Question about Celestron PowerSeeker 114 EQ Telescope
Needs nuts for lens - Celestron PowerSeeker 114 EQ Telescope
  • 3,186 Answers
Eyepieces DO NOT have bolts and nuts. The eyepiece simply slips into the hole in the focuser. There is a tiny thumb screw that holds the eyepiece when it is placed into the focuser. You can buy a replacement at any well stocked hardware store.
Bring the scope tube to the store so you can measure the tiny screw hole and buy the correct thumbscrew.
Posted on Aug 22, 2010
Can I just replace the third brake light bulb only ..just the bulb.on a 2005 Chevy Malibu LS.or do I have to replace the hole brake light itself..
from inside the trunk looking up at the light First, gently work the gray, carpet like cover loose from the area around the tail light ,(this may give you a little trouble). Once you have done this, you will see three silver nuts. These must be unscrewed. The lower left nut must be accessed through a hole next to where the trunk lid fits. (The screws are permanently attached to the lens housing so will not drop into obscurity when the nuts are removed). After removing the nuts, GENTLY work the lens housing away from the car. You may need a screw driver to unseat the housing, but just be gentle.
You will find three bulbs inside the lens. The brake light bulb is on the lower right side. Simply pull the old bulb out and insert the new one.
Just reverse these directions to reassemble the housing.
Nov 18, 2015 | Cars & Trucks
How do I replace the rear blinker?
The lens needs to be removed. Look behind the trunk liner/carpet covering the access to the retainers holding the lens in place. Remove the retainers ( could be plastic wing nuts or actual nuts screwed to the tail light studs. ) There may be 3-5 holding the lens in place. Once retainers are removed the lens will pull away from the vehicle and the light socket can be twisted and removed from the lens assembly exposing the bulb
Jul 28, 2015 | 1996 Ford Thunderbird LX
GREEN CRT OUT OF FOCUS
The individual lens have a lug nut that when loosened allows the lens to be turned-----cover red and blue lens and call up the convergence grid---from the rear adjust that lens until the green lines are in good focus(can also do the red in and the blue if needed)
You will get no more advantage as the manual focus controls on the splitter block have very limited range.
when done carefully tighten the wing nuts on the lens back tight.
Dec 05, 2012 | Mitsubishi WS-65807 65" Rear Projection...
How to change the back lights or break light
You need to pull away the trim from the corners to get at the bulbs,to remove the lenses you will see either 4 or 6 nuts that hold the lens cover onto the body,this is held in place with mastic so once the nuts are off just pull away from one corner of the lens.
Feb 26, 2011 | 1996 Volkswagen Jetta
How do you change rear windshield brake light bulb in 1988 olds 88?
Hello there,
First of all, it isn't all that easy or quick. First, gently work the gray, carpet like cover loose from the area around the tail light ,(this may give you a little trouble). Once you have done this, you will see three silver nuts. These must be unscrewed. The lower left nut must be accessed through a hole next to where the trunk lid fits. (The screws are permanently attached to the lens housing so will not drop into obscurity when the nuts are removed). After removing the nuts, GENTLY work the lens housing away from the car. You may need a screw driver to unseat the housing, but just be gentle.
Best of luck.
Jan 11, 2011 | 1988 Oldsmobile Delta 88
How can I replace my rear tailight on my 2003 Thunderbird?
you should be able to remove the taillight lens. open your trunk,you may have to pull back the carpet covering the taillight retainer nuts.There should be 3 or 4 retainer nuts,these will either be a plastic wing nut style,or metal nut. remove all of them and gently pull on the lens,it should come out with very little resistance.the bulb fixtures will generally turn counterclockwise. replace burnt bulbs and replace the lens. hope this helps. Dale
Feb 14, 2010 | 2003 Ford Thunderbird
HOW TO REPLACE STOP LIGHT BULB ON 1999 FORD ESCORT WAGON
Open your trunk or hatch,you may have to pull back the carpet that will cover the tailight lens mounts on the inside.There are 3-or 4 plastic wing nut style nuts behind the light in the trunk. remove these,and pull the lens out from the outside. the lighs will turn usually counter clockwise. replace burnt bulbs. replace the lens,and refasten the nuts carefully.
Feb 14, 2010 | 1999 Ford Escort
How do i change the brake lights in the rear
GO TO THE TRUNK ,THERE ARE PLASTIC NUTS THAT HOLD THE LENS IN PLACE,NEED TO LOOSEN THEM PULL OUT THE LENS,THE BULBS ARE THERE TWIST THEM OUT, REPLACE WITH NEW LIGHTS THEN REPLACE THE LENS TIGHTEN THE NUTS ,JOB DONE
Oct 30, 2009 | 1989 Buick Park Avenue
Tail light brocken
tail light bulb broken/out remove backside nuts and remove lens and replace as needed
taillight lens broken same thing remove backside nuts and replace ..for affordability try a salvage yard
as a temporary fix red or yellow electrical tape ...i hope one of them was an answer to this question as i dont have much to go on ...
Sep 24, 2009 | 1998 Hyundai Elantra
Need to replace a brake light
in the trunk of the 2000 poniacs there are black caps over the screw nuts that hold your brake lenses in the body of the car. you will have to remove them caps and the nuts off the screws the lens should have 3 on it. hold the lens when you take the 3rd one off to keep your len from faling to the ground. then just pop he twist fixture and pull ad replace the light buld.
Jun 27, 2009 | 2000 Pontiac Bonneville
Celestron PowerSeeker 114 EQ Telescope Logo
52 people viewed this question
Top Celestron Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Vernon Taylor
Lawrence Oravetz
Are you a Celestron Optic Expert? Answer questions, earn points and help others
