So I left my laptop out, just bought it a few months ago. Dog peed on it. Turned it off immediately, set it over the heater to dry overnight. Boots up perfectly now and the mouse pad works great, but none of the keys work! Trying to replace keyboard or clean inside keys? Removed all screws from back and can't seem to remove the top of the keyboard portion, it doesn't budge. Is there a bezel I am missing or some tab type closure? Looked for one but can't find it. Have computer repair experience just not with this laptop.
Comments:
May 04, 2008
- Thank you was able to pull the keyboard off now easily. Removed the clear plastic sticky off the back of the keyboard. Keys are not "stuck" but are not being recognized. Any idea of how to clean the inside of the keyboard? Was thinking about soaking it in water and mild laundry detergent, but not sure about that. It has dried sticky stinky dog urine inside the spaces of the actual keyboard. The good news is that the plastic sticker prevented the pee from getting into the computer so everything there is fine. If this doesn't fix I will probably just hook up an external usb keyboard, but would like to fix instead.
-   My dog peed on my pc, too! We have it all cleaned off and the computer works fine, but after a while...after it gets hot...it stinks!!!!!! what to do now? ughh -   msmoodster
Sep 09, 2008
-   Okay, I finally figured it out. Plus it appears that there's a difference between the Compaq 700 and the Compaq *C*700. I just had to push my smallest screwdriver into one of the holes and it pushed the keyboard out. (A paperclip would also probably suffice). It would've helped if the manual said that. It also would've helped if it better explained how to release the zero-insertion-force connector holding in the cable, but I managed to figure that out after some playing around. My laptop bezel isn't too bad after the ordeal (the old keyboard took most of the scratches) but it still ticks me off that HP doesn't know how to explain things to its customers.-   Visor4
Sep 08, 2008
-   > Look for 4 tabs on the top edge of the keyboard. Use a small flat head screwdriver or something similar and pry forward.
You're kidding, right? I'm looking at my Compaq C776 and I can barely see the tabs. When I try to pry at them with a small flathead screwdriver, I scratch up the nice finish above the keyboard. This is NOT an "easy" solution as the keyboard still won't budge and now I'm scratching my 3-week-old laptop all to hell. I've removed all 3 keyboard screws, and a couple of others just for good measure. The HP manual does not mention anything about poking at tabs, and makes it seem like the keyboard should come out in a sinch. Anybody else got any ideas?-   Visor4
May 16, 2008
-   i did;nt spill anything on my Presario 700. the keyboard just dont work. it turns on and all, the mouse pad works but not the keyboard. please help.
-   Kizzy30
THIS might help..:) Should you have any further questions,
please feel free to post them here.
P.S. - If you find that the solution/answer
I provided led you to, or resulted in a fix, please close the ticket with a FixYa!
rating.I would be very grateful for your show of appreciation. If it hasn’t, please do not assign a rating just
yet. Please post back as to what steps you took, results, etc, and I will try
to assist you further as best I can. I am here at your service.
My compaq presario 700 is apparently made a little differently.
there are no tabs...to get the key board out, all you have to do is:
Use a paper clip(that way it doesn't scratch everything as badly..
slip the paperclip in the corner above your del key...this is the thin panel that has your power light, volume keys etc. work your paperclip sliding it to the left, as you still pull up on it, and that panel will pop right off,once that's off, you can then just slide the keyboard upwards...and it will come right out.
when i turn on it boots for a while then shuts off completeley. At on time I was able to boot to...
(More)
when i turn on it boots for a while then shuts off completeley. At on time I was able to boot to Windows but now it shuts off before it can go to windows. I suspected it was the chip and bought a new on....however....it wont even turn on. i also changed the fan and heatsink module....still no success.
my laptop boots up with eight separate screens? it has gone back to one screen a couple of times but...
(More)
my laptop boots up with eight separate screens? it has gone back to one screen a couple of times but it now only boots up with eight screens, like tile effect?
My CD-ROM drive is not opening or closing when i put a CD in it just blinks like its busy and is not...
(More)
My CD-ROM drive is not opening or closing when i put a CD in it just blinks like its busy and is not being read. I dont see the other drivers that use to be in the my computer section all there is the C dive and D drive
