Question about Maytag Dryers
Maytag bought in 1991 Electric. Has been well kept up with a good repairman. Stored the dryer for 6 months and now it will not heat..Any suggestions
    President:
  • 2,702 Answers
Only one realy,,,call your repairman out,,,,it could be its been got at by a mouse??? and its eaten the wires out??? they do do that you know!,,,that or there is some corrosion going on in the washer and the heater coil has seen its life eaten away by corrosion as its been stored away,,,
go on ,,,,treet yourself,,,,,buy a new washer????
you just know you wont to!!!!!!!!!!
Posted on Aug 21, 2010
Electric dryer runs but no heat. all thermal and motor and heater element have continuity.
Dryer Diagnostic - Not Heating up - Repair ... - YouTube
? 11:16
https://www.youtube.com/watch?v=3Vns05qIjGs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your trusty Maytag Electric Dryer suffering from some of the ... However, in REGULAR mode, it runs normal too, but theheat stops ...
Maytag Dryer Not Heating - How to Test the Heater and ...
? 4:12
https://www.youtube.com/watch?v=_zjiZ0sbCgI
Oct 12, 2013 - Uploaded by Bill Newberry
How to test the heating element on a Maytag Dryer. If you Maytagdryer is running but not heating these are what you need to check. ... The dryer runs but does not heat. .... Not heating Maytag electric dryer - Duration: 19:38.
Not heating Maytag electric dryer - YouTube
Jan 13, 2016 | Maytag Dryers
Maytag Bravos XL Dryer not heating- blowing thermal fuse
The thermostat is controlling the temperature, however the Heating Coil may be defective. Check the COIL.
Feb 27, 2014 | Maytag MEDB950YW Electric Dryers
Maytag dryer 3000
i have same dryer check fuses it may have 2 fuses on your breaker that'sall my book says
Jan 10, 2014 | Maytag Dryers
My Maytag dryer DG8420 doesn't light up the gas. The last time this happened (June 2006) the repairman replaced the ignitor. This time I took out the ignitor and attached the leads of my VOM to it and...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 09, 2011 | Maytag Dryers
I have a neptune dryer I bought from a used appliance store about 6 months ago. The cycle comes on but there is no hot air. Clothes are not dry after 3 full cycles. I am not even sure if its gas. Don't...
you will need to get behind the dryer and disconnect the vent tube, try drying a load of clothes with the vent tube disconnected if it drys then the tube is the problem and needs to be cleaned out. If it is not drying at all then it is a few things, I am assuming its electric here is a website that will help:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Nov 29, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My maytag dryer does not dry clothes, it takes upwards of two hours to dry a normal load. Tub turns, timer works, exhaust vent is clear, just doesn't dry.
Your dryer needs a new heating element. Any good Maytag repairman can put one in. If you are very handy you can do it yourself but if not it should not be an expensive job.
Mar 22, 2010 | Maytag PYE2300AY Electric Dryer
Maytag MDE7400AYW taking 2 or 3 cycles to dry
it's probably your sensor assembly. go to www.repairclinic.com/Appliance-Parts?s=t-MDE7400AY-%3d%3d&z=100 . That is the best possible solution and not too expensive. Good luck.
Apr 05, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
My Maytag Dryer Wont Heat, Im an amateur repairman
Inside the dryer on the bottom right corner.
Mar 10, 2009 | Maytag MDG6657BW Gas Dryer
Intermittent heat on maytag ldg8606aae dryer
your coils are most likely bad. if you are up to tackling the job yourself, I can help. otherwise, you will need to call a repairman. Joe
Nov 10, 2008 | Maytag Neptune MDE5500AY Electric Dryer
MAYTAG PYE2300AYW ELECTRIC DRYER not heating
Check the terminal block and make sure you're getting 220. If you only get 110, the dryer will run but without heat.
Apr 03, 2008 | Maytag PYE2300AY Electric Dryer
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
