Question about Makita Angle Grinder 4.5" 9524NBX
Slow,smell burned - Makita Angle Grinder 4.5" 9524NBX
  • Makita Master
  • 885 Answers
Sounds like your brushes are used up. Take the brush caps off on each side of the grinder handle, if the carbon is 1/8" long or shorter they have to be replaced. (Makita Part #191938-1) If you overworked the tool (put too much pressure on while grinding) it's possible the armature and/or field overheated and burned out. They are Makita Part #517301-4 and #521621-0 respectively. You need a growler to check these items to see if they're shorted out.
Posted on Aug 23, 2010
Smelled burning wire and then stopped running
It can also be a suppression capacitor by the switch , or the electric field itself one or both coil fiels are gone.
Mar 29, 2014 | Hitachi DH40MR Jackhammer
Burning rubber smell when slowing down in an 89 Ford Bronco XLT?
Check under the car and look for a plastic bag that may have melted on the exhaust.
Feb 20, 2014 | Ford Bronco Cars & Trucks
Clutch burning smell in slow traffic
TAKE IT BACK RIGHT AWAY. if im correct switch i mite not be but i think that year ford owned jag. ford transmissions are known for having bad cooling system(over heating) for the trans causing bad vavle boxs in the trans causing that buring smell. you do not want to pick up that cost out of pocket. i did:(
Jan 31, 2013 | Cars & Trucks
Vacum Cleaner has burning smell.
Have you checked the belt...if u dont have the instructions to locate the belt see the manufacturer's website.
Sep 05, 2012 | Crock Pots & Slow Cookers
Amana ALW880QAW doesn't spin and agitation is slow
winephan,
I could be the pump slowly ceazing causing the belt to slip which would give a burning smell.
Motors in those units, are well build...have a service guy in but DON"t say anything about the motor.. because they will say it because you mentioned it
I sounds like you pump
Jul 22, 2010 | Amana ALW880WH Top Load Washer
Motor starts then slows and then stops. No indicator fault
few possibilities,capacitor could be burnt out,microfarads are printed on side of can,it will smell bad if it has failed,but can also fail without any ,odour,hope this helps
Apr 25, 2009 | Whirlpool GEW9250 Electric Dryer
Slow agitating
Sounds like a failure in the gear case but the burning smell makes me wonder if you have a problem with the motor. You will need a appliance tech to verify
Feb 26, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Burned smell
If the motor slowed down this would indicate a bad motor. not cost effective on this model to replace unless under warranty. it is not uncommon these days to see a motor go bad every now and then.
What are the first 4 digits of your serial number? this would be the month and year of mfr. even without a receipt, a warranty service shop should be able to assist you.
Oct 21, 2008 | Hoover U5507900 Elite Rewind Bagless...
Makita Angle Grinder 4.5" 9524NBX Logo
369 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
