Question about LG Washing Machines
My washer is a 2005 LG Tromm #WM2277HW. My daughter has used it for a few years and I have just got it back today. In the process of doing my first load of laundry the light keeps blinking IE or 1E? I tried a different setting from quick cycle to perma press and it still acted this way? I do not know where the manual is, it wasn't returned with my machine. Do you have an answer for me? Thanks, Debbie
    Champion:
  • 245 Answers
This is your water frequency. Check to make sure your water is turned on. If that is not the problem, Take your hoses off the machine and look at the filter screen on the inlet valve. If that's not it. It could be the inlet valve is bad. Good luck. Give me a rating if I am correct. Good luck!
Posted on Aug 22, 2010
Washer was spinning out. It got unbalanced. And stopped before I could get to it. Now it won't start. Why?
try unplugging and plugging back in. if that does not work, try unplugging and then plugging back in while holding down the power button. good luck.
Mar 03, 2015 | LG 4925ER1015B 4924ER1010 Used Frontload...
My lg tromm washer on the wash cycle is not spinning, and is making a grinding noise
check for something in the bowel. pins ,buttons coins etc have a technician check the spin operation.
Why is my LG TROMM frontloader dryer making a loud noise when running?
If the washer is making a loud noise the rear drum with bearing might need to be replaced. On this washer the bearing might not be sold separately, the entire rear drum might have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Sep 02, 2014 | LG 4925ER1015B 4924ER1010 Used Frontload...
"LG Tromm WM2277HW will not
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall effect sensor is used in these washer which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when their is an issue with the motor or when the hall effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sesor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Mar 27, 2011 | LG WM-2277HW Front Load Washer
Not completing cycle error IE
IE is a water supply error. turn water off to machine and unscrew your 2 water hoses on back of machine and clean inlet screens with old toothbrush. if they are clean, you probably have a stuck closed water solenoid.
Jul 25, 2010 | LG WM2277H Front Load Washer
LG Washer Model #wm2277hw
It is a motor error
• The connector in the LEAD WIRE ASSEMBLY is not connected to the connnector of STATOR ASSEMBLY Reconnect or repair the connector • The hall sensor is out of order/defective. Replace the STATOR ASSEMBLY
Apr 19, 2010 | LG WM-2277HW Front Load Washer
My Tromm washer model WM2277HW won't spin and flashes ''LE'' Help!
try to open the back of your machine wher you can have an access to the motors, see if it is running or the belt is in right place, you can turn it on while looking at it , just don't get closser, a few feet away woul be enough for you to see it
Nov 06, 2009 | LG Washing Machines
LG TROMM displays LE
LE stands for Load Error,
First try unplugging the machine for a few minutes and then retry a cycle. If you still get the LE error:
The Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in the US). Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000
Jun 21, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Tromm Washer Model # WM2277HW by LG
will it spin after it washes if it does not then your belt might be broke
Feb 12, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
121 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
