Question about Kenmore 78812 / 78814 / 78819 Gas Kitchen Range
The oven does not get hot when on bake. It does get hot on broil
  • Kenmore Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Posted on Aug 21, 2010
My oven will not heat up to temperature
It may be the bake element that has gone out. The self clean usually uses the broil element to heat the oven. And most oven will either put 120 volts to the broil element while baking or pulse the broil element while baking. This will cause the oven to get warm but not hot. Check the oven bake element it cound be bad or a wire may have burned off.
Feb 14, 2014 | Ovens
The bake element (in over) will no longer get hot, should the element itself be replace or could it be something else? Range model RS675PXEQ0
It does sound like the bake element is probably the problem. Many ovens turn on the broil element with 120 volts to even out the heat in the oven or pulse the broil element. This may be why the oven is warm but not baking.
Nov 12, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
My bottom oven ( non-confection) will not go on-it will just sat 100 degrees but won't get warm or hot. Top seems to be working fine. This started after I tried to use the self cleaning feature.
If broil and bake do not work on your bottom oven, it is probably your lower thermistor or control board. If the bake works but broil doesn't or broil works and bake doesn't, it is very likely your heating element. With an ohmmeter, the heating elements should be about 40 ohms. Much higher or lower signals a problem. If you suspect the control board is the problem, they can be repaired quickly and reliably at www.fixyourboard.com
Oct 11, 2010 | GE Profile JTP56 Electric Double Oven
Neither the oven or broil element comes on. No error code appears, any thoughts?
Hi.
If both broiling and baking element are not heating, then the most common fault causing the problem is a defective temperature probe.
The probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in line on the circuit from electroning oven control to baking and broiling element.
When the probe fails, it will affect both baking and broiling function.
The temperature probe is tested reching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
If the temperature probe is good, then parts that may be responsible for the fault are oven electronic control and wiring. Having both elements failing at the same time would be rather unusual.
Regards.
Mar 02, 2010 | KitchenAid Ovens
Hi i have a kemore gas range that the bake ingiter or broil won`t
The igniter in the oven does not spark. It heats up and glows red hot until enough current opens the safety gas valve to the burner. It is not associated with the stovetop burners. Replace the oven igniter itself.
Aug 11, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Wont heat past 200 degres
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
May 27, 2009 | Ovens
Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
Nov 29, 2007 | Whirlpool RF262LXS Kitchen Range
Maytag oven not getting hot enough
When you put the oven into bake it preheats with the bake and broil element both.  The broil element is most likely your only heat source if it took that long to cook the pie.  Need to verify that the bake element is coming on.  If it isn't then the problem is either in the control or the element itself.  Give me the model # off the sticker on the oven and I can help you do the check out.  In the mean time see if the bake element is getting hot.
Oct 26, 2007 | Maytag MER5552BAW / MER5552BAQ /...
Kenmore 78812 / 78814 / 78819 Gas Kitchen Range Logo
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
