Question about MSI KT4 Ultra (MS-6590-010) Motherboard
Just installed msi kt4 ultra/ ms-6590 v1.0 board. can't figure out where to connect hdd led, power led, reset and power leads
I'm selling one set up on ebay. It's label JFP1 in the manual. located on the bottom right of the board. also try www.msi.com.tw/ http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=200574168760&ssPageName=STRK:MESELX:IT#ht_500wt_1156
Posted on Feb 08, 2011
    Sergeant:
  • 203 Answers
Please find the info your looking for by clicking this link. you may need to register in forums 1st to read thread. Look in 'Technical' under ' General Technical Issues' for your layout.
http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t=86
Posted on Aug 22, 2010
I need MSI-MS 6590 motherboard software for upgrade
Drivers for MSI motherboards can be downloaded from the MSI website.
Start here:
http://www.msi.com/service/download/
Aug 10, 2011 | MSI Microstar KT6 Delta (MS-6590)...
I need all the driver for a msi kt4 ultra ms 6590 mb its a amd
Browse following link
http://www.msi.com/product/mb/KT4%20Ultra.html#/?div=BIOS
Click on Download section & find appropriate drivers...
Please rate & vote this , if like solution..
Thanks
San
Mar 15, 2011 | MSI KT4 Ultra (MS-6590-010) Motherboard
Como colocar cables de ensendido, reset, led's, sonido, usb del gabinete a la placa
Mira aca...
keynan_0.jpgPor más información, baje el Manual... Mira las páginas nº 25 - 50.
En caso que necesitas más ayuda, mandame un mensaje...
Si estás satisfecho con mi solución, por favor valorarlo (con los pulgares), o mejor, dejame un testimonial!
Suerte,
Pelu (Israel).
Dec 05, 2010 | MSI KT4 Ultra (MS-6590-010) Motherboard
No bios on kt4 ultra
You will need to contact MSI for a replacement updated bios; http://us.msi.com/index.php?func=service
Mike
Jun 07, 2010 | MSI KT4 Ultra (MS-6590-010) Motherboard
I tried to install more RAM and received 4 single
first check for the maximum configuration of your motherboard, second if that check you have fixed it correctly ,if place horizontally and then fix it , it will work
beep sound occurs only due to the above reasons
Feb 28, 2010 | MSI KT4 Ultra (MS-6590-010) Motherboard
Help, no sound driver!
i think downgrading to xp is an option, else try manually installing the xp drivers in vista, if u know how to do so, else please come back.
i personally recommend xp or win2k!
Aug 18, 2009 | MSI KT4 Ultra (MS-6590-010) Motherboard
I have a MSI KT4 Ultra Motherboard 6590 and after
Hi! It's not uncommon for a new installation of Windows to render a PC mute. It's happened to me on several occassions, but do not dispair.
After one round or two of Windows Updates, your device will be detected as missing its drivers and they will be downloaded and installed for you.
This happens with generic motherboards which use less known built-in devices such as the sound card, the video card, etc. Should your motherboard be an Intel, Asus, or other popular name brand, you run less of a chance to get this problem.
Please run Windows Update a couple of times, or until you're satisfied your machine is up to date.
Aug 17, 2009 | MSI KT4 Ultra (MS-6590-010) Motherboard
CPU Fan
Hello rc53_61,
If you look at the back of your old power supply you should be able to find the information you need (if you are going to replace the current power supply with the same one). The best place to find an exact power supply is visiting the manufacturer of your computer system for example: dell, hp, compaq, etc. You can replace a power supply rather easily, the only things you need to make sure is that the plug connection is compatible with the one on your motherboard and the power supply rating is the same or even a bit higher for wattage. Check the following links to find some good quality power supplies at a reasonable rate. These sites will help you with compatibility also by putting in your motherboard information. Let me know if you need further assistance.
Tiger direct
Directron
Just in case the links do not work properly
http://www.tigerdirect.com
http://www.directron.com
If you do not mind, please rate my help I would greatly appreciate it. Thanks
Sep 06, 2008 | MSI KT4 Ultra (MS-6590-010) Motherboard
MSI MS-6590 Hard Disk
Up to 160 GB is supported by the KT4 Ultra (MS-6590)
Aug 01, 2007 | MSI Microstar KT6 Delta (MS-6590)...
MSI KT4 Ultra (MS-6590-010) Motherboard Logo
396 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
