Question about AO Smith Centurion 1081 1 Hp Standard Keyed Shaft Motor
Ordered new pump at pool store. they put old cord on new motor and i got it home and it does not run . i think they may wired it wrong but they closed til mon. thanks
  • AO Smith Master
  • 1,363 Answers
YOU MIGHT HAVE A BAD CORD .. USE A VOLT METER TO CHECK POWER AT THE MOTOR.. ON THE SIDE OF THE MOTOR THERE IS A WIRING DIGRAM LOOK AT IT TO SEE IF ITS HOOKED UP RIGHT.. DID YOU CHECK ALL OF THE BREAKERS ???
Posted on Aug 23, 2010
Hello, I have a little giant #508158, pump is approx. 2 years old used about 4 times to drain a residential pool that is in-op @ the moment, however the pump has stopped working, the GFCI does "not" trip,...
To be precautious, if the damage to the wire is near to the appliance you might be lucky enough to savage it as it is hard to come by. Cut the wire 2 -3 inches away from the damage and hang to drain dry for 2 days or so if there is any sign of water ingress. leave the damaged wire in situ until you are ready to remake a connection with the salvaged piece, salvage any water tight shroud on the wire into the pump or replace it with new.
When you open the electric box on the pump it would pay you to test the pump motor with a mega, to see if the motor is down if it is need I say any more.
When you have finished the repair or what ever, it might be an idea to store the pump , either repaired or replaced inside a metal box and put some rat poison baited traps around, also leave a couple of Asprins out for the rat in case it get guts ache.
Mar 11, 2014 | Plumbing
Brand new motor replaced old pb4. After installation it just hums and does not pump. Before installation it works fine without water going through? Any body know what is wrong?
Double check the wiring installation. One wire wrong will stop it. Don't let it hum! Compare old motor to new, are they the same voltage? Can you rotate the motor by hand? It should be free.
Oct 26, 2013 | Polaris Pb460 Polaris Booster Pump...
Rcvd new pentair 1 hp pool pump replumbed and did the electrical connection. motor get real hot and shut off. i used the correct 12 ga wires and wire it for 115v. do you think i got a bad pump. it did...
Assuming everything is electrically correct, the motor probably has a short in the winding somewhere. The motor should have a one year warrantee on it. Any pool store ought to be able to trade it out for you.
Sep 14, 2013 | AO Smith 2hp Pool Pump Motor Ao Smith...
I want to put a new GFCI outlet on the end of my intex pool pump to plug into the wall b/c the fuse has been blown. Where can I get one?
They make what is basically a very short extension cord with a gfci at one end. Plug you motor cord into the receptacle end. If the motor cord end needs to be replaced, put a new plug on it.
Watch the polarity. The white wire goes on the wide prong, the (usually) black wire goes on the narrower prong and the green wire goes on the bottom prong.
Aug 29, 2013 | Intex Pool & Spa
Pump stopped working
Reverse the wiring .put live to neutral and vise versa. May have been put wrong on label. Store wont tell you that because they will wan't payment to come out to your home.
Jun 21, 2013 | Pentair 340210 Dynamo Swimming Pool Pump...
Replaced old Sta-Rite pool motor with new 1.5 hp Emerson 1081 pool motor. Used exiting 240V wiring. Wired L1 to 120V (black wire), L2 to 120V (red wire), Ground to green ground Screw (green wire). Turned...
Get qualified electricrian to help. I've had the same problems with my pool pump. If you make one little mistake, it could be your last.
Oct 05, 2011 | Pool & Spa
A.O. Smith c48k2pa105c5 pool pump motor was running fine for 3 weeks. The other day it shut off cause of the thermal switch. Well now when I turn it on it works fien for a couple minutes then it shuts off...
If you mean that this motor is only 3 weeks old, and this is happening, return the motor.
If its an old motor and this is happening, purchase a new one. Even if you had a technician come out to look at the motor, chances are it would cost more than the motor itself.
Largest causes of thermal overload are.
-incorrect wiring
-wiring to wrong voltage
-incorrect wiring size
-bad motor windings
-bad rear end bearings.
Apr 27, 2011 | AO Smith Pool Pump Motor Hayward Swimming...
My motor for the usq1202 comes on and humms loudly, does not come on and then tripps the breaker. Is there a solution or do I need a new motor?
Could be a start capacitor, Ether in the back of the motor,about the size of a "D" cell battery, black with two or three wires coming from it. Or a little bigger in a case right on top of the motor.
With the power off remove this and go to get a new one at a pool store or a motor store. Take the old one with you as you will need to match it up to the new one.
It stores power to get the motor spinning. Otherwise the motor pulls to much power and kicks the breaker.
Nov 24, 2010 | Smith 2hp Pool Pump Motor A O Electric...
I just replaced my pool pump motor and it runs fine now but will not shut off. I did not mark the wires when I removed them as I didn't think it mattered except for the ground. When I reconnected the new...
Did the old motor have a built in toggle switch and the new one doesn't? The motor itself will not have an on/off switch...is the one there shorted closed? If the new one has a switch it sounds like you may have crossed the line and load leads so the motor always has power...Please comment back with more details.
Sep 12, 2010 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
AO Smith Centurion 1081 1 Hp Standard Keyed Shaft Motor Logo
113 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Larry Maranto
john h
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
