My LCD screen keeps flicking and sometimes goes blank
    Scholar:
  • 122 Answers
Ok, I'm assuming your using this for a Television because your in the Flat Panel Television solutions. If you are using this for a monitor, you might need to check your video card drivers and your video card its self could be giving out.
Any how, if you are using this as a television, then right off I would have to say. Check your power button your remote, make sure its not sticking, also check the TV power button and make sure it is also not faulty and causing the TV to power on and off rapidly.
Next, check to see if the cables are all plugged in and secure. No lose connections, your power socket is stable and the power plug is not mid way or being kicked half out of the socket.
Now then, if these are checked and no other reason for the cause I would have to assume unfortunately your LCD is giving out.
Posted on Aug 21, 2010
My vizio 32" flat screen keeps shutting off by
sound like the main board is starting to fail
Feb 21, 2011 | Vizio L32 32 in. LCD HDTV
The screen goes blank after 1 second display, flicks back again to the display for 1 second and back to blank, this goes on non stop. The little led next to the on/off button goes from green to yellow...
pandres, Your monitor will need troubleshooting to find out reason why the 2 "cold-cathode-fluorescent-lamps" fail to remain lighted. They provide "white light" so you can see what is on the lcd panel. Connect a "known good" monitor to your pc to prove monitor is bad. If pc is ok, then your monitor will need repair. This type problem not new and is very common for all brands of ccfl back-lit lcd monitors. Watch some video clips at YOUTUBE that show disassembly and repair of ccfl lcd monitors. Read fixya profiles of "budmrtn" buddymc" "12fixlouie" for more information. 12fixlouie
Sep 08, 2010 | Neovo S 19 19 in. Flat Panel LCD Monitor
LCD TV blanks out when I flick the switch for my room lights
Do you have surge protector installed? If not, you should use one, something like MONSTER CABLE.
Nov 27, 2009 | Televison & Video
Screen flicks black every so often
check control panel for screen refresh rate .and change rate too see if that helps.
Apr 28, 2009 | Computers & Internet
Hitachi 65F710 tv goes blank for a second...
sounds like a possible flex module problem. repair is usually abut $500- $600.
Apr 24, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Screen goes blank while typing
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 14, 2009 | Acer Aspire 5315 Notebook
LCD screen goes blank and computer stops functioning
This must be a loose connection on the lcd behind the lid or in the hinge, I would not atempt a repair, laptops are a nightmare, take to a specialist repairer.
Nov 27, 2006 | IBM ThinkPad T42 Notebook
Blank LCD screen?
Its probably a broken flex cable or the LCD is bad now because of all the flicking going on?? The flex cables about 15 bucks depending on where you get it but if your not good with really tiny electronics I would let a pro do the repair for you as you can cause alot of damage, as you could break other flex cables just taking it apart. Good Luck
May 04, 2006 | JVC Cybercam GR-DVP7 Mini DV Digital...
Televison & Video Logo
103 people viewed this question
Top Televison & Video Experts
Electro Med Services...
