802 10-inch 13-amp Portable...
Model 36-979. Where can I get a wiring diagram for the power switch?
images for Delta Table Saws wiring diagram for power ...
Replacing a Table Saw Power Box and Switch. Rocket ...
? 7:45
https://www.youtube.com/watch?v=8A25b9BjkmY
Feb 12, 2014 - Uploaded by AdventuresInDIY
See how an in the way power box on a 10 inch Delta table sawwas switched out ... Would you happen to have a wiring diagramfor your saw.
Oct 28, 2015 | Delta Saws
Need to purchase delta 36-979 dado head table insert for 10' table saw
Use an appropriate pc of mdf that is same thickness of throat plate already installed. Use a router to flush trim to that throat plate. Now, insert and hold down with clamps and scrap panel. Raise Dado head ,while running, enough to do the job. This completes a zero clearance throat plate. No need to buy!
Dec 31, 2012 | Delta 36 979 10 Inch Left Tilt 1 1/2...
The belt on my 10"
you need to check your brushes again. something is making contact or shorting out. look at everything carefully
Dec 25, 2010 | Delta 36 979 10 Inch Left Tilt 1 1/2...
10'' delta table saw manual
you might try Dewaltservicenet.com but you will need the model number and you might have to put the dash in between to get it to list the model. Let me know if you need more assistance and if you do I would also need this information.
Nov 27, 2009 | Delta JT160 Shopmaster 10 Amp 6 Inch...
How do I align the saw blade with the saw table I have a 10 inch Delta Contractor's saw that is about 10 years old. The blade is not straignt with the miter slot. andyc@bergeralllied.com
The Blade Arbor is held to the bottom of the table with mounting screws and stop/adjusting screws. Loosen the mounting screw and adjust the stop screws to make Blade true with miter slot.
Sep 14, 2009 | Delta 36 982 10 Inch Left Tilt 1 1/2...
Delta Table Saw stopped running
I have a table saw that the cord from the motor plugs into the the back of the on/off switch. I yours is configured like that, unplug the motor cord from the back of the switch and plug it in to the wall and see if the motor will run. If so replace the switch.
Jun 21, 2009 | Delta 10"Hybrid Tablesaw with 30"Unifence
I purchased the Bosch saw blade on Ebay
If the arbors the same and you're running with in the RPM rating, it will be fine. But ALWAYS wear your safety glasses.
Mar 15, 2009 | Bosch PRO1072SM 10 Inch 72T Miter Saw...
Can I mount a Delta 36-T30 T2 30-Inch Fence and Rail System on my
I just installed a Delta T2 fence on my 10" Craftsman Table Saw. It's 27" deep. The bushing either could be relocated or you could use spacers on the front, back, or both on the saw to get the required distance. Also, you'll have to drill new holes, however, I used one of the existing holes in the front and back of my saw as well.
Mar 11, 2009 | Delta 36 T30 T2 30 Inch Fence And Rail...
Saws Logo
119 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
