Question about Kenmore Air Purifiers
We bought a Kenmore Electro static air purifier model #85264 has been working fine. I clean it regularly in the dishwasher with no soap as we were directed. The last time I put it together, the check cell was on, I attempted to reset it, and turned the power off, unplugged it, took it all apart, put it back together and now the main screen comes on for a second and turns off, the board lights come on but then turns off after about 10 seconds. The machine is not operating, is there a way to reset it?
2 Suggested Answers
  • 7 Answers
SOURCE: Kenmore 85264 Electro Static Air Cleaner
Ammonia is a very strong agent & reacts with certain metallic compounds. No wonder the cleaning cell turned black. Educated guess, is you've ruined it. Cleaning in vinegar & hot water alone shouldn't have affected it like this. I would presume vinegar & ammonia mixed together would make a severe chemical reaction quite possibly harmful to you. I'm surprised you were able to put these 2 things together.
Vinegar & hot water by itself is an envirofriendly method of cleaning, deodorizing & disinfecting items. It's safe, as Vinegar is made from potato's...it's bio-degradable & shouldn't harm any fabric, wood, glass or metal materials. It doesn't seem to work very well on plastic. It's great for fabrics. Laundering with vinegar will kill mold, must, mildew & helps reduce allergens in fabrics.
Posted on Aug 05, 2010
Where and how can I order new filters.
You never need to ORDER new filters for your SUN AIRE purifier unit. Our pre-filter is LIFETIME/WASHABLE 0.5 micron 2-stage electro-static and NEVER needs replacement. Our pre-filter saves you about $100-200 per year in expensive replacement HEPA/charcoal/carbon filters on other units. Made in America and built to last you a lifetime- SUN AIRE purifiers! www.betterair.com
May 04, 2010 | Sun Aire Sun-Aire Air Purifier - Stainless...
Kenmore model 85264. Cleaned the filter only after 4 days use! It is dry. reinstalled and "check cell" light is still on. Pressing it does not reset it. Unit will not work. Filter is installed correctly.
you have to hold in the button until it resets.if the unit does not turn on you have to hold the middle button(on button)until it turns on....takes 5 to 10 seconds
Dec 14, 2009 | Kenmore Air Purifiers
Bought used model - should I clean plates inside or on back and how to do it?
The Plates need cleaning regularly with 1/2 ammonia and 1/2 warm water. In a shallow flat-bottomed container, with enough solution to completely cover the plates, let them soak for NO MORE than 10 minutes. Rinse well, then brush both sides with a stiff brush and rinse well again. Shake off the excess water, then thoroughly dry with a blow dryer, before reinstalling. If you e-mail to miller@healthyti.com and ask for cleaning instructions, they will gladly e-mail supplemental instructions (free) beyond what Ecoquest supplies on their website.
Sep 02, 2009 | Ecoquest Living Air Classic Air Purifier
Metal screen cleaning? pads required?
Soap and water will work just fine. Rinse thoroughly with hot water. I'd dry it with a hair dryer before reinstalling it.
"Should I use the pads?" -- Could you please clarify this question.
thanks...
Charlie
May 29, 2009 | Ecoquest Flair Air Purifier
I would recomend calling the 800 number to answer that question. I have this unit too and the instructions do NOT say to soak in Amonia and Vinegar! Good luck with that!
Mar 15, 2008 | Air Purifiers
Kenmore AC2044-1 question ASAP!
If it says "Clean Cell Now" and it is a new machine, it is broken. I have six, yes six, of this model. They are all new and you shouldn't have to clean the filter/cells for a few months.
The way to clean is:
  1. Unplug
  2. remove the white cover
  3. remove the prefilter. Good time to clean the prefilter by removing the 2 retention clips and gently swing the prefilter outward. Clean or groom it with a vacuum. Use the upholstery brush. wash the prefilter in warm, soapy water. No Chlorine! Rinse clean with regular water. Wipe with a paper towel and let dry completely. It is okay to gently use a hair blower to speed up the drying process.
  4. Onto the Cell.
  5. The cell can be washed one of two ways. Either in a hot tub of water or in a dishwasher.
  6. Wear gloves to protect your hands. Never touch the fins or wires. It will ruin them and cut you up. Use the two handles.
  7. Use hot water and dish detergent.
  8. No chlorine and no abrasives.
  9. Soak for 10 minutes, then dip a couple of times to remove stuck dust/dirt/schmutz.
  10. Rinse with clean water.
  11. Allow to dry
  12. Allow to dry
  13. Allow to dry
  14. Okay to use a hair dryer to speed up process.
  15. Reinstall
  16. Power up
  17. Press and hold CHECK button for 3 secs to reset.
Thanks.
Jan 10, 2008 | Kenmore AC2044-1 Air Purifier
The air purifier is blowing black soot.
I had the same problem and then found that it was from burning aroma candles! I will never burn them again!
Jan 04, 2008 | Honeywell HFD-130 Air Purifier
Need your help
Wireing Schematics for power supply board of Kenmore C347-32953 air purifier. Not sure if connection P4N is ground (black wire) or does it go on connection P1L beside it.
Dec 17, 2007 | Air Purifiers
Air Purifiers Logo
96 people viewed this question
Top Kenmore Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you a Kenmore Air Purifier Expert? Answer questions, earn points and help others
