Question about Maytag Washing Machines
I have a Maytag Washer, Model #, A506, Series 10. It’s 21 years old. I noticed oil on the floor about three months ago. I removed the front panel to see where the oil was coming from and didn’t see any oil inside, including the top side of the base. I tilted the machine back to inspect the underside of the base (where the belts and pulleys are) and that is where the oil is coming from. I appear to have an AH2347239 TRANS DEE orbital transmission and believe that is where the oil is coming from. The oil is all over the AH2347248 PULLEY, top and bottom. Now if I was to take a guess I would guess the problem is a faulty transmission lower slip seal. What would your diagnosis be? I’m not especially talented in mechanics. So depending on your diagnosis would this be something the everyday person with some mechanical skills be able to do. How would I do it? Can you direct me in the right direction? I was able to find a parts list on line which is how I’ve been able to identify the parts so far. Sincerely, Marty59
  • 1 more comment
  • Thanks Rob. Since I haven't gotten into the machine yet and only have inspected things where and when in this procedure do I add the lost oil? What type of oil do I use. Also, can I do all of this without a manual?
    Sincerely,
    Marty
  • Thanks again Rob. I ordered the seal yesterday. I will be giving it a shot soon. I will let you know how I did. Thanks for your expertise. Please don't run off...I may need you assistance again.
    Marty
  • I DID IT! Thanks for your expertise Rob and for your encouragement. someone else that responded to me said it was time to buy another washer. He said that the repair is extremely complicated involving taking the transmission apart. It all went just as you said Rob. I did pay attention to the lug stop as you suggested but getting it back was a bit testy for me. I ran a trial wash and spin w/out clothe. It worked so I then washed a load. Seems to be doing just fine.
    Thanks again Rob,
    Marty
  • 259 Answers
Marty, you are right on in assuming it is the lower lip seal. To access the part you will need to remove the center pulley center cap, then the phillips head screw that retains lug stop **(pay attention to the orientation of this part!!) and remove the lug stop and washer.
Next remove the center pulley by un-winding it off the transmission.
This is where the project gets trick as maytag actually created a tool to remove the lip seal, but you can still do it using a small flat head screwdriver insterting it in the space between the transmission tail shaft and the seal. (The seal fits tight to the outer bore of the transmission with the lip sealing up inside about 3/4 of an inch inside to the spiral cut tail shaft)
Pry the seal outwards enough to grasp it with a pair of needle nose pliers and pull it out.
The new seal is part #207843and it comes with an installation "tool" to seat it back up inside.
**When re-assembling the unit after installing (winding) the pulley back onto the spiral cut shaft be sure to position the lug stop so that it does not bind on the pulley when it is engaged in spin, yet does contact the pulley in agitate mode.
Posted on Aug 26, 2010
  • 1 more comment
  • Robert DeStevens
    Robert DeStevens Aug 27, 2010
    Yes Marty, you can do this without the manual. Lay the machine on it's back or front to start the process, and do not worry about replacing the lost oil, it will look like a lot has come out, but it's deceiving because the main pulley has been spraying the droplets around underneath. Also, that transmission has a lot in it already and actually had an equivalent life span without any oil in it.
    Just be sure to clean all the pulleys as best you can when you are under there to prevent belt wear from the oil.
  • Rob, I just want to double check. Are you telling me not to worry about adding back the lost gear lube? That really scares me, but if you tell me it isn't necessary...then I won't bother. I just need to hear it again.
    Marty
  • Robert DeStevens
    Robert DeStevens Sep 03, 2010
    Good for you Marty!!
    It makes me smile when I hear that one of our customers was able to complete a task such as this! Give yourself a big pat on the back for a job well done! That washer you have is one of the last of a great design and should last you.
    Thanks Again for the update!!
    Bob
  • Maytag Master
  • 8,220 Answers
Lower seal kit trans
Maytag library of manuals
Best of luck to you.
Some Maytag old timers hang out HERE
Posted on Aug 27, 2010
    Sergeant:
    Champion:
  • 311 Answers
21 years old- it's time for a new washer. This is an involved repair and would require the transsmission to be taken apart, etc and that is no easy task and something I would never do even with me being in the business. You have gotten your moneysworth out of this.
Maytag washer overflows
Remove and clean the water level tube that connects to the tub at one end and to the water level switch at the other end. Probably it is full of gunk.
May 28, 2017 | Maytag Washing Machines
Maytag 2000 series error codes
I have a Maytag Maxima frontload washer that was getting these two error codes. I found in my case it was due to the tub not draining water as quickly expected. On my model there were two screws at the bottom of the front panel (one on each side towards the floor) Once these screws were removed and my husband tilted the washer up I was able to get my hand behind the panel and unscrew the filter cap that is located towards the middle at the bottom. It is a large plastic circle that you unscrew. With your hand remove any gunk or objects blocking the filter (usually filled with gunk) screw the filter cap back in, screw the front panel screws in and try to run another load. I have had to do this twice so far. You would think if the filter needs to be cleaned out every year or so they would make it more easily accessible.
Feb 23, 2014 | Frigidaire ATF6000ES Front Load Washer
Maytag Model A506 Series 04 Serial 201072 VA, no owner or service manual available. How does the machine cabinet open up? There is a hinge for the top to lift open, but how does one release the latch? ...
If your Maytag is a typical top loader, you insert a putty knife at the front to release the latches. Try going to www.repairclinic.com and entering A506. With luck, you will see a list of common repair parts and may be able to view a generic Maytag video showing disassembly.
Aug 12, 2017 | Washing Machines
My husband purchased a Maytag Neptune front load washer model # MAH8700AWW about 5 years ago. The washer works great and we have never had any problems until recently. We just had pergo floors installed in...
you may need to put some anti vibration shock pads under the legs or some two sided tape to put on the feet to help secure it to the floor it may be slipping on the new floor surface
Feb 13, 2011 | Maytag Neptune MAH9700 Front Load Washer
Leaking water on spincycle
I have the same problem with my washer. The problem just began a few weeks ago. It is splashing out the front left corner of the tub and running down the inside of washer and then leaking out the bottom of the frame. It is just enough water to be annoying. The washer is about 6 years old.
Model: FAV6800AWW
Serial: 11277017EG
Any ideas??? Help!
Jul 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Remove the front of the washer to get at the water pump sav205daww
I have never messed with one of these with 2 front panels but it looks to me like you remove the 2 screws at bottom like the old series and get the toe kick off first. Then remove or back off some screws at the base of the front panel and then compress the top springs to release the panel. Here are some old school pix
Sep 11, 2009 | Maytag Legacy Series Top Load Washer
Maytag side by side fridge makes vibration noise
Mine is a different model, and less than three years old, but the vibrating noise was really annoying. I would shift the unit or the door slightly, and it would stop for a while, as you reported. I took a few minutes, applied pressure to different areas, up and down, inside and out. The noise was louder near the floor. I removed the plastic grill and applied upward pressure on the wires covering the coils - it was loose. I noticed an accumulation of dust, and vacuumed as far as I could reach around the underneath area; also pulled fridge out and vacuumed a dust-covered vent on the back near the floor. Was planning to insert some kind of wedge under the loose part, but when I put everything back in place, the vibration stopped - now I only hear a gentle hum. Seems I did something right in this process.
Apr 13, 2009 | Maytag MSD2756G Side by Side Refrigerator
Kenmore 80 series only 3 yrs old, won't, spin and the agitator appears to be stripped
your agitator dogs are stripped there about $10.00,remove cap to replace. easy,need 1/2 to 3/8 adapter or 7/16 socket depending on model. and your coupler is broken about $20.00 its what runs yous washer its like your belt under neath between motor and transmission , less cloths max water will stop it from happening again
Nov 09, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag Epic Z
heres a product that might be helpful http://www.apwagner.com/index.php?main_page=product_info&products_id=148095 really had good results with this since inroducd a year ago, $ 30 bucks its worth a shot!!!!
Oct 17, 2008 | Washing Machines
Maytag washer sav365zaww
LARRY...I HAVE THE SAME MODEL AND THE SAME PROBLEM JUST STARTED FOR THE 3RD TIME. CALLED THE REPAIRMAN THE FIRST TIME, MYSELF THE 2ND. MINE IS A BROKEN(IN TWO) BRAKE PAD. THERE ARE THREE OF THEM. REMOVE 2 SCREWS AT VERY BOTTOM OF WASHER FRONT AND REMOVE PANEL. YOU CAN GET TO THE 2 FRONT PADS FROM THERE ALTHOUGH TIGHT FIT. I ALSO READ THEY SHOULD HAVE CLEAR LITHIUM GREASE ON THEM, ALTHOUGH THIS DOESN'T MAKE SENSE TO ME. GONNA GO DO MINE AGAIN...GOOD LUCK....KHRIS
Oct 24, 2007 | Maytag SAV2655A Top Load Washer
Washing Machines Logo
637 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
