Question about Brother XL-2600
The needle on my machine appears to suddenly be too low. I was sewing, and there was suddenly a thudding noise as I sewed. When I next needed to rethread the needle, the needle is now too low for the threader to go through the eye of the needle. The needle is in its highest position (the knob on the side has the line at the top), and I tried making sure the needle was pushed up, and it does go all the way up to the needle stop.
    Genius:
  • 1,788 Answers
The needle needs to be replaced, it is not seated right
Posted on Aug 21, 2010
Why does it make a knocking noise as it sews?
the needle position is up tight in the holder and no where else
the cut away bit of the needle faces the bobbin case hook and the groove in the needle faces the end of the machine and gives clearance for the thread to pass through the material
from your description and what you did, the needle /hook timing needs adjusting as it is out
turn the machine over by hand as in sewing and watch the position of the eye of the needle and the bobbin case hook
just as the needle starts to move up, the hook should be just above the eye of the needle at the edge of the needle
The adjustment is by loosing off the screw on the vertical shaft at the end of the machine that is attached to an arm that moves the needle up and down and move that bit up or down until the needle is positioned correctly to the hook
tighten up the screw
next is to check the needle tension is not too tight
workshop manuals are available on line in pdf version or take it to a sewing machine repair shop for a proper diagnosis
May 12, 2016 | Singer Stylist 7258 Electric Sewing...
Clunking noise from sewing machine
Would need a good look to know whats wrong sorry the bad answer but a sowing machine with clonk ?? could be anything
Jul 05, 2013 | Brother HE-1 Embroidery Machine
The top and bottom threads of my Bernina Activa 220 do not engage.
try changing the needle
rethread the machine top & bobbin
it is also possible that the machine could be out of time & needs to be
checked at a repair shop
Aug 19, 2012 | Bernina Sewing Machines
Hello, I have a Brother NX200-Innovis computerized sewing machine. It was sewing like a dream when all of a sudden it slowed down and beeped and flashed "E6" . The balance wheel has completely...
turn the sewing machine completely off
rethread the machine the top thread & bobbin, if possible use a different spool of thread for top & bobbin
then turn the sewing machine on again & see if you still get the same message, if the same message still displays,,then it needs to be serviced
Aug 10, 2011 | Brother NX-400
Lould noise when sewing. already, cleaned inside, oiled, changed thread, needle and begins to sew correctly but while sewing becomes loud again. bobbin casing does not appear to be damaged. machine is...
Have you taken your throat plate off and cleaned that out? You have to take a stubby short screwdriver and remove the throat plate. Sometimes, lint and cloth build up in there and it looks like felt almost. I was surprised when mine had it, I always followed the standard way of cleaning and lubricating until my friend told me about this. I was shocked, to say the least, that she was right. And my machine quieted right down. Hope this solves your problem
Dec 30, 2010 | Brother CE4000 Computerized Sewing Machine
My Xmas gift sewing machine worked perfect stitching for about 18" than all of a sudden an F8 message occured and the machine kept making a clicking noise.
you should put an oil to the needle bar of your machine and to your bobbin. always put an oil if they clicking noise again.
Dec 26, 2009 | Brother CS6000i Computerized Sewing...
The needle hits way too low! Cannot sew any
You need to retime the machine, do not alter the needle bar it is very unlikey it has moved, email me for instructions drivewithken@blueyonder.co.uk
Nov 04, 2009 | Singer 7462 Mechanical Sewing Machine
We recently bought a used 301 Singer Sewing machine, it appears to sew well but makes a loud clattering sound,where the needle goes up & down, is this typical for this machine?
If I remember the 301 is an American model slant needle with a gear driven motor, the machines were known as 'Rockets' the noise you can hear is the play in the shaft of the motor which is very common to that model if it is where the noise is coming from, if the noise is coming from the needle area then a drop of oil might do it some good.
Oct 26, 2009 | Singer Sewing Machines
Thread bunching underneath
clean the lint out with canned air and check the bobbin holder for any possible needle pieces from breaking a needle maybe the needle is bent and you can't see the slight bend.may need oiling too
Mar 02, 2009 | Singer 1120 Mechanical Sewing Machine
Sewing machine, strange noise
Is the needle in right? There is a front and back to a needle. Also is it the right needle for the machine?
Dec 07, 2008 | Singer 7462 Mechanical Sewing Machine
Brother XL-2600 Logo
98 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
