SOURCE: COOKTOP
its been my experience that the dual burner switch is far more likely the culprit, unless you can physiclaly see the outer ring is broken( visual inspection works wonders. as far as trying to ohm out i generally look at theelemnet itself (4 wires lead to the elemnt you can trace 1 to the outer portion of element, and 1 to the inner portion.WITH POWER OFF Iswithc those 2 wires and the restore power try element ad watch for outer ring to work inner ring no good. now i know its the switch not sending power. reset wires and order new switch
SOURCE: Heating element will not come on
The best to test that is to remove the top and take the outer coil and use it on any of the other burners to see if it heats up, then youll know for sure is the element or the switch.
Eddie Rentas
Tupper Lake NY
SOURCE: Burner temperature is always on high heat even at low setting
not related any further then sounds as if you have 2 burner switches gone bad,and actually the front right burner is controlled by a electronic control circuit board part retails for about $160-$200 part number 12002723, and left rear switch about $30 part number 74007841 . uint needs to be uninstalled from counter and parts changed by removing the bottom panel
SOURCE: burner on electric ceramic/glass cooktop is getting too hot
sounds like you need a new thermostat
SOURCE: The dual element on my electric smooth-glass
Hi, my humble advice to you is to call in the repair man to come and carry out a check and properly diagnose what the problem is.
You might be lucky to have a fuse problem which th repair man will find and replace it and if the element goes beyond the fuse issue, the repair man will be in the best position to determine if you are to purchase and install a burner module or buying a new cooktop...
So call in the repairman first.....
