Question about GE 16.7 cu. ft. / 473 liter Upright Freezer FUF17DMRWH
My ge upright freezer is getting cold, but it is not freezing the food
    President:
  • 2,702 Answers
Check the door is closing tight first,,if it is try turning the thermostat down a bit more,,if that dont work you may need a new thermostat fitted and maybe even a re-gas and a new compressor
how old is the freezer???
Posted on Aug 21, 2010
4 Suggested Answers
  • 11 Answers
SOURCE: My GE upright freezer does not get cold.
Sounds like the system is low on freon. The other common problem is a dirty condenser. Insure the condenser is clean, if it is. You will need to charge the system with freon. Which only a qualified refrigeration tech should do.
Posted on Nov 28, 2008
duby1990
  • 370 Answers
Sounds like you are low on freon.
Posted on Dec 01, 2008
Bat1956
  • 585 Answers
SOURCE: won't freeze after door was left open
Having the door open has introduced an excess of humidity and therefore condensate/ice into the freezer coils. The coils are therefore iced over. You have choices depending upon your skill level. You might: allow the unit to sit unplugged with the door open until the excess ice thaws out and wets the floor underneath, which may take from 6 to 24 hours. You might: do this, adding some heat source in the freezer to accelerate the process. You might: locate the defrot timer, advancing the timer until a click is heard indicating the unit is in defrost, and repeat after about 15 minutes to defrost the unit with it's own heater. You might: let it recover just as it is but it will take a couple of days to clear itself.
Posted on May 19, 2009
What number should i set the upright freezer control
Thank you for your inquiry, friend!
Normally it is recommended to set your Frigidaire upright freezer to zero degrees. It is your option to make it cooler if you choose too. I hope this information has been helpful. -Matt
Oct 15, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Upright freezer not freezing food and ice forming on back wall
is the top of the freezer full where it can breathe remove something to help it breathe
Sep 10, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
My GE upright frost free freezer is not cold enough to freeze food anymore.....its cold but not freezer cold....stuff is defrosting....what could be wrong. I hear it running, but I dont hear it go off...
without getting all technical, look for the condenser coil and be sure it is clean. Some are under the refrigerator and can be accessed by removing a "kick plate." Some are under and in the back and can be accessed by removing a cover with a few screws. Some units have a small fan that moves air over the condenser coil. Look for it and see if it is running. And then there are some that have coils that run up the rear of the unit and when it is pushed back against the wall, the air can not circulate and can cause this issue. This is the simple first step to do before getting a service tech involved.
Dec 16, 2017 | GE 20.3 cu. ft. / 575 liter Upright...
Freezer starting to defrost
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Feb 22, 2010 | GE 13.7 cu. ft. General Electric Upright...
Freezer gets cold but doesn't freeze
check tem.p inside cabinet and let us know what you find
Jun 29, 2009 | GE Freezers
Nov 28, 2008 | GE 13.7 cu. ft. General Electric Upright...
GE 16.7 Upright Freezer
HI the heat on the outside of the cabinet is normal. the freezer is now working properly give it 24 hrs thanks.
Jul 17, 2008 | GE 16.7 cu. ft. / 473 liter Upright...
GE 16.7 cu. ft. / 473 liter Upright Freezer FUF17DMRWH Logo
200 people viewed this question
Top GE Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
John Tripp
John Tripp
Are you a GE Freezer Expert? Answer questions, earn points and help others
