Question about Dishwashers
Telmann TEL12DWMS Motor hums but does not wash dishes
  • dunk1 Nov 08, 2008
    weve got a telmanns that has a E2 fault can you help
TELMANN WASHING MACHINE HAS CODE ERROR E 2 can anyone help
jane@nosnam.co.nz
Posted on May 17, 2008
Samsung dish washer DD81-01549A_EN How do you reset the dish washer it won't wash it just hums
Humming could be no water going in, check fill hose.Or get a bucket of water put into drum then start machine helping to Flush out.
Oct 21, 2017 | Samsung Washing Machines
Telmann washing machine does not drain out water
a object may entered the pump and jammed the rotor or the drive from the motor to pump coupling may have broken
Jul 11, 2014 | Dishwashers
Telmann
GO TO TELMANN.COM I DID AND CAME TO A WEB SITE WHERE YOU CAN ORDER PARTS
May 08, 2014 | Washing Machines
Telmann TEL6TL washing machine doesnt spinn properly, brake motor not activated
replace whole mechanism if cheeper than replacing unit and dont want to pay a pro
Jun 19, 2012 | Washing Machines
Telmann starts putting water through then stops and beeps, does it on every cylce?
does it fill up to the tub and then stops and does it empty and spin let me know any more imfo will help me solve thanks
Nov 12, 2011 | Washing Machines
It lets a little "soaking"
your belt went bad in dish washer replace belt. dont keep runing that like that you will burn the moter up in dish washer
Feb 15, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
It fills & dumps the water with no problem BUT it will not wash the dishes it just makes a humming noise.
OK, i would test the motor to make sure that it is working properly. this is a two speed motor and, if the windings are bad or separating, it will not be able to switch speeds. if the motor checks out ok, this will confirm control failure. replace timer or control board in this case.
May 29, 2009 | Kenmore Dishwashers
Dishwasher doesn't drain after washing
Try to see if you hear a slight hum noise from the electric motor under the bottom. The noise will not last for long. This is the motor trying to start in the reverse direction. For the unit to drain the motor must run in the opposite direction so it can actually wash dishes well in on direction and not run in the other. After power has been removed (and maybe water too) get under unit and see if motor will turn in both directions. If it does, then the nearby start capacitor needs replacing or the motor is defective. A bad motor will not hum for long before the "heat trip" safety device will cut it out and it will then have to cool off before more test or done
Mar 17, 2009 | Kenmore Dishwashers
GE Nautilus Built-In Dishwasher
This would be the motor that spins the dish washing unit in the bottom. The noise you hear might mean that the motor will need to be replaced.
Sep 17, 2008 | GE Nautilus 24" Built-in Dishwasher
Problems with Fisher & Paykel Nemo model DW681.
is there somthing stuck in the wash motor,can you hear a humming noise ? if yes remove motor and see if you can turn it by hand.hopr this helps.
Mar 14, 2008 | Dishwashers
Dishwashers Logo
588 people viewed this question
Top Dishwashers Experts
