Question about Brother Office Equipment & Supplies
Brother HL 2100 ... toner light came on so I bought new toner. Then the drum light is on.. so I bought a new drum... The drum light remains on. No paper jam.... Using genuine Brother replacements..... How do I get the light to stop blinking AMD get to use my printer again?
SOURCE: Brother MFC 7420 Paper Jam
After changing the drum, toner and running around town for days trying to find a reliable place to get this printer repaired, I realized I was spending a lot more money than what the printer actually costs. the drum was over $100, toner was $80, and the printer is $250. I bought a new one, and I can now use the old one for parts.
Posted on Jan 16, 2008
hemantraj
  • 638 Answers
SOURCE: Brother HL-2030 paper jam
thin sensor (looks like steel colour ) is not in the proper position.it is in the back side of the printer to the lower side where you feed the paper. irepair this problems regularly for my customers. you can do it your self it is very easy.just make your sensor move up and down properly it should not be blocked somewhere.rate this solution as fixya to encourage us to solve more and more problems like yours.good luck.
Posted on Jun 14, 2008
SOURCE: Brother printer HL 5250 DN.
Brother Drum Reset Instructions
The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
Press the cover release button and then open the front cover of the printer.
Press and hold down Go button until all 4 LEDs are lit. Once all 4 LEDs are lit, release the Go button.
Close the front cover.
Make sure that the Drum LED is now off.
Reset the drum counter only when you replaced the drum unit with a new one.
Posted on Dec 08, 2008
SOURCE: Paper jam in Brother HL-2140 printer
I have the same problem - try what it says at this link. http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000026/faq000026_015.html?reg=us&c=us&lang=en&prod=hl2140_all
Posted on Mar 18, 2009
SOURCE: Have a BROTHER HL2140. Paper jam: Can't remove
Solved by opening the front and removed paper: not required to remove cartridge. Info on Problems with Printers. Thank You
Posted on Nov 09, 2009
Brother HL 5250 red light flashing
I found this solution on the web-- Hope it helps.
The HL-2070N gets stuck in a toner end-of-life error condition. Perform the following to clear :
With paper loaded, new toner in,
Open front door
Turn off printer
While holding down the GO button, turn printer back on
When all four LEDs light up release GO button. All LEDs will turn off
Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
Press the GO button 5 times
Paper light will be blinking
At this point the toner end-of-life condition has been reset. Close front door.
BTW, I got this from Brother Support. Also, just a reminder, timing is important here so don't pause between button presses.
Jan 28, 2009 | Brother HL-2070N Laser Printer
HL-5140 Brother laser printer red status light remains on.
The red lite indicates one of the following needs to be looked at:
Cover open (Front cover) Close the front cover.
Cover open (Jam clear cover) Close the jam clear cover of the fuser unit.
Memory full - Press the go button.
Print overrun - Press the go button.
Clean drum unit - Clean the corona wire.
Jan 15, 2009 | Brother HL 5140 Laser Printer
Brother HL-2140 printing black pages.
Hi Nacardi,
Could be bad toner (toner sitting on shelf for too long). Or the drum could have been over exposed. The drum is light sensitive.
S88
Dec 14, 2008 | Brother HL 2140 Laser Printer
I have a brother HL 2040 laser printer. The toner and drum light were lit, so I replaced both the drum and the toner cartridge, but the toner light remains on. I have tried everything, but the toner...
Two things I could suggest you check. First, make sure you have removed all packing from the drum and toner. Sometimes there is a plastic strip on the toner that has to be removed before installation. Also, make sure you are using a Brother brand toner. Some generic brands do not replace the chip in the cartridge and they will not work,
Sep 19, 2008 | Office Equipment & Supplies
My Brother HL 5240 has Status toner, drum and paper lights on, I bought it on 4/30/08, new toner, plenty of paper, it showed on computer: printer is off line, but it was connected with computer. Really...
The drum light will flash on my brother HL-5240 Laser Printer when printing but it continues to print just fine. Does this mean the drum needs to be replaced?
Aug 07, 2008 | Office Equipment & Supplies
Drum and toner led blinking
I have the same problems with you guys, and none of the solutions above work.
I solved Brother HL-2040 with the following tricks
1. Use the link below to process steps 1-4 and stop.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002500/000017/faq002517_001.html?reg=us&c=us&lang=en&prod=hl2040_all&Cat=11
2. Use screw driver to remove 3 screws on one side of the toner
3. From the small separate part after removed it from the toner, there is a small white adjustment (plastic), use your finger adjust to the opposite side. Put it back to the toner, and screw them back as original.
4. Follow the remain steps from the link above,
Your toner indicator should be turn OFF
Regards
Vu
Jun 18, 2008 | Brother HL-2040 Laser Printer
BROTHER Hl 2040 PRINTER WON'T PRING
I got exactly the same problem and the "reset" didn't do anything. I fixed it by putting a piece of duck tape on magic eye on the cartridge.
Fallow those step to do the same thing as me:
  1. Open the front panel.
  2. Remove the toner and the drum
  3. Remove the toner FROM the drum
  4. On each side of the toner, there should be a little glass. Put the piece of duck tape on one of them. I put mine on the right side.
  5. Put everything back in.
  6. Turn on your printer if it's not already.
  7. Now, the low toner light should be gone and the green light should be on.
Now, you can really empty your cartridge.
Apr 06, 2008 | Brother HL-2040 Laser Printer
Drum light blinks, drum and toner have been replaced
you need to update your machine after every time that you repleacing toner or drum
contact tech support of brother company or i can help you but it will cost you
elvis
Jan 02, 2008 | Brother HL-5240 Laser Printer
HL-2040 CHANGE TONER
Reset the drum counter by opening the front panel, then hold down the power button for about 5seconds until ALL the leds are on. Then realease the button and close the front panel. Your coutner will be resetted.
Dec 22, 2007 | Brother HL-2040 Laser Printer
Brother HL-5250DN
if the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Sep 01, 2007 | Brother HL 5250DN Laser Printer
56 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
