Question about Mitsubishi WD-62531 Projection Television
I have a mitsubishi wd 62531 that turns on and works 2-3 hours and then shuts off.after letting set an hour or so it turns back on but only for an hour or 2 and then shuts off again
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 132 Answers
I would start by changing the lamp if you haven't already. You can buy them on ebay. Just enter your model number. Unfortunately there is no way to test a lamp to tell if it's bad or not other than trying one. You will need one eventially anyway, so you might as well try. Lamps on average last around 2 years. I've seen several go out in less time than that. It just depends on how much it's played. If it isn't that, then I would visibly inspect the power supply module and make sure that there aren't any electrolytic capacitors that are swollen or domed on top rather than flat. Any that are domed should be replaced. I've seen a few dlp's that have had caps cause shutdown problems before. If it's still in warranty I would contact mitsubishi about it and they will pay for a tech to look at it.
Posted on Aug 22, 2010
Need a Mitsubishi WD-62531 Lamp. I have 2 part numbers which one is right?
go to www.shopjimmy.com
when you search brand and model it will appear..
Jun 07, 2012 | Mitsubishi WD-62531 Projection Television
Were is the lamp cover of the mitsubishi WD-62531 at so i can change the lamp
It's on the back of the tv, located on the left while facing the back. There are 2 screws holding the lamp cover and 2 more holding the lamp.
Sep 14, 2010 | Mitsubishi WD-62531 Projection Television
WD-62531 fan
If the fans aren't operating then the set shouldn't stay on or even turn on. If its the main lamp exhaust fan then you are looking for part number 299P288010. They are relatively easy to replace as they only have a 3 pin connector that will plug into the main board or the power supply. Verify its that fan and as always if you replace it yourself make sure the set is unplugged. Once replaced the back will have to be re-installed or the set will not work as it has a safety switch that detects when the lamp door is off and on.
Jun 29, 2010 | Mitsubishi WD-62531 Projection Television
I HAVE A 65 INCH MITSUBISHI TV WD-62531, WAS WATCHING TV, AND ALL OF SUDDEN THERE IS A BLACK FILM ON THE BOTTOM OF THE SCREEN. CAN ANYONE HELP ME OUT WITH THE PROBLEM, PLEASE EMAIL MIKEKIMA@HOTMAIL.COM
Have a Mitsubishi 65 rear projection menu keeps fading on and off, any ideas of the problem. Bulb just replaced 2 months ago, no problems with bulb. Also a DVD works fine, but tv picture will not come on.
Dec 24, 2009 | Mitsubishi WD-62531 Projection Television
Mitsubishi WD-62531 Replaced lamp 2 weeks ago. Red light flashing again. Same problem but the lamp is fine. Sound but no picture.
You have either a bad ballast (it powers the lamp) or a bad DMD board. Either one of those will result in a no lamp fire issue. Have a technician look at it...
Oct 17, 2009 | Mitsubishi WD-62531 Projection Television
RED LAMP LIGHT!!
Check to make sure your lamp is not blown.
Make sure you installed a Mits original, and not a generic.
Make sure the lamp is seated and secured properly, as slight movement can cause a loss of connection.
Slide your set out to the side and peer into it through the slats. Can you see the lamp fire on?
Your symptom does not indicate that it could be a problem other than the lamp and the installation thereof, however---there is an instance where 2 capacitors will blow on the power supply and cause a red lamp light to show. Furthermore, the light engine itself could be causing the problems.
But, since you just installed the lamp, I would look over your installation.
Apr 09, 2009 | Mitsubishi WD-62531 Projection Television
Mitsubishi Projection TV WD-62525
this set has 3 temperture sensors.If the set gets too hot it will shut down.
first clean the cooling fan as it may be full of dust.
if this is not the cure the one of the sensors is likely bad.
Thanks Guy9
Jun 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62531 Projection Television Logo
41 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
